Water Level Sensor..
Use air pressure. Basic scuba diving principles. Lets say you wanted to
measure the height of water in a 55gal drum. Take a piece of pvc pipe with
a sealed end cap and stick a barb connector through the top with a piece of
pvc tubing attached. Run this tubing to a Motorola pressure sensor (from
Jameco) and measure the pressure. As the water level falls, the pressure
exerted on the sensor will fall. As the water in the drum rises, the
pressure will rise within the pvc pipe.
Brian
At 03:50 AM 8/29/2003 +0000, you wrote:
<SNIP>
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.512 / Virus Database: 309 - Release Date: 8/19/2003
Brian
<SNIP>
I need to put together a water level display for a friend with a
shallow well, 18' deep to be exact. With very little precipitation this
summer his well is running low and he needs to check the basic water level
prior to taking a shower or filling his horses water tubs etc, to know if
he can do it at the time, or if he needs to wait for the level to rise first.
My question is regarding the level sensor -- he would like to have
feedback regarding the entire well depth. I'd like to use a capacitive
type sensor but don't know if such a critter exists for that length or
within a reasonable price. I've also thought of using an ultrasonic ranger
at the top of the well to get a distance measurement to the water surface,
which I think would work well, but I don't think it would hold up well in
that humid environment. What would you recommend for a basic low
resolution level sensor capable of 18 feet of sensing, that could last for
a while? Tracy, given your experience, what are your thoughts?
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
My first thought is a pressure sensor.
hermetically sealed, and lowered to depth. water weight is constant
per foot so it should be simple to do.
18 foot is the total depth of the well ? or is the water 18 feet deep
in a 30 foot well ?
If the well is 18 ft deep and he expects 8 ft of water, IIRC, fresh
water is 14.7 pounds for every 34 feet ? (old SCUBA days long past)
How big is the well ? is it a 4" hole, or a 3 ft pit ?
I'm thinking a PVC tube with the coil and a float with another coil
for mass.
And, I assume you already thought that any stuff you put down there
will wind up in the coffee ? ie: use stainless, not copper.
Dave
--- In basicstamps@yahoogroups.com, Timothy Medema <timm@c...> wrote:
> Hey Everyone,
with a
this
water level
know if
rise first.
to have
capacitive
ultrasonic ranger
surface,
well in
last for
> Thanks,
> Tim
> Timothy Medema
entity to
of, or
received
from any
> computer.
Good ideas. The well is a total of 18' deep and 3' in diameter
for that entire height. Yes, as far as what I put down there ending up in
the coffee -- that's why I like the ultrasonic, sense from the top of the
well, non-contact idea.
Tim
At 03:42 PM 8/28/2003 +0000, you wrote:
>Hi Tim,
>in a 30 foot well ?
>for mass.
>Dave
> > Hey Everyone,
>with a
>this
>water level
>know if
>rise first.
>to have
>capacitive
>or
>ultrasonic ranger
>surface,
>well in
>last for
> > Thanks,
> > Tim
> > Timothy Medema
>entity to
>of, or
>or
>received
>from any
> > computer.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
tight enclosure, with a nice length of wire coming out of it. You
just have to hook up +5V, GND, and then hook the signal wire up to an
analog to digital converter chip and a basic stamp1. See the
rovcircuit.gif in the ROV folder in the file section of this message
board. In the top right corner you'll see the pressure transducer
hooked up to the ADC and the BS1 (you won't need the bob-III chip).
To get this pressure transducer go to digikey.com, the model is:
MSP6025P3-4-ND. It costs $110.50. if you got a long enough cable, you
could just lower the pressure transducer into the well whenever you
needed to test water height. At the top of the well, the cable would
connect to the basic stamp and analog to digital converter (and an
LCD or a laptop to see the output).
> Hi Dave,
diameter
ending up in
of the
> Tim
> >Hi Tim,
constant
deep
> >in a 30 foot well ?
> >for mass.
> >Dave
wrote:
> > > Hey Everyone,
friend
> >with a
precipitation
> >this
> >water level
to
> >know if
to
> >rise first.
like
> >to have
> >capacitive
length
> >or
> >ultrasonic ranger
water
> >surface,
up
> >well in
low
could
> >last for
> > > Thanks,
> > > Tim
> > > Timothy Medema
> >entity to
privileged
use
> >of, or
persons
> >or
you
> >received
> >from any
> > > computer.
Subject and
a tube? As you sweep a sine wave frequency into that type of system with a
small speaker and listen with a microphone, the system will resonate at a
single frequency depending on length of air in the tube. Tune a coke bottle
with water and blow across it to see the effect. I'm guessing that
fractional-inch accuracy would be repeatable if you could resolve to a few
Hertz.
