Help
Can some one explain to me the math on
page 21 and 24 on how thay came up with
1.5ms this is book Robotics v1.4 Student work book
I`ve tried to do it by calc and long form and as written
but to any event have not come up with the
answer.
just like page 48 #3 wants to know
What is the nessary PULSOUT duration argument
to make a 1.626 ms pulse?
I`m unable to answer it till I see
how the first is answered.
Thanks for your time
Jeff Jensen
answer.
Jeff Jensen
Does any body have interface GP2D02 to stamp1? or does any body can tell me
where to find more details and pograms for BS1 interfacing to GP2D02 ?
Thanks in advance for help.
Thanks & Regards
Kolitha
4800 baud, 8N1, over a serial line, 0 to +4.5 volts (not the RS232
standard +/- 12). The strings all start with "$", are about 45 chars
long, and are terminated with a CR,LF pair. I can grab these strings
and display them on my PC using a standard terminal program and a
normal serial port (COM2). Everything works fine using the PC. The
strings display correctly, and contain only normal ascii characters,
always less than < dec 128 bytes, as they should be.
However, I can't grab these bytes using my BS2X and the program code
below. I thought it should have been pretty easy, since it looks
like electrically the signal is just standard TTL logic signals,
which I presume can be directly input to a BS2X input pin, using
the "non-inverted/direct connection" baud mode value. The + signal
line from the gauge is connected to pin 0 thru a 22K resistor; the
ground signal line is connected to Vss.
The code is only test code, and I am only trying to grab any old 10
bytes that come in. Characters are, in fact, grabbed and displayed
but none of them are what they should be, and in fact are often ascii
extended characters. It never seems to get 10 chars either,
typically only about 6.
I also tried the other 3 baud mode values for 4800 baud, including
the non-inverted ones. Results were much the same, same characters
displayed except that now typically only 1 or 2 each time, instead of
6 or so.
If anyone can help me out with this I will greatly appreciate it.
Thanks.
CPpin CON 0 ' Serial in connected to pin 0
CPbaudcode CON 16572 ' 4800 baud, 8N1, inverted/direct
CPtimout CON 2000 ' Max time to wait for data (ms)
CPstr VAR BYTE(11) ' 10 chars + terminating null
OUTS = %0000000000000000
DIRS = %0000000000000000
CPstr(10) = 0 ' Null-terminate string
GetChars:
SERIN CPpin, CPbaudcode, CPtimout, Timout, [noparse][[/noparse]STR CPstr\10]
DEBUG HOME, STR CPstr
PAUSE 500 ' Wait 1/2 second
GOTO GetChars
Timout:
DEBUG "No activity on pin 0. Program terminated."
END
>I have a gauge that sends out ascii data strings once a second at
>6 or so.
>Thanks.
Try 16884 for the baudemode. This is the appropriate baudemode for the BS-2SX.
The baudmode you are using is for the BS-2 Stamp.
Bruce
road race car that will be used in the Mini-Baja Competition for the
Society for Automotive Engineers. THere will be 3 digital inputs
(Engine RPM, Transmission Shaft Speed, Rear axle speed) : one pulsing
about 18000x/sec max and the other two at speeds equivalent to 1/2-
1/3 of that. Addtionally a fuel level sensor will output a 0-5V
signal to the controller. These signals will be used to calculate
vehicle speed, Transmission ratio (acutally CVT ratio), Engine RPM,
and Fuel level so that they can be displayed using LED displays or
the like. My question is what stamp would be useful and fast enough
to do all this. I think display of the parameters is to be simple
LED bar graph type for fuel level and RPM.
I know all of the info isn't there, but if anyone needs any other
info pls let me know.. I haven't done this before so I cuold use all
the help I can get. (It is for a school project).
THanks,
J.
high for anything youve mentioned in the email, a stamp might handle it but
a pic 16f87x surley would.
let me know i can help.
normdoty@h...
>From: "jay_mann2000" <jay_mann2000@y...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] Help
>Date: Tue, 26 Feb 2002 18:02:15 -0000
>I am currently designing a dashboard system for a single-seat off-
>THanks,
>J.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
Chat with friends online, try MSN Messenger: http://messenger.msn.com
I have a problem
I have 2 computers, one laptop Epson 486/50Mhz, whit Dos 6.2 , and one Desk
Celeron 466Mhz whit Win98SE.
Well in the laptop the BS1 run ok, but in the desk, do not run ; if i put in Dos
mode, Dos prompt , or in the windows explorer, it give-me one message EEPROM
VERIFY FAILURE.
Can you help-me ?
Much Obliged
Wagner
Brazil
answer.
I am a new user of basic stamp. Having some problems with the communication
in my first steps in BS2.
I am using SERIN and SEROUT command both through the debug communication
port (Rx=Tx=16).
