Water Level Sensor.. — Parallax Forums
edited 2003-09-04 03:30 in General Discussion
Use air pressure. Basic scuba diving principles. Lets say you wanted to
measure the height of water in a 55gal drum. Take a piece of pvc pipe with
a sealed end cap and stick a barb connector through the top with a piece of
pvc tubing attached. Run this tubing to a Motorola pressure sensor (from
Jameco) and measure the pressure. As the water level falls, the pressure
exerted on the sensor will fall. As the water in the drum rises, the
pressure will rise within the pvc pipe.
Brian
At 03:50 AM 8/29/2003 +0000, you wrote:
<SNIP>
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.512 / Virus Database: 309 - Release Date: 8/19/2003
    edited 2003-08-28 16:25
    Hey Everyone,
    I need to put together a water level display for a friend with a
    shallow well, 18' deep to be exact. With very little precipitation this
    summer his well is running low and he needs to check the basic water level
    prior to taking a shower or filling his horses water tubs etc, to know if
    he can do it at the time, or if he needs to wait for the level to rise first.
    My question is regarding the level sensor -- he would like to have
    feedback regarding the entire well depth. I'd like to use a capacitive
    type sensor but don't know if such a critter exists for that length or
    within a reasonable price. I've also thought of using an ultrasonic ranger
    at the top of the well to get a distance measurement to the water surface,
    which I think would work well, but I don't think it would hold up well in
    that humid environment. What would you recommend for a basic low
    resolution level sensor capable of 18 feet of sensing, that could last for
    a while? Tracy, given your experience, what are your thoughts?
    Tim
    Timothy Medema
    CrystaLite, Incorporated
    3307 Cedar St. (425) 745-6000 800-666-6065
    Everett, WA 98201 Fax: (425) 257-0232
    www.crystaliteinc.com
    <mailto:timm@c...>timm@c...
    The information transmitted is intended only for the person or entity to
    whom it is addressed and may contain confidential and/or privileged
    material. Any review, retransmission, dissemination or other use of, or
    taking of any action in reliance upon, this information by persons or
    entities other than the intended recipient is prohibited. If you received
    this in error, please contact the sender and delete the material from any
    computer.
    edited 2003-08-28 16:42
    Hi Tim,
    My first thought is a pressure sensor.
    hermetically sealed, and lowered to depth. water weight is constant
    per foot so it should be simple to do.
    18 foot is the total depth of the well ? or is the water 18 feet deep
    in a 30 foot well ?
    If the well is 18 ft deep and he expects 8 ft of water, IIRC, fresh
    water is 14.7 pounds for every 34 feet ? (old SCUBA days long past)
    How big is the well ? is it a 4" hole, or a 3 ft pit ?
    I'm thinking a PVC tube with the coil and a float with another coil
    for mass.
    And, I assume you already thought that any stuff you put down there
    will wind up in the coffee ? ie: use stainless, not copper.
    Dave
    --- In basicstamps@yahoogroups.com, Timothy Medema <timm@c...> wrote:
    > Hey Everyone,
    with a
    this
    water level
    know if
    rise first.
    to have
    capacitive
    ultrasonic ranger
    surface,
    well in
    last for
    > Thanks,
    > Tim
    > Timothy Medema
    entity to
    of, or
    received
    from any
    > computer.
    edited 2003-08-28 16:59
    Hi Dave,
    Good ideas. The well is a total of 18' deep and 3' in diameter
    for that entire height. Yes, as far as what I put down there ending up in
    the coffee -- that's why I like the ultrasonic, sense from the top of the
    well, non-contact idea.
    Tim
    At 03:42 PM 8/28/2003 +0000, you wrote:
    >Hi Tim,
    >in a 30 foot well ?
    >for mass.
    >Dave
    > > Hey Everyone,
    >with a
    >this
    >water level
    >know if
    >rise first.
    >to have
    >capacitive
    >or
    >ultrasonic ranger
    >surface,
    >well in
    >last for
    > > Thanks,
    > > Tim
    > > Timothy Medema
    >entity to
    >of, or
    >or
    >received
    >from any
    > > computer.
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-08-28 17:11
    I used a pressure transducer on my ROV that came ready in a water
    tight enclosure, with a nice length of wire coming out of it. You
    just have to hook up +5V, GND, and then hook the signal wire up to an
    analog to digital converter chip and a basic stamp1. See the
    rovcircuit.gif in the ROV folder in the file section of this message
    board. In the top right corner you'll see the pressure transducer
    hooked up to the ADC and the BS1 (you won't need the bob-III chip).
