Easy A/D converters?
Hello!
What are some A/D converters that can be easily connected to the basic
stamp? I'm quite new with the basic stamp. In fact, I hadn't
realized that it didn't have built in A/D converters, as does the
OOPic. However, I'm willing to put in the extra work because my
initial tests with the basic stamp have been super and I love the
editor.
I'm looking for a very basic 8-bit A/D converter that doesn't need a
lot of external components. I need, um, I think it's called "4
channel"... One that can measure 4 analog signals.
Thanks a ton!
- Bret
editor.
Thanks a ton!
- Bret
clone45@h... writes:
Hello!
editor.
Thanks a ton!
- Bret
Go to www.maxim-ic.com
There are literally hundreds of choices. Welcome to the stamp. Probably the
easiest uP on the planet to use.
The TLC2543 12-bit 11-channel is very easy to use. Surprisingly, you will
find that it is probably a lot cheaper than a 4-channel. Takes 4 pins - channel
select, datain, dataout and clock.
Sid Weaver
W4EKQ
Port Richey, FL
Maxim. Is there one that you've used before that you could recommend?
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 8/23/2003 4:16:21 PM Pacific Daylight Time,
> Hello!
basic
> editor.
> Thanks a ton!
> - Bret
Probably the
previous post. I'll check out the data sheet tonight!
Cheers!
- Bret
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> In a message dated 8/23/2003 7:16:20 PM Eastern Standard Time,
a
you will
pins - channel
> Sid Weaver
> W4EKQ
> Port Richey, FL
>Hello!
>editor.
>Thanks a ton!
>- Bret
Hi Bret -
Here is a relatively simple 4-channel ADC from National which you should be
able source quite easily:
http://www.national.com/pf/AD/ADC0834.html
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Hello!
basic
> editor.
a
> Thanks a ton!
> - Bret
Hi Bret,
the TLC chip is a good bet as it is 11 channel and will offer all
your ADC inputs needs and offer the excess pins as digital inputs if
you want.
Also, there are quite a few sites (Like Tracey's OWL site) that offer
simple explanations of how to connect it and how to address it in
software. That particular chip has a lot of people on here to help
if you need it.
Dave
our web site.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: c45a6 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LMA1CmLAxheh4K-0piUqRx4v1xP7slMzwclJqoOdX2RVqc6Fn5ix8KrmsBmMgoolVTQAiJQioLzZECI]clone45@h...[/url
Sent: Saturday, August 23, 2003 6:14 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Easy A/D converters?
Hello!
editor.
Thanks a ton!
- Bret
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
On Sat, 23 Aug 2003 18:20:06 -0700 "Jon Williams"
<jwilliams@p...> writes:
> The ADC0831 will get you going and you can find lots of ready-to-run
> on our web site.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: c45a6 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J8p3ucTVCq8UyTChkfcrbE-UYRQn4UZVMjs1ebthu1UCec5HAoR2NZg0KRB6Q9Nd18Ir8Ee7_k-XUxw]clone45@h...[/url
> Hello!
> basic stamp? I'm quite new with the basic stamp. In fact, I hadn't
> editor.
> Thanks a ton!
> - Bret
________________________________________________________________
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
Only $14.95/ month - visit www.juno.com to sign up today!
use the SHIFTIN/SHIFOUT cmds to interface).
Parallax (and many others) sells the
Maxim ADC0831 chip (single channel) (8-pins).
They have interfacing instructions in their
"Analog and Digital" course (download the manual).
Having started using the BS2 in Jan '03, I
sympathize with the huge amount of possible chips
to be used, and the desire just to have one or two
to begin with.
--- In basicstamps@yahoogroups.com, "c45a6" <clone45@h...> wrote:
> I'm a little overwhelmed by the number of A/D converters offered by
recommend?
> > Hello!
> basic
> > editor.
need a
> > Thanks a ton!
> > - Bret
> Probably the