Also, I've not tried it at high frequencies, but at low ones you can measure
the feedback on the exciting speaker itself to determine the resonant
frequency of the system. There will be an impedance spike at the resonant
frequency which is easy to measure via a resistor in series with the driver
speaker. That way a single driver could act as both an exciter-speaker and
sense-microphone. A small/cheap speaker with a coat of varnish on the cone
could be an inexpensive water-proof exciter and sensor at the same time.
If you need some audio math to support such an experiment let me know. I'm
not really a stamp guy, but I do sound for a living.
Mike Sokol
www.modernrecording.com
mikes@m...
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, August 28, 2003 11:59 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Water Level Sensor..
> Hi Dave,
> Tim
> >Hi Tim,
> >in a 30 foot well ?
> >for mass.
> >Dave
> > > Hey Everyone,
> >with a
> >this
> >water level
> >know if
> >rise first.
> >to have
> >capacitive
> >or
> >ultrasonic ranger
> >surface,
> >well in
> >last for
> > > Thanks,
> > > Tim
> > > Timothy Medema
> >entity to
> >of, or
> >or
> >received
> >from any
> > > computer.
Another great idea, I'm looking into it.
Tim
At 04:11 PM 8/28/2003 +0000, you wrote:
>I used a pressure transducer on my ROV that came ready in a water
> > Hi Dave,
>diameter
>ending up in
>of the
> > Tim
> > >Hi Tim,
>constant
>deep
> > >in a 30 foot well ?
> > >for mass.
> > >Dave
>wrote:
> > > > Hey Everyone,
>friend
> > >with a
>precipitation
> > >this
> > >water level
>to
> > >know if
>to
> > >rise first.
>like
> > >to have
> > >capacitive
>length
> > >or
> > >ultrasonic ranger
>water
> > >surface,
>up
> > >well in
>low
>could
> > >last for
> > > > Thanks,
> > > > Tim
> > > > Timothy Medema
> > >entity to
>privileged
>use
> > >of, or
>persons
> > >or
>you
> > >received
> > >from any
> > > > computer.
>Subject and
If you only need to know depth at discrete points, there are a lot
more possibilities.. E.g., www.qprox.com has some 2-point level
sensor chips, as well as some that are meant for depth gages.
The longest capacitive sensor I know of commercially is 2 meters
long. I don't know what luck you would have to build one yourself
down to 18 feet (~6 meters). Capacitive sensors are not the most
stable, maybe good to 1%fs accuracy, as deposits left on the sense
wire cause the calibration to drift with time,temperature and
humidity. Especially useless in salt water. I have a lot of
experience with capacitive probes (much of it unpleasant!).
The most accurate water depth sensors are the ones based on a float
and a beaded cable coming up over an encoder wheel to a
counterweight. They can resolve 1 mm in 10s of meters of water
level, better than 0.01% with a stable mounting inside a clean
shelter. That is what the USGS hydrological stations use.
Pressure sensors at the bottom of the well can be good for 1% or
better accuracy. For long term monitoring, it requires a gage
transducer with a vented cable coming up to the top, so you are
measuring the pressure relative to atmospheric. An absolute pressure
transducer is also possible, but then you might have to account for
changes in barometric pressure (150 millibar extreme~5 feet of
water), and temperature. An absolute pressure sensor is fine in
systems where you can lower it down from the surface and get a fix on
pressure both at the surface and at depth within a short time period.
A bubbler system puts the pressure sensor at the top of the well,
instead of at the bottom, and measures the gage pressure necessary to
force gas bubbles out of a tube at a fixed position underwater.
Ultrasound you mention, too, and there are waterproof transducers
available. The electronics is a little more complicated, and the
price of commercial units attests to the nuances of making it work at
its best. But it should work great in an 18' well if there are not a
lot of obstructions.
Mike's idea of a sound probe, to measure the resonant frequency of an
"organ pipe" is fascinating. I've never seen a depth probe based on
that principle. If you've ever listened at the top of a well or a
pipe going down into the water, you know how much the cavity molds
the sounds of water sloshing or other natural sounds.
Another method I've not seen commercially is that of a radio
frequency stub, shorted at the bottom by the water. The quarter-wave
resonance to be monitored and computed to water depth.
-- best regards
Tracy Allen
electronically monitored ecosystems
http://www.emesystems.com
mailto:tracy@e...
>Hey Everyone,
>Thanks,
>Tim
>Timothy Medema
water and measure the time to impact and the sound of the splash.
