Pulsout command
Hello,
Can the BS2p perform any other operations while executing a pulsout command or
does it function in the same way as a pause instruction?
Many thanks,
Alex
Many thanks,
Alex
executing that instruction and nothing else happens until the
instruction completes. If you need to generate pulses asynchronously,
look at http://www.al-williams.com/pak8.htm
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: Alex Metcalfe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fc12JJQnSbULWzyHLlIjsAJICtX0tTVlzsW37RR63IKcrTXFTYTUMY90xxN4ukLfS0yKQLLae7P8mghkZ-sW]ametcalfe@p...[/url
> Sent: Tuesday, June 24, 2003 2:39 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Pulsout command
> Hello,
> pulsout command or does it function in the same way as a
> pause instruction?
> Many thanks,
> Alex
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Original Message
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rmp4F3oGLoViMaptuiCsVbeufNYVjXx2b5wKZAZn3-x4VRC1HUU2_Fs6uH72VRg7WyEWesRfDNQl9lM]alw@a...[/url
Sent: Tuesday, 24 June 2003 13:29
Subject: RE: [noparse][[/noparse]basicstamps] Pulsout command
Once you execute a PULSOUT (or any Stamp command) it concentrates on executing
that instruction and nothing else happens until the instruction completes. If
you need to generate pulses asynchronously, look at
Al Williams
AWC
* Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
Original Message
> From: Alex Metcalfe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GX5kViLqQfYiYUUgy6LaG7QH5Xr-oYlR9PkjGelY21vSIthb7XH0ccZvZOA212YoKFJvs841dSHWCrI]ametcalfe@p...[/url
> Hello,
> command or does it function in the same way as a pause instruction?
> Many thanks,
> Alex
> from the same email address that you subscribed. Text in the Subject
from the same email address that you subscribed. Text in the Subject and Body
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
-- Jon Williams
-- Parallax
In a message dated 6/24/2003 3:36:24 AM Central Standard Time,
ametcalfe@p... writes:
