sht-11/71 source? — Parallax Forums
sht-11/71 source?
edited 2003-07-04 01:09 in General Discussion
I'm trying to find a one-off source for these humidity sensors - preferrably
in Canada though I don't have my hopes up [noparse]:D[/noparse]
I tried the parallax site. $29US each I can handle, but the $50US shipping
to Canada is out of the question.
Sent: Thursday, July 03, 2003 8:29 AM
Subject: Re: [noparse][[/noparse]basicstamps] Speaking of logging - Dataflash?
> Hi,
> I use dataflash in my loggers. I've never gotten a firm answer about
> the write cycle life (which they call "endurance"). Data
> "retention", which is how long it will hold onto a bit of information
> without refresh, is rated as 10 years. Endurance is not an issue in
> the kind of slow data logging I am doing. They do suggest refreshing
> pages that have not been used for a while, at least once every 10,000
> cycles. For example, if you store some parameters on page 0, and
> then proceed to write to other pages 10000 times, then you should
> come back and refresh page 0. This is all in their app notes and
> FAQs.
> -- Tracy
> http://www.emesystems.com/BS2flash.htm
> >Has anyone tried out the Dataflash memories from Atmel? I've been
checking
> >the datasheets etc and I can't seem to find what the write cycle life is.
> >Normal flash is usually 10k writes, anyone know what dataflash' is?
    edited 2003-07-03 18:46
    PM,
    Sensiron will send you a free sample, if you can mount it yourself. I made a
    little board, really easy and works fine.
    Jonathan
    www.madlabs.info
    Sent: Thursday, July 03, 2003 10:17 AM
    Subject: [noparse][[/noparse]basicstamps] sht-11/71 source?
    preferrably
    > From: "Tracy Allen" <tracy@e...>
    > > Hi,
    > > FAQs.
    > > -- Tracy
    > checking
    is.
    and
    edited 2003-07-03 18:47
    Hello,
    Try: http://www.phanderson.com/ordering_1.html , Mr. Anderson is
    really nice and he only charges what is necessary. It only cost me
    $1.50 to get a few chips sent. But thats because I live in the US.
    I dont think it would cost to much more for him to ship to Canada.
    The cost for the SHT71 is: $25US.
    Hope this helps,
    Harrison
    preferrably
    shipping
    > > Hi,
    about
    information
    issue in
    refreshing
    10,000
    > > FAQs.
    > > -- Tracy
    been
    > checking
    cycle life is.
    is?
    Subject and
    edited 2003-07-03 18:50
    I use a Humirel HS1101 (Digikey Part# HS1101-ND [noparse][[/noparse]$18.32 CDN]) with good success.
    This isn't a smart device, it's just a variable capacitor. Not nearly as
    elegant as the sht-11/71
    I use the 555 based circuit that's in the datasheet to get at the RH.
    http://rocky.digikey.com/WebLib/Humirel/HS1101.pdf
    If you order it, be sure to order the anciliary resistors for the type of 555 to
    be used at the same time!
    Don't forget that orders under $32.50 from Digikey have a $6.50 handling charge.
    Cheers,
    Dave
    > From: pm
    > Sent: 03 Jul 2003 12:17:03
    preferrably
    > From: "Tracy Allen"
    > To:
    > > Hi,
    > > I use dataflash in my loggers.··I've never gotten a firm answer about
    > > the write cycle life (which they call "endurance").·· Data
    > > without refresh, is rated as 10 years.··Endurance is not an issue in
    > > the kind of slow data logging I am doing.··They do suggest refreshing
    > > cycles.··For example, if you store some parameters on page 0, and
    > > come back and refresh page 0.··This is all in their app notes and
    > > FAQs.
    > >····-- Tracy
    > >····http://www.emesystems.com/BS2flash.htm
    > checking
    is.
    > >·· basicstamps-unsubscribe@yahoogroups.com
    > > from the same email address that you subscribed.··Text in the Subject
    and
    > ··basicstamps-unsubscribe@yahoogroups.com
    > from the same email address that you subscribed.··Text in the Subject and
    edited 2003-07-03 19:07
    If you made a board to mount the Sensirion sensor, do you have any info
    on that available?
    On Thursday, July 3, 2003, at 01:46 PM, Jonathan Peakall wrote:
    > PM,
    > made a
    > Jonathan
    > www.madlabs.info
    > From: "pm" <pmeloy@s...>
    > preferrably
    >> shipping
    >>> Hi,
    >>> FAQs.
    >>> -- Tracy
    >> checking
    >>>> life
    > is.
