Repost: Soft start clutch — Parallax Forums
edited 2003-06-27 20:31 in General Discussion
Hmm..the initial post seems to have vaporized.
My application uses an electric clutch attached to a gasoline motor-
add 12 volts, clutch engages. The problem is that it engages so hard
that breakages are occurring. Has anyone an idea how to slowly
engage this device- It is "currently" being activated by a MOSFET
that is driven by an opto and a bs2p output. Any ideas are
appreciated.
Tim
    edited 2003-06-27 16:21
    I think you need to look at the mechanical problems here first.
    1 What are you running off the engine
    2 What is the starting torque of this device
    3 What is the clutch rated at
    4 What is breaking
    5 What RPM is the motor running at
    6 Most motors have air flaps for keeping the motor at a constant RPM
    load/noload
    And yes you may be able to ramp up the voltage with slippage and heating and
    breaking
    Larry Gaminde
    Sent: June 27, 2003 8:06 AM
    Subject: [noparse][[/noparse]basicstamps] Repost: Soft start clutch
    > appreciated.
    > Tim
    edited 2003-06-27 16:30
    You can use a PWM function, start with a low pulse width and slowly
    increse it.
    With hardware, you can insert a choke in series, when applied power,
    the choke will limit the current until it saturates.
    Inductance of the choke could be defined as;
    V=L*di/dt
    simplifying, L (henries)=Voltage applied*time/Current
    edited 2003-06-27 20:14
    I wonder what the current draw will be when not completely engaged (electro
    magnet)
    Larry Gaminde
    Sent: June 27, 2003 12:31 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Repost: Soft start clutch
    > You need to ramp the voltage up very slowly to allow the clutch to slip.
    Do
    > this with an integrator circuit, however, some clutch designs will not
    > engage slowly but instead have an on/off type of engagement. This is
    > typical of the type used on automotive air conditioner compressors. In
    that
    > case, shock is absorbed by the belt stretch/slippage. Another approach,
    you
    > may need to soft couple to your motor using a rubber coupling which will
    > absorb some shock. Or, change to v belt coupling and adjust the tension to
    > allow some slippage on engagement. This is one reason that centrifigal
    > clutches are used in these types of applications so that engine speed is
    > increasing and starting to drive the load and when speed comes up high
    > enough to support the load, the clutch is fulling engaged. It also slips
    > when the load speed exceeds the drive speed. If you can engage the clutch
    > at a low speed and then increase engine speed it may solve your problem.
    > jim
    > http://www.geocities.com/jimforkin2003/
    > From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8XMtxg7-ZrrEgxQqH5eU-oQkKeeaQ30cCmim0W9IUoK0QuOpO-ezRp6MKvoj1oc2XV1KVkVb9_wB8CMuUeDh]tweaver@i...[/url
    > Sent: Friday, June 27, 2003 11:07 AM
    > appreciated.
    > Tim
    You need to ramp the voltage up very slowly to allow the clutch to slip. Do
    typical of the type used on automotive air conditioner compressors. In that
    case, shock is absorbed by the belt stretch/slippage. Another approach, you
    jim
    From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-mHeb2oeR8tqmr4UX55QicQEg8f5XcsWV69qpYPVxt3JrQVhRMAHJM7USpyqDEwuVCfvzI7C1jcxpawt0723]tweaver@i...[/url
    appreciated.
    Tim
