Repost: Soft start clutch
Hmm..the initial post seems to have vaporized.
My application uses an electric clutch attached to a gasoline motor-
add 12 volts, clutch engages. The problem is that it engages so hard
that breakages are occurring. Has anyone an idea how to slowly
engage this device- It is "currently" being activated by a MOSFET
that is driven by an opto and a bs2p output. Any ideas are
appreciated.
Tim
appreciated.
Tim
1 What are you running off the engine
2 What is the starting torque of this device
3 What is the clutch rated at
4 What is breaking
5 What RPM is the motor running at
6 Most motors have air flaps for keeping the motor at a constant RPM
load/noload
And yes you may be able to ramp up the voltage with slippage and heating and
breaking
Larry Gaminde
Original Message
To: <basicstamps@yahoogroups.com>
Sent: June 27, 2003 8:06 AM
Subject: [noparse][[/noparse]basicstamps] Repost: Soft start clutch
> appreciated.
> Tim
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
increse it.
With hardware, you can insert a choke in series, when applied power,
the choke will limit the current until it saturates.
Inductance of the choke could be defined as;
V=L*di/dt
simplifying, L (henries)=Voltage applied*time/Current
magnet)
Larry Gaminde
Original Message
Sent: June 27, 2003 12:31 PM
Subject: RE: [noparse][[/noparse]basicstamps] Repost: Soft start clutch
> You need to ramp the voltage up very slowly to allow the clutch to slip.
Do
> this with an integrator circuit, however, some clutch designs will not
> engage slowly but instead have an on/off type of engagement. This is
> typical of the type used on automotive air conditioner compressors. In
that
> case, shock is absorbed by the belt stretch/slippage. Another approach,
you
> may need to soft couple to your motor using a rubber coupling which will
> absorb some shock. Or, change to v belt coupling and adjust the tension to
> allow some slippage on engagement. This is one reason that centrifigal
> clutches are used in these types of applications so that engine speed is
> increasing and starting to drive the load and when speed comes up high
> enough to support the load, the clutch is fulling engaged. It also slips
> when the load speed exceeds the drive speed. If you can engage the clutch
> at a low speed and then increase engine speed it may solve your problem.
> jim
> http://www.geocities.com/jimforkin2003/
Original Message
> From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8XMtxg7-ZrrEgxQqH5eU-oQkKeeaQ30cCmim0W9IUoK0QuOpO-ezRp6MKvoj1oc2XV1KVkVb9_wB8CMuUeDh]tweaver@i...[/url
> Sent: Friday, June 27, 2003 11:07 AM
> To: basicstamps@yahoogroups.com
> appreciated.
> Tim
typical of the type used on automotive air conditioner compressors. In that
case, shock is absorbed by the belt stretch/slippage. Another approach, you
jim
Original Message
From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-mHeb2oeR8tqmr4UX55QicQEg8f5XcsWV69qpYPVxt3JrQVhRMAHJM7USpyqDEwuVCfvzI7C1jcxpawt0723]tweaver@i...[/url
appreciated.
Tim
