Serout/Serin Numeric Probs
HELP.. I know Im missing somethin simple here.
I am passing data between 2 stamps with the following:
From Slave
result var word
...do stuff...
SEROUT 0\1,16468,6000,nomaster,[noparse][[/noparse]sensor, result]
debug dec sensor," ", dec result, cr
... loop for all 5
To Master
result var word
serin 2\3, 16468, 3000, waitforslave, [noparse][[/noparse]sensor, Result]
.. keep polling slave for all 5
Debug output
Master Slave
Sensor 1 113 Sensor 1 113
Sensor 2 14 Sensor 2 526
Sensor 3 228 Sensor 3 484
Sensor 4 127 Sensor 4 383
Sensor 5 109 Sensor 5 365
I noticed that the 113 value of sensor 1 is correct, but what is
happening to 4-5 I have not been able to fix with formatting either
on the serin or serout side of things. Both "result" are defined as
words. Result gets its value from the following line of code:
SHIFTIN 9,SCLK,2,[noparse][[/noparse]result\12] which is a MAX 186 ADC.
Your thoughts?
Thanks in advance.
rltaylor001@h...
From Slave
result var word
...do stuff...
... loop for all 5
To Master
result var word
Debug output
Master Slave
Your thoughts?
Thanks in advance.
rltaylor001@h...
SEROUT 0\1, 16468, 6000, No_Master, [noparse][[/noparse]sensor, result.LOWBYTE,
result.HIGHBYTE]
and...
SERIN 2\3, 16468, 3000, Wait_For_Slave, [noparse][[/noparse]sensor, result.LOWBYTE,
result.HIGHBYTE]
-- Jon Williams
-- Parallax
In a message dated 6/14/2003 3:23:17 PM Central Standard Time,
rltaylor001@h... writes:
> From Slave
> result var word
> ...do stuff...
> ... loop for all 5
> To Master
> result var word
> Debug output
> Master Slave
> Your thoughts?
> Thanks in advance.
> rltaylor001@h...
have to do the same when I serout to VB, since the "word" is greater
than 255. Are there issues gluing the low/high bytes back together
in VB?
Thanks again,
RLT
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> SERIN and SEROUT work with bytes. Try this:
> result.HIGHBYTE]
> and...
> result.HIGHBYTE]
> -- Jon Williams
> -- Parallax
> > From Slave
> > result var word
> > ...do stuff...
> > ... loop for all 5
> > To Master
> > result var word
> > Debug output
> > Master Slave
either
as
> > Your thoughts?
> > Thanks in advance.
> > rltaylor001@h...
> in VB?
> Thanks again,
> RLT
I have a VB project showing how to receive byte-sized data and
combine bytes to form words, extract & act on individual bytes, etc,
here http://www.rentron.com/PicBasic/VB_PIC_TEMP.htm
-Bruce
tech@r...
RLT
--- In basicstamps@yahoogroups.com, <tech@r...> wrote:
> > Thanks, nice to have a second set of eyes.. I am assuming that
I'll
greater
together
> > in VB?
> > Thanks again,
> > RLT
> Regards,
> -Bruce
> tech@r...
and download Nuts & Volts article #89.
-- Jon Williams
-- Parallax
In a message dated 6/14/2003 4:31:33 PM Central Standard Time,
> Thanks, nice to have a second set of eyes.. I am assuming that I'll
> in VB?
> Thanks again,
> RLT