    To get this pressure transducer go to digikey.com, the model is:
    MSP6025P3-4-ND. It costs $110.50. if you got a long enough cable, you
    could just lower the pressure transducer into the well whenever you
    needed to test water height. At the top of the well, the cable would
    connect to the basic stamp and analog to digital converter (and an
    LCD or a laptop to see the output).
    > Hi Dave,
    diameter
    ending up in
    of the
    > Tim
    > >Hi Tim,
    constant
    deep
    > >in a 30 foot well ?
    > >for mass.
    > >Dave
    wrote:
    > > > Hey Everyone,
    friend
    > >with a
    precipitation
    > >this
    > >water level
    to
    > >know if
    to
    > >rise first.
    like
    > >to have
    > >capacitive
    length
    > >or
    > >ultrasonic ranger
    water
    > >surface,
    up
    > >well in
    low
    could
    > >last for
    > > > Thanks,
    > > > Tim
    > > > Timothy Medema
    > >entity to
    privileged
    use
    > >of, or
    persons
    > >or
    you
    > >received
    > >from any
    > > > computer.
    Subject and
    edited 2003-08-28 17:18
    Has anyone ever tried an organ-pipe approach for measuring liquid height in
    a tube? As you sweep a sine wave frequency into that type of system with a
    small speaker and listen with a microphone, the system will resonate at a
    single frequency depending on length of air in the tube. Tune a coke bottle
    with water and blow across it to see the effect. I'm guessing that
    fractional-inch accuracy would be repeatable if you could resolve to a few
    Hertz.
    Also, I've not tried it at high frequencies, but at low ones you can measure
    the feedback on the exciting speaker itself to determine the resonant
    frequency of the system. There will be an impedance spike at the resonant
    frequency which is easy to measure via a resistor in series with the driver
    speaker. That way a single driver could act as both an exciter-speaker and
    sense-microphone. A small/cheap speaker with a coat of varnish on the cone
    could be an inexpensive water-proof exciter and sensor at the same time.
    If you need some audio math to support such an experiment let me know. I'm
    not really a stamp guy, but I do sound for a living.
    Mike Sokol
    www.modernrecording.com
    mikes@m...
    Sent: Thursday, August 28, 2003 11:59 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Water Level Sensor..
    > Hi Dave,
    > Tim
    > >Hi Tim,
    > >in a 30 foot well ?
    > >for mass.
    > >Dave
    > > > Hey Everyone,
    > >with a
    > >this
    > >water level
    > >know if
    > >rise first.
    > >to have
    > >capacitive
    > >or
    > >ultrasonic ranger
    > >surface,
    > >well in
    > >last for
    > > > Thanks,
    > > > Tim
    > > > Timothy Medema
    > >entity to
    > >of, or
    > >or
    > >received
    > >from any
    > > > computer.
    edited 2003-08-28 17:23
    Thanks Sam,
    Another great idea, I'm looking into it.
    Tim
    > > Hi Dave,
    >diameter
    >ending up in
    >of the
    > > Tim
    > > >Hi Tim,
    >constant
    >deep
    > > >in a 30 foot well ?
    > > >for mass.
    > > >Dave
    >wrote:
    > > > > Hey Everyone,
    >friend
    > > >with a
    >precipitation
    > > >this
    > > >water level
    >to
    > > >know if
    >to
    > > >rise first.
    >like
    > > >to have
    > > >capacitive
    >length
    > > >or
    > > >ultrasonic ranger
    >water
    > > >surface,
    >up
    > > >well in
    >low
    >could
    > > >last for
    > > > > Thanks,
    > > > > Tim
    > > > > Timothy Medema
    > > >entity to
    >privileged
    >use
    > > >of, or
    >persons
    > > >or
    >you
    > > >received
    > > >from any
    > > > > computer.
    >Subject and
    edited 2003-08-28 23:20
    Hi Tim,
    If you only need to know depth at discrete points, there are a lot
    more possibilities.. E.g., www.qprox.com has some 2-point level
    sensor chips, as well as some that are meant for depth gages.
    The longest capacitive sensor I know of commercially is 2 meters
    long. I don't know what luck you would have to build one yourself
    down to 18 feet (~6 meters). Capacitive sensors are not the most
    stable, maybe good to 1%fs accuracy, as deposits left on the sense
    wire cause the calibration to drift with time,temperature and
    humidity. Especially useless in salt water. I have a lot of
    experience with capacitive probes (much of it unpleasant!).
