PBASIC equivalent of INKEY$ command in QUICKBASIC?
Is there a command equivalent to INKEY$ available in BASIC? Is there
a way to achieve this in PBASIC code to be run in BS2p?
THanks
Mohammed
THanks
Mohammed
DEBUG "Press a key", CR
DEBUGIN inKey
DEBUG CR, CR, "You pressed --> ", inKey, " (with ASCII value: ", DEC
inKey, ")"
To the Stamp, a character is just a byte -- it's presentation in the
DEBUG window depends on any modifiers. With none, the DEBUG window
prints the character represented by that byte. With formatters (DEC,
HEX, BIN, etc.), the value is converted to a string of characters. In
the example above, if you press "A", you'll get:
You pressed --> A (with ASCII value: 65)
The manual has a good description of how all this works and you can
download it at no charge.
-- Jon Williams
-- Parallax
Original Message
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BKrC85yf8XKX2FGNcmzvO6TJd0hOM4Cb4OhUtVyKEf3nHz3fle46SJ0RyV9mpzZ3qB4QmmsxmawKUZX7KQ]mohammedrasiq@y...[/url
Sent: Thursday, June 26, 2003 11:04 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PBASIC equivalent of INKEY$ command in
QUICKBASIC?
THanks
Mohammed
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
QUICKBASIC does not hold the normal execution of the program. The
INKEY$ function stores the last pressed key, whenever that is
pressed. In the case of BASICSTAMP using SERIN & DEBUG, the program
execution has to wait until the user enters a key. Any ways around it
in BASIC STAMP?
Thanks a lot
Mohammed
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You can use SERIN or DEBUGIN (you must have PBASIC 2.5 for DEBUGIN).
> DEBUGIN inKey
DEC
> inKey, ")"
(DEC,
In
> -- Jon Williams
> -- Parallax
Original Message
> From: mohammedrasiq [noparse][[/noparse]mailto:mohammedrasiq@y...]
> QUICKBASIC?
there
> THanks
> Mohammed
Subject
> abuse@p...
non-interrupt beast, can do only one thing
at a time.
The PC, having an interrupt-driven keyboard
reader piece-of-code, can receive input from
the keyboard and hold it until another piece
of PC code (inkey$) can read it.
The Stamp has to explicitly read each piece
of input coming in to it. So the only
way you can do this with a Basic Stamp is
to explicitly try to get the byte and
wait for it.
You can, however, use a timeout on the SERIN
command so if a byte is not being transmitted
just now, your program can go do something
useful and try again in a little bit.
You can also use the CTS signal as a
SERIN 'flag pin'. This allows the BS2 to
signal a sender (when the SERIN instruction
runs) that it is now OK to send the byte.
--- In basicstamps@yahoogroups.com, "mohammedrasiq"
<mohammedrasiq@y...> wrote:
> Thanks Jon for your detailed reply. However, the INKEY$ function in
it
> in BASIC STAMP?
> Thanks a lot
> Mohammed
DEBUGIN).
> > DEBUGIN inKey
value: ",
> DEC
> > inKey, ")"
the
window
> (DEC,
characters.
> In
can
> > -- Jon Williams
> > -- Parallax
Original Message
> > QUICKBASIC?
> there
> > THanks
> > Mohammed
> Subject
> > abuse@p...
Mohammed
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> The Basic Stamp, being a non-multi-tasked,
> at a time.
> wait for it.
in
program
around
> it
> > in BASIC STAMP?
> > Thanks a lot
> > Mohammed
<jwilliams@p...>
> DEBUGIN).
> > > DEBUGIN inKey
> value: ",
> > DEC
> > > inKey, ")"
in
> the
> window
> > (DEC,
> characters.
> > In
> can
> > > -- Jon Williams
> > > -- Parallax
Original Message
> > > QUICKBASIC?
> > there
> > > THanks
> > > Mohammed
> > Subject
to
> > > abuse@p...
don't have in the BASIC Stamp. The only way to prevent missing
characters is to use flow control (so characters can't be sent until
you're ready for them) or use an external UART as a buffer.
-- Jon Williams
-- Parallax
Original Message
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T-BhIpbrPxWYRTsfWad_eLRGcOz3jYiOFnzHWD5PDcvNiEVLxh99v7dF0tLMYENoRuX76vf1vg5wjIKDIg]mohammedrasiq@y...[/url
Sent: Friday, June 27, 2003 10:05 AM
Subject: [noparse][[/noparse]basicstamps] Re: PBASIC equivalent of INKEY$ command in
QUICKBASIC?
in BASIC STAMP?
Thanks a lot
Mohammed
> DEBUGIN inKey
DEC
> inKey, ")"
(DEC,
In
> -- Jon Williams
> -- Parallax
Original Message
> QUICKBASIC?
there
> a way to achieve this in PBASIC code to be run in BS2p? THanks
> Mohammed
Subject
> abuse@p...
abuse@p....
wrote:
> QBASIC is taking advantage of the PC keyboard buffer -- something
you
> -- Jon Williams
> -- Parallax
Original Message
> QUICKBASIC?
it
> in BASIC STAMP?
> Thanks a lot
> Mohammed
DEBUGIN).
> > DEBUGIN inKey
> DEC
> > inKey, ")"
the
window
> (DEC,
> In
can
> > -- Jon Williams
> > -- Parallax
Original Message
> > QUICKBASIC?
> there
> > Mohammed
> Subject
> > abuse@p...
Subject
> abuse@p...
