PBASIC equivalent of INKEY$ command in QUICKBASIC? — Parallax Forums
edited 2003-06-27 17:37 in General Discussion
Is there a command equivalent to INKEY$ available in BASIC? Is there
a way to achieve this in PBASIC code to be run in BS2p?
THanks
Mohammed
    edited 2003-06-27 15:27
    You can use SERIN or DEBUGIN (you must have PBASIC 2.5 for DEBUGIN).
    DEBUG "Press a key", CR
    DEBUGIN inKey
    DEBUG CR, CR, "You pressed --> ", inKey, " (with ASCII value: ", DEC
    inKey, ")"
    To the Stamp, a character is just a byte -- it's presentation in the
    DEBUG window depends on any modifiers. With none, the DEBUG window
    prints the character represented by that byte. With formatters (DEC,
    HEX, BIN, etc.), the value is converted to a string of characters. In
    the example above, if you press "A", you'll get:
    You pressed --> A (with ASCII value: 65)
    The manual has a good description of how all this works and you can
    download it at no charge.
    -- Jon Williams
    -- Parallax
    From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BKrC85yf8XKX2FGNcmzvO6TJd0hOM4Cb4OhUtVyKEf3nHz3fle46SJ0RyV9mpzZ3qB4QmmsxmawKUZX7KQ]mohammedrasiq@y...[/url
    Sent: Thursday, June 26, 2003 11:04 PM
    Subject: [noparse][[/noparse]basicstamps] PBASIC equivalent of INKEY$ command in
    QUICKBASIC?
    THanks
    Mohammed
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-06-27 16:05
    Thanks Jon for your detailed reply. However, the INKEY$ function in
    QUICKBASIC does not hold the normal execution of the program. The
    INKEY$ function stores the last pressed key, whenever that is
    pressed. In the case of BASICSTAMP using SERIN & DEBUG, the program
    execution has to wait until the user enters a key. Any ways around it
    in BASIC STAMP?
    Thanks a lot
    Mohammed
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    > DEBUGIN inKey
    DEC
    > inKey, ")"
    (DEC,
    In
    > -- Jon Williams
    > -- Parallax
    > From: mohammedrasiq [noparse][[/noparse]mailto:mohammedrasiq@y...]
    > QUICKBASIC?
    there
    > THanks
    > Mohammed
    Subject
    > abuse@p...
    edited 2003-06-27 16:57
    The Basic Stamp, being a non-multi-tasked,
    non-interrupt beast, can do only one thing
    at a time.
    The PC, having an interrupt-driven keyboard
    reader piece-of-code, can receive input from
    the keyboard and hold it until another piece
    of PC code (inkey$) can read it.
    The Stamp has to explicitly read each piece
    of input coming in to it. So the only
    way you can do this with a Basic Stamp is
    to explicitly try to get the byte and
    wait for it.
    You can, however, use a timeout on the SERIN
    command so if a byte is not being transmitted
    just now, your program can go do something
    useful and try again in a little bit.
    You can also use the CTS signal as a
    SERIN 'flag pin'. This allows the BS2 to
    signal a sender (when the SERIN instruction
    runs) that it is now OK to send the byte.
    --- In basicstamps@yahoogroups.com, "mohammedrasiq"
    it
    > in BASIC STAMP?
    > Thanks a lot
    > Mohammed
    DEBUGIN).
    > > DEBUGIN inKey
    value: ",
    > DEC
    > > inKey, ")"
    the
    window
    > (DEC,
    characters.
    > In
    can
    > > -- Jon Williams
    > > -- Parallax
    > > QUICKBASIC?
    > there
    > > THanks
    > > Mohammed
    > Subject
    > > abuse@p...
    edited 2003-06-27 17:08
    Thanks Allan for your reply. That answers my question.
    Mohammed
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > at a time.
    > wait for it.
    in
    program
    around
    > it
    > > in BASIC STAMP?
    > > Thanks a lot
    > > Mohammed
    <jwilliams@p...>
    > DEBUGIN).
    > > > DEBUGIN inKey
    > value: ",
    > > DEC
    > > > inKey, ")"
    in
    > the
    > window
    > > (DEC,
    > characters.
    > > In
    > can
    > > > -- Jon Williams
    > > > -- Parallax
    > > > QUICKBASIC?
    > > there
    > > > THanks
    > > > Mohammed
    > > Subject
    to
    > > > abuse@p...
    edited 2003-06-27 17:13
    QBASIC is taking advantage of the PC keyboard buffer -- something you
    don't have in the BASIC Stamp. The only way to prevent missing
    characters is to use flow control (so characters can't be sent until
    you're ready for them) or use an external UART as a buffer.
    -- Jon Williams
    -- Parallax
    From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T-BhIpbrPxWYRTsfWad_eLRGcOz3jYiOFnzHWD5PDcvNiEVLxh99v7dF0tLMYENoRuX76vf1vg5wjIKDIg]mohammedrasiq@y...[/url
    Sent: Friday, June 27, 2003 10:05 AM
    Subject: [noparse][[/noparse]basicstamps] Re: PBASIC equivalent of INKEY$ command in
    QUICKBASIC?
    in BASIC STAMP?
    Thanks a lot
    Mohammed
    > DEBUGIN inKey
    DEC
    > inKey, ")"
    (DEC,
    In
    > -- Jon Williams
    > -- Parallax
    > QUICKBASIC?
    there
    > a way to achieve this in PBASIC code to be run in BS2p? THanks
    > Mohammed
    Subject
    > abuse@p...
    abuse@p....
    Thanks, Jon.
    you
    > -- Jon Williams
    > -- Parallax
    > QUICKBASIC?
    it
    > in BASIC STAMP?
    > Thanks a lot
    > Mohammed
    DEBUGIN).
    > > DEBUGIN inKey
    > DEC
    > > inKey, ")"
    the
    window
    > (DEC,
    > In
    can
    > > -- Jon Williams
    > > -- Parallax
    > > QUICKBASIC?
    > there
    > > Mohammed
    > Subject
    > > abuse@p...
    Subject
    > abuse@p...