(every body has a plan that will not work)
Also, if you considder using a long piece of PVC pipe, you could
insert some sort of sensors and have a magnetic float so that as the
float lifted, it would trip descrete points. that seems to offer the
complete plastic enclosure and simple switches.
just a variation of a theme.
One idea is that you could control a valve(s) so that when the well
went below some points, things like the garden hose would shut off,
or water pressure (and therfore flow) would reduce, allowing the well
to recover or not drain as fast.
That way, you wouldn't be stuck in the shower.
Dave
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Tim,
pressure
on
period.
to
at
a
an
on
wave
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >Hey Everyone,
with a
precipitation this
water level
know if
rise first.
like to have
capacitive
length or
ultrasonic ranger
surface,
well in
last for
> >Thanks,
> >Tim
> >Timothy Medema
the analog processing needed would be quite straightforward. These are
simple extensions of what we audio guys do on a daily basis. The hardware
involved would be inexpensive as well. I really think this could be a great
non-contact way to measure liquid levels, flammable or otherwise. Has anyone
ever seen this method used in a commercial device, or is it a new idea (i.e.
an invention)?
Once the proper analog pre-processing is done, a Stamp could do anything you
wanted to do with the data. Drive a readout, ring a bell, start a pump, etc.
Of course, you could do the whole thing digitally, but I'm not sure a stamp
would have the horsepower for that sort of work. Could be fun to play with
though.
Any feedback?
Mike Sokol
mikes@m...
Original Message
Sent: Thursday, August 28, 2003 9:08 PM
Subject: [noparse][[/noparse]basicstamps] Re: Water Level Sensor..
> When reading Mike's idea, it stuck me that one could drop a drop of
> Dave
> > Hi Tim,
> pressure
> on
> period.
> to
> at
> a
> an
> on
> wave
> > -- best regards
> > Tracy Allen
> > mailto:tracy@e...
> > >Hey Everyone,
> with a
> precipitation this
> water level
> know if
> rise first.
> like to have
> capacitive
> length or
> ultrasonic ranger
> surface,
> well in
> last for
> > >Thanks,
> > >Tim
> > >Timothy Medema
surface,
well in
--what about putting the ultrasonic ranger in an enclosure with a
shutter-like door operated by a solenoid?
but you can extend it by using a tube. Take a look at
http://www.kele.com/olcat/ss6/ALP-V.pdf , its the owner's manual for the
alphasonic units we use to control water level in diatomaceous earth filter
tanks. I don't know anything else about the subject, other than that these
have worked very reliably for a little over five years so far. This is in a
public swimming pool mechanical room - quite hot and very humid 24/7 - also
lots of chloramines in the air - even low grade stainless steel rusts within
a few months there.
Original Message
> From: rdenn25 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=032aax3Sr1qUj4BYoSY22UhxQTe8FMFWMF3_Dhas2DEkqXXMG5OBaAOKizkvLYUidqOhCm-gXw]rad0@a...[/url
> Sent: August 28, 2003 8:51 PM
> To: basicstamps@yahoogroups.com
> surface,
> well in
> Subject and Body of the message will be ignored.
does make sense.
One possible problem is natural noise. In streams at full flow, "the
roar is deafening", and even a narrow measurement tube creates a huge
turbulence wake of its own. I guess that would not usually be a
problem in a well or a tank or a lake. Would extraneous sounds be a
problem? Electronically, the detection system could be made
extremely narrow band.
-- Tracy
>I'm sure the tuned organ-pipe system would work from physics principals, and
>an invention)?
>though.
>Any feedback?
>Mike Sokol
>mikes@m...
Original Message
>From: "Dave Mucha" <davemucha@j...>
>> Dave
>> > Hi Tim,
>> pressure
> > on
>> period.
>> to
>> at
>> a
>> an
>> on
>> wave
>> > -- best regards
>> > Tracy Allen
>> > mailto:tracy@e...
>> > >Hey Everyone,
>> with a
>> precipitation this
>> water level
>> know if
>> rise first.
>> like to have
>> capacitive
>> length or
>> ultrasonic ranger
>> surface,
>> well in
>> last for
>> > >Thanks,
>> > >Tim
>> > >Timothy Medema
wanted to
pipe with
piece of
(from
pressure
the
> Brian
At first glance, adding air to the bottom of the tank might promore
alge growth? I'm not sure how much oxygen isn in ground water.
If is not only a great idea, it also one that can be very accurate
and is done industrially. So it is proven.