While Running my application in the BS2 environment everything works well-
transmitting and receiving.
Doing the thing through the hyper terminal is making problems. I receive
well but the transition of character is not working properly.
Do I have to use other digital ports (P0, P1 Etc..) and not the debug one
(16) in order to communicate through the debug port when I am not working
through the BS2 editor ?
Thank You
My Home Telephone Number is: +972-3-6021184
My Fax Number is: +972-9-9587360
My Home Telephone Number is: +972-56-546756
Azriel Roy
built-in level-shifter on the BS2 programming port "borrows" power from
the serial connection and in the process causes anything sent to the BS2
to be echoed back. The Stamp Editor terminal knows how to deal with
this. I haven't worked with HyperTerminal in quite a while, but I
believe you can turn off the local character display. That way, when
you enter a character in HT, what you'll actually get onscreen is the
echoed character from the Stamp. That said, you will always see
something -- there's no way to use a generic terminal with the Stamp's
programming port an not see at least one character.
-- Jon Williams
-- Parallax
Original Message
From: Roy Azriel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=A-q0YVx4ZTyuZaBvtH517eCG2zH2G3d650ArC_C0ja__L3y_rWlufIOSWq-TCgsLqXIkOG7UuglrKvmN]royaz@z...[/url
Sent: Sunday, July 20, 2003 12:52 AM
Hello,
communication in my first steps in BS2. I am using SERIN and SEROUT
command both through the debug communication port (Rx=Tx=16). While
transmitting and receiving. Doing the thing through the hyper terminal
is making problems. I receive well but the transition of character is
not working properly. Do I have to use other digital ports (P0, P1
working through the BS2 editor ?
Thank You
Azriel Roy
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
is used by the BS2 as a 'reset'. Holding it
active will hold the BS2 in reset.
You can put a switch on pin-4. Open lets
hyperterm talk to the BS2. Closed lets
the PC program the BS2.
The board of education (BOE) has a capacitor on
it which should only allow one reset when you
first connect Hyperterm.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> The reason you're having problems with HyperTerminal is that the
from
the BS2
when
the
Stamp's
> -- Jon Williams
> -- Parallax
Original Message
> From: Roy Azriel [noparse][[/noparse]mailto:royaz@z...]
> Hello,
terminal
is
> Thank You
> Azriel Roy
Subject
> abuse@p...
Actually I already over come this problem by writing somthing in VB. I am
still having problems receiving what is expected, I am getting charecters
that have not been sent.
My application is supposed to connect to motorola modem called io1000 I
still can not establish connection between the BS2 abd the modem.
Now I suppose the problem is that I have to put a converter from TTL level
to standad serial values, am I write ?
Original Message
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AzX-0AcuczAh-mNBHGwoDSx1VLkLn-qsNvgZPfcMJUaKZKc9fFUw5a03-6zMvp0CLb8rx1unlykcxU0YAGs]jwilliams@p...[/url
Sent: Sunday, July 20, 2003 5:53 PM
Subject: RE: [noparse][[/noparse]basicstamps] Help
-- Jon Williams
-- Parallax
Original Message
From: Roy Azriel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EQHQDmYgLrfx_5q2fr1Q8MHodOAYGZurQhB_fI05QDAczBmpk3e57GTHrHOWVv6eBF4HwT1zt7j1]royaz@z...[/url
Hello,
Thank You
Azriel Roy
abuse@p....
must use an 'inverting' baud rate. (84 + 16384)
2. Yes, the Max232 chip is a fairly typical
TTL to 232 and 232 to TTL chip. It takes 4
1 uF capacitors to run off 5 volts. Yes,
you'll probably need one of these to talk
to the Modem. On the other hand, the
MAX3110 is an SPI interfaced UART with a
232 drivers built in (takes a 3.686 MHz
crystal and 2 caps for an oscillator),
and it holds 8 bytes in its buffers
-- this might be a more successful
chip to talk to the modem through.
3. The BS2 is a 'single tasking' beast, so
you can talk, or listen, but you can't do
both (unless you use a UART). You can
use timeouts, or the 'FlagPin',
to reduce the amount of time the BS2 waits
around while nothing is happening.
--- In basicstamps@yahoogroups.com, "Roy Azriel" <royaz@z...> wrote:
> Thank you for your response.
VB. I am
charecters
io1000 I
TTL level
Original Message
> From: Jon Williams [noparse][[/noparse]mailto:jwilliams@p...]
from
the BS2
when
the
Stamp's
> -- Jon Williams
> -- Parallax
Original Message
> Hello,
terminal
is
> Thank You
> Azriel Roy
Subject
> abuse@p...
Subject and
I buy one cmos camera (B&W), whit two outputs; one digital, and other
analogic
Well i have the BasicStamp II, and i can one help if you have one program
to transfer the digital out to BSII
Much Obliged
W@GNER
