"No Basic Stamp Found" error
Received my BS2 starter kit. Want to use my Toshiba Tecra notebook
with the editor. Loaded Windows software and Got the error "No Basic
Stamp Found." Not getting an "Echo" on COM 1. Then tried it on my
desktop...works great.
Any ideas what may be wrong? Both computers running Win. 98. I tried
both the v.1.3 and the Beta versions of the Editor. Yes, this is my
first time working with micro-controllers.
Jake
Jake
I don't think its you. It might be your notbook's setings. In the device manager
check to see if your ir port is inabled. If it is disable your irport and
reinable your serial port. But if this dosn't work for you, you may need a usb
to serial adaptor from parallex. I hope this works for you ( at least it did
for me).
Walt
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
With Toshiba notebooks, it is usually the FIFO buffers. Turn them off, and
it will (hopefully) work.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, August 14, 2003 12:27 AM
Subject: [noparse][[/noparse]basicstamps] "No Basic Stamp Found" error
> Jake
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
another device to make sure that it is working. Once you get it working
with say, an external modem, then "do" Start Menu, Control Panel,
System, Device Manager, expand "Ports", select "Com1", click
"Properties", then "Port Settings" then click Advanced. After
navigating this rabbit warren, you should now have a window open with
"Advanced Port Settings" with two sliders for "receive buffer" and
"Transmit buffer". Slide them all the way to the left (Low(1)) setting.
Click "OK". and back out of the Microsoft maze by clicking "OK" each
window that has that option. You should now be able to successfully
identify and communicate with the stamp.
> Jake
> from the same email address that you subscribed. Text in the Subject and Body
I also had the same problem with my Toshiba Tecra 8100 running windows 2000
Pro. The solution is very easy. Go to your device manager in windows,
select ports then click on com ports, click on your com port (com-1, com-2
etc) click the "port" settings tab, then the "advanced" button and disable
FIFO.
That cured my problem and I am pretty sure it will take care of yours as
well.
Al Sines, W3AL
Original Message
Sent: Thursday, August 14, 2003 3:27 AM
> Jake
Stache using a home-built PC. For some reason, the tx line from the
PC was resting at a high +12 volt level, instead of the usual -12
volts, due to some unusual BIOS or hardware thing. This would cause
programming to fail. The resolution was to open a debug window on
that programming port, and then the port would go properly to -12
volts and the RUN command (F9) would work. I later found out from
Parallax tech support that they had seen a similar issue in
programming Stamps on a very few laptop computers, resolved with the
same workaround.
-- Tracy
>You are having the same problem that I did. Test your serial port with
>> Jake
>>Subject and Body of the message will be ignored.
the application Hotsync running. Hotsync is a program
that will download information into my palm pilot through
a serial port. Although, I had the palm cradle detached
from the pc, the software still held that serial port.
You might check that you don't have any of these types of
applications running.
On Thu, 14 Aug 2003 14:57:41 -0400
"Al Sines" <sasines@c...> wrote:
>Jake:
>manager in windows,
>port (com-1, com-2
>button and disable
>FIFO.
>care of yours as
>well.
>Al Sines, W3AL
Original Message
>From: "Jake" <n0lx@a...>
>>Tecra notebook
>>error "No Basic
>>it on my
>>98. I tried
>>this is my
>> Jake
>>in the Subject and
>the Subject and Body of the message will be ignored.
<TEXTAREA NAME="Signature" ROWS="4" COLS="60"><TEXTAREA
nots from readers.
stick it in the files section.
with
working
with
setting.
each
successfully
notebook
Basic
tried
my
> > Jake
