PaintBall Stamp
Hey everyone,
I'm working on a project that counts how many shots from my paintball
gun are fired
and then displays them on four 7seg leds displays through a max 7219. I
have everything
wired up, but when I flip the switch I get a blip from the screen
usually a 5 and then nothing.
So I simplified it to one screen and a starter program which is "Using
the Max7219 display
Driver" from Parallax. I followed all the instructions except for
installing capacitors because
I'm running straight from the pwr supply which is in operational
voltages. If you could please
help I'd greatly appreciate it.
-Mike
gun are fired
have everything
the Max7219 display
-Mike
decoding, I got a pattern of leds on the display to light up? Does
anyone know what this means?
-Mike
Original Message
From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rx31u5hnKOdgAY-hIq_62UIiXnKuuAtZnvHKgRTNNzqqPuBi_QSD09T7nwwoL95rt4BMfgoc4MmTNSoljGl5cw]laxboy687@e...[/url
Sent: Friday, July 18, 2003 7:05 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PaintBall Stamp
Hey everyone,
gun are fired
have everything
the Max7219 display
-Mike
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
shift register) without problems. I think my driver chip is slightly
different than yours, though.
In the code below, simply set LED_DigitToChange to 0-7 to pick which digit
to change, and LED_DigitValue to 0-$F, then GOSUB LED_SetDigit.
I have Q0 through Q7 of the shift register going to D0 to D7 of the MAX7218
if I remember right. I have Q8 going to the MODE input of the MAX7218 as
well to save a stamp pin.
Here's the applicable code to update a digit:
LED_DigitToChange VAR Nib ' What digit to change
LED_DigitValue VAR Byte ' What to set it to
LED_WritePin PIN 12 ' Causes inputs on MAX7218 to get latched in
SP_SIPin PIN 0 ' Serial data input pin on 74F675
SP_StorePin PIN 1 ' Latches shift register into parallel out
register on 74F675
SP_ShiftPin PIN 2 ' Shifts one bit into shift register from
SP_SIPin
LED_SetDigit:
' Send command byte
LOW SP_StorePin
SHIFTOUT SP_SIPin, SP_ShiftPin, MSBFIRST, [noparse][[/noparse]%101011\6, LED_DigitToChange\3]
HIGH SP_StorePin
LOW LED_WritePin
HIGH LED_WritePin
' Send digit
LOW SP_StorePin
SHIFTOUT SP_SIPin, SP_ShiftPin, MSBFIRST, [noparse][[/noparse]%01\1, %000\3,
LED_DigitValue\4]
HIGH SP_StorePin
LOW LED_WritePin
HIGH LED_WritePin
RETURN
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, July 19, 2003 2:05 AM
> Hey everyone,
> gun are fired
> have everything
> the Max7219 display
> Thanks
> -Mike
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
doesn't show one.
Original Message
From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xrq5KTQwIIsESe1zlECzFs_F1RSY5mrRgUEty1N_sQvf_3Mc8R4cwfnbsJFmk9tE-doRivVFBZrvzeM0Vg]zman97211@y...[/url
Sent: Saturday, July 19, 2003 6:16 AM
Subject: Re: [noparse][[/noparse]basicstamps] PaintBall Stamp
I interface to 6 digits using a MAX7218 via a 74F675 (Serial in/Parallel
out
digit
MAX7218
register on 74F675
SP_SIPin
LED_SetDigit:
' Send command byte
LOW SP_StorePin
HIGH SP_StorePin
LOW LED_WritePin
HIGH LED_WritePin
' Send digit
LOW SP_StorePin
LED_DigitValue\4]
HIGH SP_StorePin
LOW LED_WritePin
HIGH LED_WritePin
RETURN
Original Message
> Hey everyone,
> gun are fired
I
> have everything
> the Max7219 display
> Thanks
> -Mike
and
BS2 interfacing to the driver chip directly, but this used something like 10
pins on the stamp. The driver IC has a MODE pin, a WRITE pin, and eight data
pins (at least on my MAX7218). I needed to set each of the data pins (either
called D0-D7 for loading a digit, or other names when sending a command
byte) and the mode pin, then toggle the WRITE pin to latch the data into the
driver. After I got it working, I put in the shift register, connected 9 of
the output from the register to 9 of the pins on the MAX7218. Now, all I
need to do is shift 9 bytes into the register and latch the serial data to
the parallel outputs, then latch thos into the driver, using 6 less pins
that originally needed (10).
