Input is serial binary bits n Output them into parallel?
I'm buying a OEM Basic stamp 2 tomolo. Just wan to know if it is
capable of taking serial bits output from the modem, convert and
output them in parallel form. Or do I need to buy NCD 101 serial-to-
parallel converter chip?
Thanks!
Thanks!
Setup:
DIRL = %11111111
Main:
DO
SERIN 15, Baud, [noparse][[/noparse]aByte]
OUTL = aByte
LOOP
You'll just need to set the baud rate for your serial stream. The
program makes pins 0 - 7 outputs then puts the serial byte on them after
it comes in.
-- Jon Williams
-- Parallax
Original Message
From: barangsg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CeZruBXEUOcDcgeskGz9yxDR00Ikva4eMN_Tztgxj2NLlAlNVfaXX_qANZieTwOpGxKrAegE__DB9rIQW2g]barangsg@y...[/url
Sent: Wednesday, July 02, 2003 4:37 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Input is serial binary bits n Output them into
parallel?
Thanks!
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
school project. I'm using a PC to send 7 bits of
binary data over e phone line to a standalone modem.
It's RS232 port will be connected to a BS2 . This 7
serial bits will be input to e BS2. Here r e functions
which I wan my BS2 to perform. Can I check with u if
they r attainable?
1)Check for incoming data.
2)Perform 1 bit error parity check.
3)Close e connection.
Thks!
--- Jon Williams <jwilliams@p...> wrote: >
Yes, you can certainly do that. Your code can be as
> simple as this:
> Setup:
> DIRL = %11111111
> Main:
> DO
> OUTL = aByte
> LOOP
> serial stream. The
> it comes in.
> -- Jon Williams
> -- Parallax
Original Message
> From: barangsg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zoHmDFEsEKvEB221O7TmnFg_OgmqHLsu14dASqOCCrt2FZnSZmPXpmpLHP-vuLSBSKK0oB_Y3wSqed1GNlBEow]barangsg@y...[/url
> Output them into
> parallel?
> know if it is
> convert and
> NCD 101 serial-to-
> Thanks!
> Text in the Subject
> report SPAM to
> abuse@p....
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Send free SMS from your PC!
http://sg.sms.yahoo.com
