sht-11/71 source?
I'm trying to find a one-off source for these humidity sensors - preferrably
in Canada though I don't have my hopes up [noparse]:D[/noparse]
I tried the parallax site. $29US each I can handle, but the $50US shipping
to Canada is out of the question.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, July 03, 2003 8:29 AM
Subject: Re: [noparse][[/noparse]basicstamps] Speaking of logging - Dataflash?
> Hi,
> I use dataflash in my loggers. I've never gotten a firm answer about
> the write cycle life (which they call "endurance"). Data
> "retention", which is how long it will hold onto a bit of information
> without refresh, is rated as 10 years. Endurance is not an issue in
> the kind of slow data logging I am doing. They do suggest refreshing
> pages that have not been used for a while, at least once every 10,000
> cycles. For example, if you store some parameters on page 0, and
> then proceed to write to other pages 10000 times, then you should
> come back and refresh page 0. This is all in their app notes and
> FAQs.
> -- Tracy
> http://www.emesystems.com/BS2flash.htm
> >Has anyone tried out the Dataflash memories from Atmel? I've been
checking
> >the datasheets etc and I can't seem to find what the write cycle life is.
> >Normal flash is usually 10k writes, anyone know what dataflash' is?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Original Message
> Hi,
> FAQs.
> -- Tracy
checking
Sensiron will send you a free sample, if you can mount it yourself. I made a
little board, really easy and works fine.
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, July 03, 2003 10:17 AM
Subject: [noparse][[/noparse]basicstamps] sht-11/71 source?
preferrably
Original Message
> From: "Tracy Allen" <tracy@e...>
> > Hi,
> > FAQs.
> > -- Tracy
> checking
is.
and
Try: http://www.phanderson.com/ordering_1.html , Mr. Anderson is
really nice and he only charges what is necessary. It only cost me
$1.50 to get a few chips sent. But thats because I live in the US.
I dont think it would cost to much more for him to ship to Canada.
The cost for the SHT71 is: $25US.
Hope this helps,
Harrison
preferrably
shipping
Original Message
> > Hi,
about
information
issue in
refreshing
10,000
> > FAQs.
> > -- Tracy
been
> checking
cycle life is.
is?
Subject and
This isn't a smart device, it's just a variable capacitor. Not nearly as
elegant as the sht-11/71
I use the 555 based circuit that's in the datasheet to get at the RH.
http://rocky.digikey.com/WebLib/Humirel/HS1101.pdf
If you order it, be sure to order the anciliary resistors for the type of 555 to
be used at the same time!
Don't forget that orders under $32.50 from Digikey have a $6.50 handling charge.
Cheers,
Dave
Original Message
> From: pm
> Sent: 03 Jul 2003 12:17:03
preferrably
Original Message
> From: "Tracy Allen"
> To:
> > Hi,
> > I use dataflash in my loggers.··I've never gotten a firm answer about
> > the write cycle life (which they call "endurance").·· Data
> > without refresh, is rated as 10 years.··Endurance is not an issue in
> > the kind of slow data logging I am doing.··They do suggest refreshing
> > cycles.··For example, if you store some parameters on page 0, and
> > come back and refresh page 0.··This is all in their app notes and
> > FAQs.
> >····-- Tracy
> >····http://www.emesystems.com/BS2flash.htm
> checking
is.
> >·· basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.··Text in the Subject
and
> ··basicstamps-unsubscribe@yahoogroups.com
> from the same email address that you subscribed.··Text in the Subject and
Original Message
on that available?
On Thursday, July 3, 2003, at 01:46 PM, Jonathan Peakall wrote:
> PM,
> made a
> Jonathan
> www.madlabs.info
Original Message
> From: "pm" <pmeloy@s...>
> preferrably
>> shipping
Original Message
>>> Hi,
>>> FAQs.
>>> -- Tracy
>> checking
>>>> life
> is.
> and
>> and
> and Body of the message will be ignored.
make traces, and etched it. Then I tinned it well, set my solder pencil
really low, and then heated the taces. I used a right angle SIP header to
connect it to the rest of the circuit. Read the app. notes for important
soldering information.
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, July 03, 2003 11:07 AM
Subject: Re: [noparse][[/noparse]basicstamps] sht-11/71 source?
> If you made a board to mount the Sensirion sensor, do you have any info
> on that available?
> > PM,
> > made a
> > Jonathan
> > www.madlabs.info
Original Message
> > preferrably
> >> shipping
Original Message
> >>> Hi,
> >>> FAQs.
> >>> -- Tracy
> >> checking
> >>>> life
> > is.
> > and
> >> and
sensor.
On Thursday, July 3, 2003, at 02:17 PM, Jonathan Peakall wrote:
> Jonathan Peakall" <jpeakall@m...>
one I preferred too! Once I find out how much he wants for shipping, I'll
give Mr. Peter an order. His just reward for being such a helpfull person [noparse]:D[/noparse]
Original Message
Sent: Thursday, July 03, 2003 10:47 AM
Subject: [noparse][[/noparse]basicstamps] Re: sht-11/71 source?
> Hello,
> Hope this helps,
> Harrison
He says that it costs $3.00 shipping for a few ounces to Canada.
That is pretty cheap.
Harrison
> Dang, didn't even notice he had those on the site. The '71 is
actually the
shipping, I'll
Original Message
> From: "harrisondp" <harrisondp@y...>
> > Hello,
me
US.
Canada.
> > Hope this helps,
> > Harrison
in a waterproof flashlight. The SHT went where the lightbulb usually does,
with a runnber boot to seal it off from the body of the flashlight. The lens
was replaced with a fine plastic mesh to keep contamination out.
Hope this is what you menat.
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, July 03, 2003 11:20 AM
> Thanks. What I was really thinking about was air circulation around the
> sensor.
eastern US an Canada, and Sensolution is it for the western half.
http://www.sensolution.com
http://www.onsetcomp.com/Products/Product_Pages/Tattletale_pages/sensi
rion.html
If Peter Anderson has it for $25, I would go for that. The single
unit price from the factory rep is $22.
I recently updated my web page at
http://www.emesystems.com/OL2sht1x.htm
to show the '71 (which really does have marvelous flow-through
characteristics), and my encapsulated (slow) version for outdoor use.
I have run across one new precaution that I have not put on the web
page yet. Sensirion has just added this item to their FAQ and it is
not shown in their data sheet or app note. The clock line has to be
at a solid low level when the chip powers up, or else there is a
chance that it will enter a bad locked up state. For example, if you
have the SHTxx powered by the 5 volt Vdd of a Stamp, and have the
data line to a stamp pin with pullup and the clock line to a stamp
pin straight, then the clock line will come up floating when you
power up the stamp, and there is a chance that it will enter this
locked up state. The solution is to add a pulldown (not up!)
resistor to the SHTxx clock line, so that it will always start low.
Or, power the SHTxx from a Stamp pin, and make the clock pin low
before bringing the power high. The power for the SHTxx has to come
up clean and relatively fast.
I have hundreds of these out in the field now, connected as shown in
the data sheet without the pulldown resistor, and most of them have
worked without a hitch. The kicker is the 3 or 4 that have had
trouble and led to an exchange of email with Sensirion. That is
engineering for you.
-- best regards
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
>I made mine to look like the mounted version sold by sensiron. I mounted it
>Jonathan
>www.madlabs.info
Original Message
>From: "Mark Marpet" <marpetm@s...>
>> sensor.
>Subject and Body of the message will be ignored.
> mounted it
> does,
> The lens
> Jonathan
> www.madlabs.info
Original Message
>> the
>> sensor.
>> and
