Max 232 / Mobile Phone — Parallax Forums
edited 2004-04-02 19:12 in General Discussion
Hope someone can help. I am currently trying to get my stamp BS2
to talk to my mobile phone. I am running into a few problems. I
have written some code to output some AT command to a pin for serial
transfer to the phone. The phone does not recognise the signal which
works fine when I copy the output to a hyperterminal session and send
to the phone manually. I assume this was due to the phone wanting
232 voltages.
So to get past this I decided to run the output from the serial
pin through a Max 232 chip. I wired this up on a breadboard as per
the diagram in issue 89 of Nuts n' Volts. I get an output from the
chip but it shows up as jibberish (random characters) on a
hyperterminal session. Thinking that the characters were
just 'shifted' on the ascii map I tryed just sending 5 1's (ie
11111). It showed up as completly different characters.
This sounds like some sort of timing issue to me. Can anyone offer
me some help ?
Thanks in advance.
Mitch
    edited 2003-06-16 14:10
    you may be seeing RF interference from the phone. Breadboard circuits are
    quite often useless when dealing with RF.
    jim
    http://www.geocities.com/jimforkin2003/
    From: mknight73 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0WrA8eolVEA3Vk8-qS4nctCwYXgTKcDC2bNAK4CNGKFLsPNHu5PiVGiNiYmEbQI-6nE1_sYffc8-Ydpv9A]mknight73@y...[/url
    Sent: Monday, June 16, 2003 8:08 AM
    Subject: [noparse][[/noparse]basicstamps] Max 232 / Mobile Phone
    232 voltages.
    me some help ?
    Thanks in advance.
    Mitch
    edited 2003-06-16 15:12
    Also, when you put a 232 driver into the circuit,
    you need to set the 'Invert' mode on the baudrate.
    --- In basicstamps@yahoogroups.com, "mknight73" <mknight73@y...>
    BS2
    serial
    which
    send
    > 232 voltages.
    > me some help ?
    > Thanks in advance.
    > Mitch
    edited 2003-06-16 21:51
    Thanks for your help. The invert worked first time. I have only
    got one step further. The phone will still not react to the AT
    commands.
    If I copy the commands to a hyperterminal session the phone reacts,
    if I use the stamp, no response.
    I have tried bridging pins (of the D9 plug) 1-4-6 and 7-8 to no
    success.
    Has anybody successfully communicated with a mobile phone from a
    stamp ? What is the difference between the stamp and pc ? Do I
    need to try RTS/CTS ?
    I am using a Nokia 6210 with data cable.
    Thanks again.
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > BS2
    I
    > serial
    > which
    > send
    wanting
    > > 232 voltages.
    serial
    per
    the
    offer
    > > me some help ?
    > > Thanks in advance.
    > > Mitch
    edited 2003-06-17 05:28
    I am working from memory, but I'm pretty sure I'm right
    If Nokia still use the same method as they did for the 5110 then you
    are being tricked.
    The nokia software creates a virtual com port on the computer that you
    can access with programs such as hyperterminal but in fact it is
    speaking a nokia binary format out the physical com port.
    So unless you know the binary protocol your sunk.
    There was however a group that was striving to overcome this, try;
    www.gnokii.org
    Perhaps they can help
    Regards
    Rohan
    Date: Tuesday, June 17, 2003 6:51 am
    Subject: [noparse][[/noparse]basicstamps] Re: Max 232 / Mobile Phone
    > commands.
    > reacts,
    > success.
    > Thanks again.
    > stamp
    > > BS2
    > I
    > > serial
    > signal
    > > which
    > and
    > > send
    > wanting
    > > > 232 voltages.
    > serial
    > as
    > per
    > from
    > the
    > offer
    > > > me some help ?
    > > > Thanks in advance.
    > > > Mitch
    edited 2004-03-22 15:37
    I'm trying to do the very same thing, but it seems with a little more
    success, though not much!
    I have my bs2p connected to the nokia 6310i with data cable, and
    when I send the 'AT' command, I can get the 'OK' reply (using the WAIT
    (OK)) in the serin command.
    I also copied a lot from Nuts&Volts 89, look at 60 also.
    I'm trying to send a SMS message from the stamp, but I get problems
    at the send stage. I get OK from the phone at each stage up to this
    though. I followed the commands in the Nokia AT command guide.
    I used flow control with serin, but not with serout (wouldn't work).
    At this stage I'm wondering if I need to connect more than just TX,
    RX, RTS, CTS, maybe the data cable gets power from the PC (stamp)
    side?
    I want to use the phone as a modem eventually, because it has its own
    battery backup!
    If you'd like the code I've got so far, let me know, perhaps we can
    figure this out between us.
    Darren.
    BS2
    serial
    which
    send
    > 232 voltages.
    > me some help ?
    > Thanks in advance.
    > Mitch
    Darren, I'm trying to do almost exactly the same as you using a Sony
    Ericsson mobile phone as a modem, but haven't had any success. I want
    the Stamp to download received SMS messages from the phone (then do
    other cool things with them, but that part is already resolved) using
    the AT command set provided by Sony Ericsson. I know I can connect to
    and download from the phone using hyperterminal but it doesn't seem
    to work to use the same settings with the Stamp. Are you using the
    I/O pins or the programming pin? I also wonder whether it's a voltage
    issue. Since my phone runs on 3 volts I assumed that it wouldn't need
    for a 12-volt RS 232 signal.
    Germaine
    --- In basicstamps@yahoogroups.com, "poguemomhoin"
    more
    WAIT
    > side?
    own
    > battery backup!
    > Darren.
    > BS2
    > serial
    > which
    > send
    wanting
    > > 232 voltages.
    serial
    per
    the
    offer
    > > me some help ?
    > > Thanks in advance.
    > > Mitch