    The most accurate water depth sensors are the ones based on a float
    and a beaded cable coming up over an encoder wheel to a
    counterweight. They can resolve 1 mm in 10s of meters of water
    level, better than 0.01% with a stable mounting inside a clean
    shelter. That is what the USGS hydrological stations use.
    Pressure sensors at the bottom of the well can be good for 1% or
    better accuracy. For long term monitoring, it requires a gage
    transducer with a vented cable coming up to the top, so you are
    measuring the pressure relative to atmospheric. An absolute pressure
    transducer is also possible, but then you might have to account for
    changes in barometric pressure (150 millibar extreme~5 feet of
    water), and temperature. An absolute pressure sensor is fine in
    systems where you can lower it down from the surface and get a fix on
    pressure both at the surface and at depth within a short time period.
    A bubbler system puts the pressure sensor at the top of the well,
    instead of at the bottom, and measures the gage pressure necessary to
    force gas bubbles out of a tube at a fixed position underwater.
    Ultrasound you mention, too, and there are waterproof transducers
    available. The electronics is a little more complicated, and the
    price of commercial units attests to the nuances of making it work at
    its best. But it should work great in an 18' well if there are not a
    lot of obstructions.
    Mike's idea of a sound probe, to measure the resonant frequency of an
    "organ pipe" is fascinating. I've never seen a depth probe based on
    that principle. If you've ever listened at the top of a well or a
    pipe going down into the water, you know how much the cavity molds
    the sounds of water sloshing or other natural sounds.
    Another method I've not seen commercially is that of a radio
    frequency stub, shorted at the bottom by the water. The quarter-wave
    resonance to be monitored and computed to water depth.
    -- best regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
    >Hey Everyone,
    >Thanks,
    >Tim
    >Timothy Medema
    edited 2003-08-29 02:08
    When reading Mike's idea, it stuck me that one could drop a drop of
    water and measure the time to impact and the sound of the splash.
    (every body has a plan that will not work)
    Also, if you considder using a long piece of PVC pipe, you could
    insert some sort of sensors and have a magnetic float so that as the
    float lifted, it would trip descrete points. that seems to offer the
    complete plastic enclosure and simple switches.
    just a variation of a theme.
    One idea is that you could control a valve(s) so that when the well
    went below some points, things like the garden hose would shut off,
    or water pressure (and therfore flow) would reduce, allowing the well
    to recover or not drain as fast.
    That way, you wouldn't be stuck in the shower.
    Dave
    --- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
    > Hi Tim,
    pressure
    on
    period.
    to
    at
    a
    an
    on
    wave
    > -- best regards
    > Tracy Allen
    > mailto:tracy@e...
    > >Hey Everyone,
    with a
    precipitation this
    water level
    know if
    rise first.
    like to have
    capacitive
    length or
    ultrasonic ranger
    surface,
    well in
    last for
    > >Thanks,
    > >Tim
    > >Timothy Medema
    edited 2003-08-29 02:34
    I'm sure the tuned organ-pipe system would work from physics principals, and
    the analog processing needed would be quite straightforward. These are
    simple extensions of what we audio guys do on a daily basis. The hardware
    involved would be inexpensive as well. I really think this could be a great
    non-contact way to measure liquid levels, flammable or otherwise. Has anyone
    ever seen this method used in a commercial device, or is it a new idea (i.e.
    an invention)?
    Once the proper analog pre-processing is done, a Stamp could do anything you
    wanted to do with the data. Drive a readout, ring a bell, start a pump, etc.
    Of course, you could do the whole thing digitally, but I'm not sure a stamp
    would have the horsepower for that sort of work. Could be fun to play with
    though.
    Any feedback?
    Mike Sokol
    mikes@m...
    Sent: Thursday, August 28, 2003 9:08 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Water Level Sensor..
    > Dave
    > > Hi Tim,
    > pressure
    > on
    > period.
    > to
    > at
    > a
    > an
    > on
    > wave
    > > -- best regards
    > > Tracy Allen
    > > mailto:tracy@e...
    > > >Hey Everyone,
    > with a
    > precipitation this
    > water level
    > know if
    > rise first.
