PaintBall Stamp — Parallax Forums
PaintBall Stamp
edited 2003-07-20 23:31 in General Discussion
Hey everyone,
I'm working on a project that counts how many shots from my paintball
gun are fired
and then displays them on four 7seg leds displays through a max 7219. I
have everything
wired up, but when I flip the switch I get a blip from the screen
usually a 5 and then nothing.
So I simplified it to one screen and a starter program which is "Using
the Max7219 display
Driver" from Parallax. I followed all the instructions except for
installing capacitors because
I'm running straight from the pwr supply which is in operational
voltages. If you could please
help I'd greatly appreciate it.
-Mike
    edited 2003-07-19 03:05
    I was trying different things to make it work, and when I turned off BCD
    decoding, I got a pattern of leds on the display to light up? Does
    anyone know what this means?
    -Mike
    From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rx31u5hnKOdgAY-hIq_62UIiXnKuuAtZnvHKgRTNNzqqPuBi_QSD09T7nwwoL95rt4BMfgoc4MmTNSoljGl5cw]laxboy687@e...[/url
    Sent: Friday, July 18, 2003 7:05 PM
    Subject: [noparse][[/noparse]basicstamps] PaintBall Stamp
    Hey everyone,
    gun are fired
    have everything
    the Max7219 display
    -Mike
    Your use of Yahoo! Groups is subject to
    edited 2003-07-19 11:15
    I interface to 6 digits using a MAX7218 via a 74F675 (Serial in/Parallel out
    shift register) without problems. I think my driver chip is slightly
    different than yours, though.
    In the code below, simply set LED_DigitToChange to 0-7 to pick which digit
    to change, and LED_DigitValue to 0-$F, then GOSUB LED_SetDigit.
    I have Q0 through Q7 of the shift register going to D0 to D7 of the MAX7218
    if I remember right. I have Q8 going to the MODE input of the MAX7218 as
    well to save a stamp pin.
    Here's the applicable code to update a digit:
    LED_DigitToChange VAR Nib ' What digit to change
    LED_DigitValue VAR Byte ' What to set it to
    LED_WritePin PIN 12 ' Causes inputs on MAX7218 to get latched in
    SP_SIPin PIN 0 ' Serial data input pin on 74F675
    SP_StorePin PIN 1 ' Latches shift register into parallel out
    register on 74F675
    SP_ShiftPin PIN 2 ' Shifts one bit into shift register from
    SP_SIPin
    LED_SetDigit:
    ' Send command byte
    LOW SP_StorePin
    SHIFTOUT SP_SIPin, SP_ShiftPin, MSBFIRST, [noparse][[/noparse]%101011\6, LED_DigitToChange\3]
    HIGH SP_StorePin
    LOW LED_WritePin
    HIGH LED_WritePin
    ' Send digit
    LOW SP_StorePin
    SHIFTOUT SP_SIPin, SP_ShiftPin, MSBFIRST, [noparse][[/noparse]%01\1, %000\3,
    LED_DigitValue\4]
    HIGH SP_StorePin
    LOW LED_WritePin
    HIGH LED_WritePin
    RETURN
    Sent: Saturday, July 19, 2003 2:05 AM
    > Hey everyone,
    > gun are fired
    > have everything
    > the Max7219 display
    > Thanks
    > -Mike
    edited 2003-07-19 12:29
    Thanks for the reply, do I need a shift register? On the code I have it
    doesn't show one.
    From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xrq5KTQwIIsESe1zlECzFs_F1RSY5mrRgUEty1N_sQvf_3Mc8R4cwfnbsJFmk9tE-doRivVFBZrvzeM0Vg]zman97211@y...[/url
    Sent: Saturday, July 19, 2003 6:16 AM
    Subject: Re: [noparse][[/noparse]basicstamps] PaintBall Stamp
    out
    digit
    MAX7218
    register on 74F675
    SP_SIPin
    LED_SetDigit:
    ' Send command byte
    LOW SP_StorePin
    HIGH SP_StorePin
    LOW LED_WritePin
    HIGH LED_WritePin
    ' Send digit
    LOW SP_StorePin
    LED_DigitValue\4]
    HIGH SP_StorePin
    LOW LED_WritePin
    HIGH LED_WritePin
    RETURN
    > Hey everyone,
    > gun are fired
    I
    > have everything
    > the Max7219 display
    > Thanks
    > -Mike
    and
    edited 2003-07-19 12:56
    When I originally got the display and the driver IC to work using only the
    BS2 interfacing to the driver chip directly, but this used something like 10
    pins on the stamp. The driver IC has a MODE pin, a WRITE pin, and eight data
    pins (at least on my MAX7218). I needed to set each of the data pins (either
    called D0-D7 for loading a digit, or other names when sending a command
    byte) and the mode pin, then toggle the WRITE pin to latch the data into the
    driver. After I got it working, I put in the shift register, connected 9 of
    the output from the register to 9 of the pins on the MAX7218. Now, all I
    need to do is shift 9 bytes into the register and latch the serial data to
    the parallel outputs, then latch thos into the driver, using 6 less pins
    that originally needed (10).
