Serout/Serin Numeric Probs — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2003-06-15 03:27 in General Discussion
HELP.. I know Im missing somethin simple here.
I am passing data between 2 stamps with the following:
From Slave
result var word
...do stuff...
SEROUT 0\1,16468,6000,nomaster,[noparse][[/noparse]sensor, result]
debug dec sensor," ", dec result, cr
... loop for all 5
To Master
result var word
serin 2\3, 16468, 3000, waitforslave, [noparse][[/noparse]sensor, Result]
.. keep polling slave for all 5
Debug output
Master Slave
Sensor 1 113 Sensor 1 113
Sensor 2 14 Sensor 2 526
Sensor 3 228 Sensor 3 484
Sensor 4 127 Sensor 4 383
Sensor 5 109 Sensor 5 365
I noticed that the 113 value of sensor 1 is correct, but what is
happening to 4-5 I have not been able to fix with formatting either
on the serin or serout side of things. Both "result" are defined as
words. Result gets its value from the following line of code:
SHIFTIN 9,SCLK,2,[noparse][[/noparse]result\12] which is a MAX 186 ADC.
Your thoughts?
Thanks in advance.
rltaylor001@h...
  • ArchiverArchiver Posts: 46,084
    edited 2003-06-14 21:56
    SERIN and SEROUT work with bytes. Try this:
    SEROUT 0\1, 16468, 6000, No_Master, [noparse][[/noparse]sensor, result.LOWBYTE,
    result.HIGHBYTE]
    and...
    SERIN 2\3, 16468, 3000, Wait_For_Slave, [noparse][[/noparse]sensor, result.LOWBYTE,
    result.HIGHBYTE]
    -- Jon Williams
    -- Parallax
    In a message dated 6/14/2003 3:23:17 PM Central Standard Time,
    rltaylor001@h... writes:
    > From Slave
    > result var word
    > ...do stuff...
    > ... loop for all 5
    > To Master
    > result var word
    > Debug output
    > Master Slave
    > Your thoughts?
    > Thanks in advance.
    > rltaylor001@h...
    edited 2003-06-14 22:30
    Thanks, nice to have a second set of eyes.. I am assuming that I'll
    have to do the same when I serout to VB, since the "word" is greater
    than 255. Are there issues gluing the low/high bytes back together
    in VB?
    Thanks again,
    RLT
    > result.HIGHBYTE]
    > and...
    > result.HIGHBYTE]
    > -- Jon Williams
    > -- Parallax
    > > From Slave
    > > result var word
    > > ...do stuff...
    > > ... loop for all 5
    > > To Master
    > > result var word
    > > Debug output
    > > Master Slave
    either
    as
    > > Your thoughts?
    > > Thanks in advance.
    > > rltaylor001@h...
    edited 2003-06-14 22:51
    > in VB?
    > Thanks again,
    > RLT
    I have a VB project showing how to receive byte-sized data and
    combine bytes to form words, extract & act on individual bytes, etc,
    here http://www.rentron.com/PicBasic/VB_PIC_TEMP.htm
    -Bruce
    tech@r...
    edited 2003-06-14 23:17
    BINGO, Thanks
    RLT
    I'll
    greater
    together
    > > in VB?
    > > Thanks again,
    > > RLT
    > Regards,
    > -Bruce
    > tech@r...
    No problem at all. To see how to exchange data with VB, go to our web site
    and download Nuts & Volts article #89.
    -- Jon Williams
    -- Parallax
    In a message dated 6/14/2003 4:31:33 PM Central Standard Time,
    > in VB?
    > Thanks again,
    > RLT
