PCB Boards - roll your own
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 7/20/2003 4:53:24 PM Pacific Daylight Time,
> chapman@t... writes:
> > Is that quote from futurlec, $20 in Australian or U S dollars?
> Don't know.....I went to the web sight, entered options for a
double sided no
> silk-screen or soldermask 3.25 by 2.5 inch pcb.......quantity 3.
Nor did I
> look into how long to receive the boards
> The same options from <A
HREF="www.expresspcb.com">www.expresspcb.com</A> (qty 3.....3.8 by
2.5 inches) and
> other options same as above is about $66 US dollars (including
shipping) and the
> boards are at your door in three business days.
> I have been extremely satisfied with the service. The PCB layout
software is
> free and extremely easy to use.
> [noparse][[/noparse]Non-text portions of this message have been removed]
Many of us make one's and twos from scratch.
there is a laser transfer method that works for large traces and not
routes between IC pads, one sided is pretty easy.
practice makes perfect, and Radio shack sells the chemicals.
if you have more time than money, not a bad idea.
if you need complicated boards, look at a board house.
http://groups.yahoo.com/group/Homebrew_PCBs/
is a group that has a vast resource both in the group posts and also
the files section.
Dave
double sided no
Nor did I
2.5 inches) and
shipping) and the
software is
the files section.
Dave
Also, I don't know how big a secret this is, but my next book is:
http://tinyurl.com/hisc
Not out yet. It contains a copy of Eagle, and details on using Eagle,
building your own (laser and photolithography), and sending out boards
to a service bureau, among other things.
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
