why does it keep burning?
I have a basic stamp 1 controlling a tip 122,127 bridge and a motor
thru opto couplers, the thing is when using one power supply it runs
ok, when using another power supply with the same voltage specs the
basic stamp burns out very fast.
could it be motor spikes?
Thank's
Fogassa
Thank's
Fogassa
wall-wart. It is quite possible for two
wall-warts rated at 12 volts DC 100 mA
to in fact vary in terms of ripple, and
vary in terms of open-circuit voltage.
In addition, insure that the two plugs
are wired identically. The 'center'
conductor MUST be positive.
I would not depend on the BS1's linear
regulator -- I'd tend to put my own
linear regulator (7805) on-board to
insure there's enough current for both
the BS1 and the motors.
motor
runs
> Thank's
> Fogassa
one supply has voltage that is too high for the stamp.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: afogassa [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4kPYNjMFe-lO2QzBNEzjNsbnr9EpwQVrh57mTGh5wQGnUhu874f8A_CDn_sAdsOFld3hnVjc_nGjbuhbRw]afogassa@y...[/url
Sent: Sunday, July 20, 2003 12:05 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] why does it keep burning?
Thank's
Fogassa
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
wires to the output wires. If you do not, the the power supply will go
well over the Voltage desired. For example, I would expect a 5 Volt
power supply to easily goto 8 Volts. And a 12 Volt supply to as much as
17. Depends upon many factors as to how high it will go<G>.
Original Message
From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GeRqc0ixbB-ij1_0-qKSlnLRXDOYqqCtJMStZ2wNfmodRqRtTfdnKTogACmwrN0bWBL-gv4jho5hIg]jjf@p...[/url
Sent: Tuesday, July 22, 2003 10:25 AM
Subject: RE: [noparse][[/noparse]basicstamps] why does it keep burning?
forget about specs on the supplies. What do you measure? I suspect
that one supply has voltage that is too high for the stamp. jim
Original Message
From: afogassa [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KA5wkG_qwFl9WMPG2VkitCgdxctn_P6dWYwcXa9T6biDjYNMPswqzthASi1F7qzE67R84kBoxCFMM_M57A]afogassa@y...[/url
basic stamp burns out very fast. could it be motor spikes?
Thank's
Fogassa
and Body of the message will be ignored.
