Initialising a Sandisk MMC memory card
The thread "BS2 to Sandisk MMC memory card" in early
2002 described a problem I have in initialising a mmc card...
1. chip select high 2. send 80 clocks 3. ..etc.
Seems quite trivial but .......
It wasn't clear whether the poster ever resolved the
problem.
Has anyone successfully managed it?
problem.
do you remember where the thread was posted?
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, July 07, 2003 12:25 AM
Subject: [noparse][[/noparse]basicstamps] Initialising a Sandisk MMC memory card
> problem.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
AND BETTER FOR OVER 50 YEARS.
WOULD NOT THE FOLLOWING DEVICE WORK WITH A MMC TO PC CARD ADAPTER.
73
SPENCE
http://www.star.net/people/~mvs/SDRVSPEC.TXT
Message: 5
Date: Mon, 07 Jul 2003 04:25:44 -0000
Subject: Initialising a Sandisk MMC memory card
problem.
Message 18213 in this forum was the query; followed
the same day by several replies.
I found them by searching for;
Jim Frazer
_____________________________________________
--- In basicstamps@yahoogroups.com, "Mike Mocenter"
<mocenter@e...> wrote:
> James,
Original Message
> From: "jamestfrazer" <jim_frazer@m...>
> > problem.
Subject and
YES IT IS EASIER TO READ.
I AM USING A MICROCONTROLLER WITH AN SPI BUS
WITH A FIFO BUFFER (msc12100) AND SO WOULD LIKE
TO WRITE TO THE SPI ON THE MMC CARD FROM THE
SPI PINS.
JIM FRAZER
_____________________________________________________
--- In basicstamps@yahoogroups.com, "BOYD S. (SPENCE) MINER"
<k4kep@b...> wrote:
> PARDON ALL CAPS. I HAVE BEEN ABLE TO READ AND TYPE ALL CAPS
MUCH EASIER
CARD ADAPTER.
> 73
> SPENCE
> Message: 5
> problem.