    > like to have
    > capacitive
    > length or
    > ultrasonic ranger
    > surface,
    > well in
    > last for
    > > >Thanks,
    > > >Tim
    > > >Timothy Medema
    edited 2003-08-29 04:50
    surface,
    well in
    --what about putting the ultrasonic ranger in an enclosure with a
    shutter-like door operated by a solenoid?
    edited 2003-08-29 05:23
    We talked about ultrasonic on the list a month or two back. Range is limited
    but you can extend it by using a tube. Take a look at
    http://www.kele.com/olcat/ss6/ALP-V.pdf , its the owner's manual for the
    alphasonic units we use to control water level in diatomaceous earth filter
    tanks. I don't know anything else about the subject, other than that these
    have worked very reliably for a little over five years so far. This is in a
    public swimming pool mechanical room - quite hot and very humid 24/7 - also
    lots of chloramines in the air - even low grade stainless steel rusts within
    a few months there.
    > From: rdenn25 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=032aax3Sr1qUj4BYoSY22UhxQTe8FMFWMF3_Dhas2DEkqXXMG5OBaAOKizkvLYUidqOhCm-gXw]rad0@a...[/url
    > Sent: August 28, 2003 8:51 PM
    > surface,
    > well in
    edited 2003-08-29 07:50
    I've never seen that idea used in a depth or water level sensor. It
    does make sense.
    One possible problem is natural noise. In streams at full flow, "the
    roar is deafening", and even a narrow measurement tube creates a huge
    turbulence wake of its own. I guess that would not usually be a
    problem in a well or a tank or a lake. Would extraneous sounds be a
    problem? Electronically, the detection system could be made
    extremely narrow band.
    -- Tracy
    >an invention)?
    >though.
    >Any feedback?
    >Mike Sokol
    >mikes@m...
    >From: "Dave Mucha" <davemucha@j...>
    >> Dave
    >> > Hi Tim,
    >> pressure
    > > on
    >> period.
    >> to
    >> at
    >> a
    >> an
    >> on
    >> wave
    >> > -- best regards
    >> > Tracy Allen
    >> > mailto:tracy@e...
    >> > >Hey Everyone,
    >> with a
    >> precipitation this
    >> water level
    >> know if
    >> rise first.
    >> like to have
    >> capacitive
    >> length or
    >> ultrasonic ranger
    >> surface,
    >> well in
    >> last for
    >> > >Thanks,
    >> > >Tim
    >> > >Timothy Medema
    edited 2003-08-29 13:44
    --- In basicstamps@yahoogroups.com, Brian Gracia <bgracia1@b...>
    wanted to
    pipe with
    piece of
    (from
    pressure
    the
    > Brian
    At first glance, adding air to the bottom of the tank might promore
    alge growth? I'm not sure how much oxygen isn in ground water.
    If is not only a great idea, it also one that can be very accurate
    and is done industrially. So it is proven.
    I imagine some form of capacity tank with a couple valves couild be
    used.
    drain the tank, then seal it, open the water pressure to it and it
    will pressureize to the pump pressure. the bubbler will only need
    about 8 psi at the 16 ft depth so the pressuers are not hard to
    obtain nor hard to measure.
    of course, you need to measure the level in the capacity tank and
    open and close some valves.
    Dave
    > <SNIP>
    edited 2003-08-29 15:48
    Brian,
    I had the same idea, but someone pointed out the the air in the tube would
    slowly dissolve into the water. I wonder how much of a "real world" problem
    that would be though.
    Jonathan
    www.madlabs.info
    Sent: Thursday, August 29, 2002 9:44 PM
    with
    of
    > Brian
    > <SNIP>
    edited 2003-08-29 16:28
    I think the real problem is water vapor in the air causing problems with the
    transducer - these are generally compatible with "clean, dry gases". I've
    had problems with long-term drift with these because of that reason.
    Jeff
    > Brian,
    problem
    > Jonathan
    > www.madlabs.info
    > From: "Brian Gracia" <bgracia1@b...>
    to
    > with
    > of
    (from
    pressure
    > > Brian
    edited 2003-08-29 16:36
    The original posted just wanted to know when it was low. While some astonishing
    ideas have come across (the organ tube is genus!) We have failed to keep it
    simple. he just wants to know when it's close to empty!
    A 15 foot pole hanging off the side with a float sensor....when the water drops
    to 3 feet or so the float no longer floats...that will close a switch. Cheap,
    simple and does what he wants.