Steve
Original Message
Sent: Saturday, July 19, 2003 1:29 PM
Subject: RE: [noparse][[/noparse]basicstamps] PaintBall Stamp
> Thanks for the reply, do I need a shift register? On the code I have it
> doesn't show one.
Original Message
> From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Yr384zCoky19uSYhd1oBR4KxtPZuilb8ni1diU8rpcUOxq8gr-_oRKJlGI0MzOnQb9rUBBzXqtZTk10]zman97211@y...[/url
> out
> digit
> MAX7218
> register on 74F675
> SP_SIPin
> LED_SetDigit:
> ' Send command byte
> LOW SP_StorePin
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
> ' Send digit
> LOW SP_StorePin
> LED_DigitValue\4]
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
> RETURN
Original Message
> From: "Mike Dillon" <laxboy687@e...>
> > Hey everyone,
> > gun are fired
> I
> > have everything
> > the Max7219 display
> > Thanks
> > -Mike
> and
7218 drives common anode displays
and the 7219 doesn't require a 74F675 (the 7218 does)...the application
from parallax should work fine if everything is wired up properly
good luck
guy
>doesn't show one.
Original Message
>From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6pt_WnQkvg4BeNZJCX-3CCpD2tYK8KzML7j0OaAX22yirRMg3ldJl3txz4yMb-KKTyR4XiUpLIcXbElLHSA]zman97211@y...[/url
>out
>digit
>MAX7218
>register on 74F675
>SP_SIPin
>LED_SetDigit:
> ' Send command byte
> LOW SP_StorePin
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
> ' Send digit
> LOW SP_StorePin
>LED_DigitValue\4]
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
>RETURN
Original Message
> > Hey everyone,
> > gun are fired
>I
> > have everything
> > the Max7219 display
> > Thanks
> > -Mike
>and
program, so I downloaded the docs and wrote my own code which was a lot
simpler than I thought to be. The display works fine and it records the
button presses as it should BUT when I pull the trigger on the gun the
recoil resets my stamp and display. Right now I'm checking for a loose
wire or something like that but I'm wondering can the stamp take a big
shock without reseting?
Thanks again guys.
-Mike
Original Message
From: Guy De Bievre [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CLSEnNkritOe2m32oQiUXKa7kDVZQLWKV4JzR8vD0KmuTI4ldYxsyxm_M_ke4ZXxyhg0bQ]guydb@t...[/url
Sent: Sunday, July 20, 2003 3:25 PM
7219 drives common cathode displays
good luck
guy
>doesn't show one.
Original Message
>From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Gu1SgwR6nCDS14RY1pT709rjBwQ2yhdDLMFcoB8yR4W5XuMMBfVrZBtq4a1K6Scb3rAU_y2-isLAU7nIXg]zman97211@y...[/url
in/Parallel
>out
>digit
>MAX7218
as
>register on 74F675
>SP_SIPin
>LED_SetDigit:
> ' Send command byte
> LOW SP_StorePin
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
> ' Send digit
> LOW SP_StorePin
>LED_DigitValue\4]
> HIGH SP_StorePin
> LOW LED_WritePin
> HIGH LED_WritePin
>RETURN
Original Message
> > Hey everyone,
paintball
> > gun are fired
7219.
>I
> > have everything
"Using
> > the Max7219 display
> > Thanks
> > -Mike
Subject
>and
and