I imagine some form of capacity tank with a couple valves couild be
used.
drain the tank, then seal it, open the water pressure to it and it
will pressureize to the pump pressure. the bubbler will only need
about 8 psi at the 16 ft depth so the pressuers are not hard to
obtain nor hard to measure.
of course, you need to measure the level in the capacity tank and
open and close some valves.
Dave
> <SNIP>
I had the same idea, but someone pointed out the the air in the tube would
slowly dissolve into the water. I wonder how much of a "real world" problem
that would be though.
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, August 29, 2002 9:44 PM
with
of
> Brian
> <SNIP>
transducer - these are generally compatible with "clean, dry gases". I've
had problems with long-term drift with these because of that reason.
Jeff
Original Message
> Brian,
problem
> Jonathan
> www.madlabs.info
Original Message
> From: "Brian Gracia" <bgracia1@b...>
to
> with
> of
(from
pressure
> > Brian
ideas have come across (the organ tube is genus!) We have failed to keep it
simple. he just wants to know when it's close to empty!
A 15 foot pole hanging off the side with a float sensor....when the water drops
to 3 feet or so the float no longer floats...that will close a switch. Cheap,
simple and does what he wants.
My high tech toilet knows when to fill itself by the same technology. [noparse]:)[/noparse]
Tim
>>> kennedy@t... 08/29/03 10:28AM >>>
I think the real problem is water vapor in the air causing problems with the
Jeff
Original Message
> Brian,
problem
> Jonathan
> www.madlabs.info
Original Message
to
> with
> of
(from
pressure
> > Brian
from the same email address that you subscribed. Text in the Subject and Body
tim.hart@h... writes:
The original posted just wanted to know when it was low. While some
astonishing ideas have come across (the organ tube is genus!) We have failed
to keep
it simple. he just wants to know when it's close to empty!
drops to 3 feet or so the float no longer floats...that will close a switch.
Cheap, simple and does what he wants.
Tim
Great point Tim !!
Go ahead and contact me off-list if this is getting too far off-topic for
this group. But for those interested, here's some thoughts on "organ-pipe"
liquid-level sensors.
One way to overcome the noise problem is to make a tuned narrow-band filter
that follows the sine wave frequency from the signal generator. That way the
sensor only listens to the single frequency in question. You could make this
filter 1 Hz wide if you really wanted to. Doing it digitally would be pretty
straightforward, but a DSP (Digital Sound Processing) chip might be needed
for really fast computations. However, I may be worrying too much about fast
response time, since I'm sure the level change will be quite slow, correct?
Then once the generator sweeps through its range and locks into a "depth"
note, a PLL (phase locked loop) circuit could keep it centered on the
"note". This is how FM radios work to stay on-station. PLL technology is
very refined and affordable. It's just a VCO (Voltage Controlled Oscillator)
and detector. That by it self could form the heart of the exciter/detector
circuit. Then use a stamp (or whatever) to measure the frequency it's locked
on to, process the info for whatever data you want to extract (rate of rise,
absolute depth, etc.) and make something happen. If you need really close
accuracy, you could also calculate the temp of the air in the pipe as well
as barometric pressure and use this data to correct for variations beyond
STP speed of sound (Standard Temperature Pressure) which is 1132 feet per
second at sea level. But I don't think this will be a big number compared to
the change in tube length.
Of course slide-whistles don't have all this excite-filter stuff, and they
do a very good job of following the length of a tube. So do trombones.
Trumpets are the digital version of a 'bone, I guess. In those cases,
there's some sort of general noise excitation of the tuned system, and the
whole system just grabs onto a single note and resonates. Same way with a
laser, albeit at a much higher frequency.
Mike Sokol
mikes@m...
301-739-6842 voice/fax
301-964-5682 mobile
Original Message
Sent: Friday, August 29, 2003 2:50 AM
> I've never seen that idea used in a depth or water level sensor. It
> does make sense.
> -- Tracy
and
great
anyone
(i.e.
> >an invention)?
you
etc.
stamp
with
> >though.
> >Any feedback?
> >Mike Sokol
> >mikes@m...
Original Message
> >> Dave
> >> > Hi Tim,
> >> pressure
> > > on
> >> period.
> >> to
> >> at
> >> a
> >> an
> >> on
> >> wave
> >> > -- best regards
> >> > Tracy Allen
> >> > mailto:tracy@e...
> >> > >Hey Everyone,
> >> with a
> >> precipitation this
> >> water level
> >> know if
> >> rise first.
> >> like to have
> >> capacitive
> >> length or
> >> ultrasonic ranger
> >> surface,
> >> well in
> >> last for
> >> > >Thanks,
> >> > >Tim
> >> > >Timothy Medema
and
tank is empty, I was thinking more about a fuel gauge for an airplane where
it would be really good to know that piece of data a bit before that
happened. ; )
Seriously, all sorts of real-world plant applications need to measure liquid
levels, some of which are quite corrosive. The pipe-organ sensor could be a
new technology for that type of engineering challenge.
Please let me know if any of you would like to play with this idea. I don't
have an immediate application for it myself, but could supply the math and
feedback on the design of such a device.
Mike Sokol
mikes@m...
Original Message
Sent: Friday, August 29, 2003 11:36 AM
failed to keep it simple. he just wants to know when it's close to empty!
> Tim
the
> Jeff
Original Message
> From: "Jonathan Peakall" <jpeakall@m...>
> > Brian,
would
> problem
> > Jonathan
> > www.madlabs.info
Original Message
> to
> > with
piece
> > of
> (from
> pressure
> > > Brian
quite well to measure levels in sewage holding tanks. Mechanical sensors get
crudded up pretty easily. And a glass tube with photo-sensor would quickly
become dirty. But I think the a pipe-organ sensor tube would always know the
depth be able to turn on the pumps.
I love it when different worlds collide.
Mike Sokol
mikes@m...
Original Message
> does make sense.
> -- Tracy
and
great
anyone
(i.e.
> >an invention)?
you
etc.
stamp
with
> >though.
> >Any feedback?
> >Mike Sokol
> >mikes@m...
Original Message
> >> Dave
> >> > Hi Tim,
> >> pressure
> > > on
> >> period.
> >> to
> >> at
> >> a
> >> an
> >> on
> >> wave
> >> > -- best regards
> >> > Tracy Allen
> >> > mailto:tracy@e...
> >> > >Hey Everyone,
> >> with a
> >> precipitation this
> >> water level
> >> know if
> >> rise first.
> >> like to have
> >> capacitive
> >> length or
> >> ultrasonic ranger
> >> surface,
> >> well in
> >> last for
> >> > >Thanks,
> >> > >Tim
> >> > >Timothy Medema
and
>One more "stinky" thought. This sort of level sensor would probably work
>Mike Sokol
>mikes@m...
Mike -
In a sewage setup I wonder if one might recirculate and recover the methane
gas to "toot the pipe" so to speak :-)
Bruce Bates
Original Message
>From: "Tracy Allen" <tracy@e...>
> > does make sense.
> > -- Tracy
>and
>great
>anyone
>(i.e.
> > >an invention)?
>you
>etc.
>stamp
>with
> > >though.
> > >Any feedback?
> > >Mike Sokol
> > >mikes@m...
Original Message
> > >> Dave
> > >> > Hi Tim,
> > >> pressure
> > > > on
> > >> period.
> > >> to
> > >> at
> > >> a
> > >> an
> > >> on
> > >> wave
> > >> > -- best regards
> > >> > Tracy Allen
> > >> > mailto:tracy@e...
> > >> > >Hey Everyone,
> > >> with a
> > >> precipitation this
> > >> water level
> > >> know if
> > >> rise first.
> > >> like to have
> > >> capacitive
> > >> length or
> > >> ultrasonic ranger
> > >> surface,
> > >> well in
> > >> last for
> > >> > >Thanks,
> > >> > >Tim
> > >> > >Timothy Medema
>and
That well is a pretty large pipe! I think the physics are sound and
maybe practical too but you may be needing a pretty low frequency
speaker - maybe a super subwoofer?
Since you admitted to being a sound guy, what is the resonant
frequency of the well as a pipe? Also what would be the resonant
frequency of a smaller sensing pipe that could be placed into the
well. Maybe a 2" X 18' PVC piece?
Maybe another solution could be a combination of the SONAR approach
but using tone bursts with audible frequencies and outdoor speakers
rather than ultrasonics. At 1.77ms/ft (for dry air! Probably needs
corrected for humidity of the well.) the round trip delay would be
about 32 ms for 18 ft. Some resolution would be lost at the lower
frequencies but to shower or not probably doesn't depend on +-
0.001" of water in the well.
If there is a lot of noise in the well already from a stream or
whatever, maybe the system could "listen" for the frequency with the
largest amplitude? that goes back to the organ pipe idea but using
the white noise from the stream to excite it.
Harry
Stamp Robotics to the next level
www.bluebelldesign.com
--- In basicstamps@yahoogroups.com, "Mike Sokol - ModernRecording"
principals, and
are
hardware
be a great
Has anyone
idea (i.e.
> an invention)?
<snip...>
> Any feedback?
> Mike Sokol
> mikes@m...
Original Messages cut