    My high tech toilet knows when to fill itself by the same technology. [noparse]:)[/noparse]
    Tim
    >>> kennedy@t... 08/29/03 10:28AM >>>
    Jeff
    > Brian,
    problem
    > Jonathan
    > www.madlabs.info
    to
    > with
    > of
    (from
    pressure
    > > Brian
    from the same email address that you subscribed. Text in the Subject and Body
    edited 2003-08-29 17:30
    In a message dated 8/29/2003 8:37:40 AM Pacific Daylight Time,
    tim.hart@h... writes:
    astonishing ideas have come across (the organ tube is genus!) We have failed
    to keep
    it simple. he just wants to know when it's close to empty!
    drops to 3 feet or so the float no longer floats...that will close a switch.
    Cheap, simple and does what he wants.
    Tim
    Great point Tim !!
    edited 2003-08-30 12:52
    Tracy,
    Go ahead and contact me off-list if this is getting too far off-topic for
    this group. But for those interested, here's some thoughts on "organ-pipe"
    liquid-level sensors.
    One way to overcome the noise problem is to make a tuned narrow-band filter
    that follows the sine wave frequency from the signal generator. That way the
    sensor only listens to the single frequency in question. You could make this
    filter 1 Hz wide if you really wanted to. Doing it digitally would be pretty
    straightforward, but a DSP (Digital Sound Processing) chip might be needed
    for really fast computations. However, I may be worrying too much about fast
    response time, since I'm sure the level change will be quite slow, correct?
    Then once the generator sweeps through its range and locks into a "depth"
    note, a PLL (phase locked loop) circuit could keep it centered on the
    "note". This is how FM radios work to stay on-station. PLL technology is
    very refined and affordable. It's just a VCO (Voltage Controlled Oscillator)
    and detector. That by it self could form the heart of the exciter/detector
    circuit. Then use a stamp (or whatever) to measure the frequency it's locked
    on to, process the info for whatever data you want to extract (rate of rise,
    absolute depth, etc.) and make something happen. If you need really close
    accuracy, you could also calculate the temp of the air in the pipe as well
    as barometric pressure and use this data to correct for variations beyond
    STP speed of sound (Standard Temperature Pressure) which is 1132 feet per
    second at sea level. But I don't think this will be a big number compared to
    the change in tube length.
    Of course slide-whistles don't have all this excite-filter stuff, and they
    do a very good job of following the length of a tube. So do trombones.
    Trumpets are the digital version of a 'bone, I guess. In those cases,
    there's some sort of general noise excitation of the tuned system, and the
    whole system just grabs onto a single note and resonates. Same way with a
    laser, albeit at a much higher frequency.
    Mike Sokol
    mikes@m...
    301-739-6842 voice/fax
    301-964-5682 mobile
    Sent: Friday, August 29, 2003 2:50 AM
    > does make sense.
    > -- Tracy
    and
    great
    anyone
    (i.e.
    > >an invention)?
    you
    etc.
    stamp
    with
    > >though.
    > >Any feedback?
    > >Mike Sokol
    > >mikes@m...
    > >> Dave
    > >> > Hi Tim,
    > >> pressure
    > > > on
    > >> period.
    > >> to
    > >> at
    > >> a
    > >> an
    > >> on
    > >> wave
    > >> > -- best regards
    > >> > Tracy Allen
    > >> > mailto:tracy@e...
    > >> > >Hey Everyone,
    > >> with a
    > >> precipitation this
    > >> water level
    > >> know if
    > >> rise first.
    > >> like to have
    > >> capacitive
    > >> length or
    > >> ultrasonic ranger
    > >> surface,
    > >> well in
    > >> last for
    > >> > >Thanks,
    > >> > >Tim
    > >> > >Timothy Medema
    and
    edited 2003-08-30 13:04
    Ref the organ pipe sensor, of course this is way overkill just to know if a
    tank is empty, I was thinking more about a fuel gauge for an airplane where
    it would be really good to know that piece of data a bit before that
    happened. ; )
    Seriously, all sorts of real-world plant applications need to measure liquid
    levels, some of which are quite corrosive. The pipe-organ sensor could be a
    new technology for that type of engineering challenge.
    Please let me know if any of you would like to play with this idea. I don't
    have an immediate application for it myself, but could supply the math and
    feedback on the design of such a device.
    Mike Sokol
    mikes@m...
    Sent: Friday, August 29, 2003 11:36 AM
    failed to keep it simple. he just wants to know when it's close to empty!
