Max 232 / Mobile Phone
Hope someone can help. I am currently trying to get my stamp BS2
to talk to my mobile phone. I am running into a few problems. I
have written some code to output some AT command to a pin for serial
transfer to the phone. The phone does not recognise the signal which
works fine when I copy the output to a hyperterminal session and send
to the phone manually. I assume this was due to the phone wanting
232 voltages.
So to get past this I decided to run the output from the serial
pin through a Max 232 chip. I wired this up on a breadboard as per
the diagram in issue 89 of Nuts n' Volts. I get an output from the
chip but it shows up as jibberish (random characters) on a
hyperterminal session. Thinking that the characters were
just 'shifted' on the ascii map I tryed just sending 5 1's (ie
11111). It showed up as completly different characters.
This sounds like some sort of timing issue to me. Can anyone offer
me some help ?
Thanks in advance.
Mitch
232 voltages.
me some help ?
Thanks in advance.
Mitch
quite often useless when dealing with RF.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: mknight73 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0WrA8eolVEA3Vk8-qS4nctCwYXgTKcDC2bNAK4CNGKFLsPNHu5PiVGiNiYmEbQI-6nE1_sYffc8-Ydpv9A]mknight73@y...[/url
Sent: Monday, June 16, 2003 8:08 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Max 232 / Mobile Phone
232 voltages.
me some help ?
Thanks in advance.
Mitch
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
you need to set the 'Invert' mode on the baudrate.
--- In basicstamps@yahoogroups.com, "mknight73" <mknight73@y...>
BS2
serial
which
send
> 232 voltages.
> me some help ?
> Thanks in advance.
> Mitch
got one step further. The phone will still not react to the AT
commands.
If I copy the commands to a hyperterminal session the phone reacts,
if I use the stamp, no response.
I have tried bridging pins (of the D9 plug) 1-4-6 and 7-8 to no
success.
Has anybody successfully communicated with a mobile phone from a
stamp ? What is the difference between the stamp and pc ? Do I
need to try RTS/CTS ?
I am using a Nokia 6210 with data cable.
Thanks again.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Also, when you put a 232 driver into the circuit,
> BS2
I
> serial
> which
> send
wanting
> > 232 voltages.
serial
per
the
offer
> > me some help ?
> > Thanks in advance.
> > Mitch
If Nokia still use the same method as they did for the 5110 then you
are being tricked.
The nokia software creates a virtual com port on the computer that you
can access with programs such as hyperterminal but in fact it is
speaking a nokia binary format out the physical com port.
So unless you know the binary protocol your sunk.
There was however a group that was striving to overcome this, try;
www.gnokii.org
Perhaps they can help
Regards
Rohan
Original Message
Date: Tuesday, June 17, 2003 6:51 am
Subject: [noparse][[/noparse]basicstamps] Re: Max 232 / Mobile Phone
> Thanks for your help. The invert worked first time. I have only
> commands.
> reacts,
> success.
> Thanks again.
> stamp
> > BS2
> I
> > serial
> signal
> > which
> and
> > send
> wanting
> > > 232 voltages.
> serial
> as
> per
> from
> the
> offer
> > > me some help ?
> > > Thanks in advance.
> > > Mitch
> Subject and Body of the message will be ignored.
success, though not much!
I have my bs2p connected to the nokia 6310i with data cable, and
when I send the 'AT' command, I can get the 'OK' reply (using the WAIT
(OK)) in the serin command.
I also copied a lot from Nuts&Volts 89, look at 60 also.
I'm trying to send a SMS message from the stamp, but I get problems
at the send stage. I get OK from the phone at each stage up to this
though. I followed the commands in the Nokia AT command guide.
I used flow control with serin, but not with serout (wouldn't work).
At this stage I'm wondering if I need to connect more than just TX,
RX, RTS, CTS, maybe the data cable gets power from the PC (stamp)
side?
I want to use the phone as a modem eventually, because it has its own
battery backup!
If you'd like the code I've got so far, let me know, perhaps we can
figure this out between us.
Darren.
BS2
serial
which
send
> 232 voltages.
> me some help ?
> Thanks in advance.
> Mitch
Ericsson mobile phone as a modem, but haven't had any success. I want
the Stamp to download received SMS messages from the phone (then do
other cool things with them, but that part is already resolved) using
the AT command set provided by Sony Ericsson. I know I can connect to
and download from the phone using hyperterminal but it doesn't seem
to work to use the same settings with the Stamp. Are you using the
I/O pins or the programming pin? I also wonder whether it's a voltage
issue. Since my phone runs on 3 volts I assumed that it wouldn't need
for a 12-volt RS 232 signal.
Germaine
--- In basicstamps@yahoogroups.com, "poguemomhoin"
<darren.gallagher@o...> wrote:
> I'm trying to do the very same thing, but it seems with a little
more
WAIT
> side?
own
> battery backup!
> Darren.
> BS2
> serial
> which
> send
wanting
> > 232 voltages.
serial
per
the
offer
> > me some help ?
> > Thanks in advance.
> > Mitch