    > and
    >> and
    > and Body of the message will be ignored.
    edited 2003-07-03 19:17
    It was easy as can be. I just took a small chunk of PCB, used resist tape to
    make traces, and etched it. Then I tinned it well, set my solder pencil
    really low, and then heated the taces. I used a right angle SIP header to
    connect it to the rest of the circuit. Read the app. notes for important
    soldering information.
    Jonathan
    www.madlabs.info
    Sent: Thursday, July 03, 2003 11:07 AM
    Subject: Re: [noparse][[/noparse]basicstamps] sht-11/71 source?
    > on that available?
    > > PM,
    > > made a
    > > Jonathan
    > > www.madlabs.info
    > > preferrably
    > >> shipping
    > >>> Hi,
    > >>> FAQs.
    > >>> -- Tracy
    > >> checking
    > >>>> life
    > > is.
    > > and
    > >> and
    edited 2003-07-03 19:20
    Thanks. What I was really thinking about was air circulation around the
    sensor.
    On Thursday, July 3, 2003, at 02:17 PM, Jonathan Peakall wrote:
    > Jonathan Peakall" <jpeakall@m...>
    edited 2003-07-03 19:38
    Dang, didn't even notice he had those on the site. The '71 is actually the
    one I preferred too! Once I find out how much he wants for shipping, I'll
    give Mr. Peter an order. His just reward for being such a helpfull person [noparse]:D[/noparse]
    Sent: Thursday, July 03, 2003 10:47 AM
    Subject: [noparse][[/noparse]basicstamps] Re: sht-11/71 source?
    > Hello,
    > Hope this helps,
    > Harrison
    edited 2003-07-03 19:46
    Hello,
    He says that it costs $3.00 shipping for a few ounces to Canada.
    That is pretty cheap.
    Harrison
    actually the
    shipping, I'll
    > From: "harrisondp" <harrisondp@y...>
    > > Hello,
    me
    US.
    Canada.
    > > Hope this helps,
    > > Harrison
    edited 2003-07-03 20:13
    I made mine to look like the mounted version sold by sensiron. I mounted it
    in a waterproof flashlight. The SHT went where the lightbulb usually does,
    with a runnber boot to seal it off from the body of the flashlight. The lens
    was replaced with a fine plastic mesh to keep contamination out.
    Hope this is what you menat.
    Jonathan
    www.madlabs.info
    Sent: Thursday, July 03, 2003 11:20 AM
    > sensor.
    edited 2003-07-03 20:42
    Onset Computer (maker of the HOBO) is the official Sensirion rep for
    eastern US an Canada, and Sensolution is it for the western half.
    http://www.sensolution.com
    http://www.onsetcomp.com/Products/Product_Pages/Tattletale_pages/sensi
    rion.html
    If Peter Anderson has it for $25, I would go for that. The single
    unit price from the factory rep is $22.
    I recently updated my web page at
    http://www.emesystems.com/OL2sht1x.htm
    to show the '71 (which really does have marvelous flow-through
    characteristics), and my encapsulated (slow) version for outdoor use.
    I have run across one new precaution that I have not put on the web
    page yet. Sensirion has just added this item to their FAQ and it is
    not shown in their data sheet or app note. The clock line has to be
    at a solid low level when the chip powers up, or else there is a
    chance that it will enter a bad locked up state. For example, if you
    have the SHTxx powered by the 5 volt Vdd of a Stamp, and have the
    data line to a stamp pin with pullup and the clock line to a stamp
    pin straight, then the clock line will come up floating when you
    power up the stamp, and there is a chance that it will enter this
    locked up state. The solution is to add a pulldown (not up!)
    resistor to the SHTxx clock line, so that it will always start low.
    Or, power the SHTxx from a Stamp pin, and make the clock pin low
    before bringing the power high. The power for the SHTxx has to come
    up clean and relatively fast.
    I have hundreds of these out in the field now, connected as shown in
    the data sheet without the pulldown resistor, and most of them have
    worked without a hitch. The kicker is the 3 or 4 that have had
    trouble and led to an exchange of email with Sensirion. That is
    engineering for you.
    -- best regards
    Tracy Allen
    mailto:tracy@e...
    >Jonathan
    >www.madlabs.info
    >From: "Mark Marpet" <marpetm@s...>
    >> sensor.
    >Subject and Body of the message will be ignored.
    Exactly, and thanks.
    > mounted it
    > does,
    > The lens
    > Jonathan
    > www.madlabs.info
    >> the
    >> sensor.
    >> and