    > Tim
    the
    > Jeff
    > From: "Jonathan Peakall" <jpeakall@m...>
    > > Brian,
    would
    > problem
    > > Jonathan
    > > www.madlabs.info
    > to
    > > with
    piece
    > > of
    > (from
    > pressure
    > > > Brian
    edited 2003-08-30 13:10
    One more "stinky" thought. This sort of level sensor would probably work
    quite well to measure levels in sewage holding tanks. Mechanical sensors get
    crudded up pretty easily. And a glass tube with photo-sensor would quickly
    become dirty. But I think the a pipe-organ sensor tube would always know the
    depth be able to turn on the pumps.
    I love it when different worlds collide.
    Mike Sokol
    mikes@m...
    > does make sense.
    > -- Tracy
    and
    great
    anyone
    (i.e.
    > >an invention)?
    you
    etc.
    stamp
    with
    > >though.
    > >Any feedback?
    > >Mike Sokol
    > >mikes@m...
    > >> Dave
    > >> > Hi Tim,
    > >> pressure
    > > > on
    > >> period.
    > >> to
    > >> at
    > >> a
    > >> an
    > >> on
    > >> wave
    > >> > -- best regards
    > >> > Tracy Allen
    > >> > mailto:tracy@e...
    > >> > >Hey Everyone,
    > >> with a
    > >> precipitation this
    > >> water level
    > >> know if
    > >> rise first.
    > >> like to have
    > >> capacitive
    > >> length or
    > >> ultrasonic ranger
    > >> surface,
    > >> well in
    > >> last for
    > >> > >Thanks,
    > >> > >Tim
    > >> > >Timothy Medema
    and
    edited 2003-08-30 16:45
    >Mike Sokol
    >mikes@m...
    Mike -
    In a sewage setup I wonder if one might recirculate and recover the methane
    gas to "toot the pipe" so to speak :-)
    Bruce Bates
    >From: "Tracy Allen" <tracy@e...>
    > > does make sense.
    > > -- Tracy
    >and
    >great
    >anyone
    >(i.e.
    > > >an invention)?
    >you
    >etc.
    >stamp
    >with
    > > >though.
    > > >Any feedback?
    > > >Mike Sokol
    > > >mikes@m...
    > > >> Dave
    > > >> > Hi Tim,
    > > >> pressure
    > > > > on
    > > >> period.
    > > >> to
    > > >> at
    > > >> a
    > > >> an
    > > >> on
    > > >> wave
    > > >> > -- best regards
    > > >> > Tracy Allen
    > > >> > mailto:tracy@e...
    > > >> > >Hey Everyone,
    > > >> with a
    > > >> precipitation this
    > > >> water level
    > > >> know if
    > > >> rise first.
    > > >> like to have
    > > >> capacitive
    > > >> length or
    > > >> ultrasonic ranger
    > > >> surface,
    > > >> well in
    > > >> last for
    > > >> > >Thanks,
    > > >> > >Tim
    > > >> > >Timothy Medema
    >and
    Mike,
    That well is a pretty large pipe! I think the physics are sound and
    maybe practical too but you may be needing a pretty low frequency
    speaker - maybe a super subwoofer?
    Since you admitted to being a sound guy, what is the resonant
    frequency of the well as a pipe? Also what would be the resonant
    frequency of a smaller sensing pipe that could be placed into the
    well. Maybe a 2" X 18' PVC piece?
    Maybe another solution could be a combination of the SONAR approach
    but using tone bursts with audible frequencies and outdoor speakers
    rather than ultrasonics. At 1.77ms/ft (for dry air! Probably needs
    corrected for humidity of the well.) the round trip delay would be
    about 32 ms for 18 ft. Some resolution would be lost at the lower
    frequencies but to shower or not probably doesn't depend on +-
    0.001" of water in the well.
    If there is a lot of noise in the well already from a stream or
    whatever, maybe the system could "listen" for the frequency with the
    largest amplitude? that goes back to the organ pipe idea but using
    the white noise from the stream to excite it.
    Harry
    Stamp Robotics to the next level
    www.bluebelldesign.com
    --- In basicstamps@yahoogroups.com, "Mike Sokol - ModernRecording"
    principals, and
    are
    hardware
    be a great
    Has anyone
    idea (i.e.
    > an invention)?
    <snip...>
    > Any feedback?
    > Mike Sokol
    > mikes@m...
    Original Messages cut