    Steve
    Sent: Saturday, July 19, 2003 1:29 PM
    Subject: RE: [noparse][[/noparse]basicstamps] PaintBall Stamp
    > doesn't show one.
    > From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Yr384zCoky19uSYhd1oBR4KxtPZuilb8ni1diU8rpcUOxq8gr-_oRKJlGI0MzOnQb9rUBBzXqtZTk10]zman97211@y...[/url
    > out
    > digit
    > MAX7218
    > register on 74F675
    > SP_SIPin
    > LED_SetDigit:
    > ' Send command byte
    > LOW SP_StorePin
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    > ' Send digit
    > LOW SP_StorePin
    > LED_DigitValue\4]
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    > RETURN
    > From: "Mike Dillon" <laxboy687@e...>
    > > Hey everyone,
    > > gun are fired
    > I
    > > have everything
    > > the Max7219 display
    > > Thanks
    > > -Mike
    > and
    edited 2003-07-20 21:24
    7219 drives common cathode displays
    7218 drives common anode displays
    and the 7219 doesn't require a 74F675 (the 7218 does)...the application
    from parallax should work fine if everything is wired up properly
    good luck
    guy
    >doesn't show one.
    >From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6pt_WnQkvg4BeNZJCX-3CCpD2tYK8KzML7j0OaAX22yirRMg3ldJl3txz4yMb-KKTyR4XiUpLIcXbElLHSA]zman97211@y...[/url
    >out
    >digit
    >MAX7218
    >register on 74F675
    >SP_SIPin
    >LED_SetDigit:
    > ' Send command byte
    > LOW SP_StorePin
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    > ' Send digit
    > LOW SP_StorePin
    >LED_DigitValue\4]
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    >RETURN
    > > Hey everyone,
    > > gun are fired
    >I
    > > have everything
    > > the Max7219 display
    > > Thanks
    > > -Mike
    >and
    Thanks guys for the info, I don't know what the problem was with that
    program, so I downloaded the docs and wrote my own code which was a lot
    simpler than I thought to be. The display works fine and it records the
    button presses as it should BUT when I pull the trigger on the gun the
    recoil resets my stamp and display. Right now I'm checking for a loose
    wire or something like that but I'm wondering can the stamp take a big
    shock without reseting?
    Thanks again guys.
    -Mike
    From: Guy De Bievre [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CLSEnNkritOe2m32oQiUXKa7kDVZQLWKV4JzR8vD0KmuTI4ldYxsyxm_M_ke4ZXxyhg0bQ]guydb@t...[/url
    Sent: Sunday, July 20, 2003 3:25 PM
    good luck
    guy
    >doesn't show one.
    >From: Steve Ziuchkovski [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Gu1SgwR6nCDS14RY1pT709rjBwQ2yhdDLMFcoB8yR4W5XuMMBfVrZBtq4a1K6Scb3rAU_y2-isLAU7nIXg]zman97211@y...[/url
    in/Parallel
    >out
    >digit
    >MAX7218
    as
    >register on 74F675
    >SP_SIPin
    >LED_SetDigit:
    > ' Send command byte
    > LOW SP_StorePin
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    > ' Send digit
    > LOW SP_StorePin
    >LED_DigitValue\4]
    > HIGH SP_StorePin
    > LOW LED_WritePin
    > HIGH LED_WritePin
    >RETURN
    > > Hey everyone,
    paintball
    > > gun are fired
    7219.
    >I
    > > have everything
    "Using
    > > the Max7219 display
    > > Thanks
    > > -Mike
    Subject
    >and
    and
