Integer Math
There have been some posts on "Multiplication Overflow(Truncation)"
and I understand the concept within.
However, I have run into something with Integer math that I don't
understand. I too am working in VB to simulate integer math. I
have been very successful up to this point dealing with numbers >
65535 and < 0 and getting them to display as a BS2 would display
them.
The thing that questions me is when using this code...
a CON 65535
b CON a*a/2
DEBUG DEC b
I would think that the stamp would display zero, but it displays 1.
So here is what I come up with...
$FFFF * $FFFF = $FFFE0001
Truncated this equals 1.
Then dividing by 2 (1/2) this should equal 0.
But the Stamp insists that the result is one... [noparse];)[/noparse]
Can someone explain what is happening here?
Thank you,
Jared Hoylman
them.
a CON 65535
b CON a*a/2
DEBUG DEC b
Thank you,
Jared Hoylman
The result should be zero. But since the constants are calculated
at compile time this is most likely a compiler bug, correct?
DEBUG DEC 65535*65535/2
...does diaply zero.
But when calculated at compile time it results in a one...
Is this a compiler(tokenizer) bug?
[noparse][[/noparse]I am using v2.0 Beta 2]
Jared
--- In basicstamps@yahoogroups.com, "microextra" <microextra@y...>
(Truncation)"
> them.
> a CON 65535
> b CON a*a/2
> DEBUG DEC b
> Thank you,
> Jared Hoylman
b con a*a/2
it is the compiler does that computation, before it downloads the
program to the Stamp.
Run this:
a CON 65535
b var word
b = a*a/2 ' now, the Stamp computes this!
DEBUG DEC b ' the result is zero.
I would consider the thing you noticed a bug in the compiler (but not
in the Stamp!). The compiler should follow the truncation rules of
integer math when it precomputes those constants.
-- Tracy
>them.
>a CON 65535
>b CON a*a/2
>DEBUG DEC b
>Thank you,
>Jared Hoylman
Thanks for the quick answer. I agree with you that it is the
compiler that is wrong. I will forward this on to Parallax.
Thanks again,
Jared
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> That is interesting, but when you write,
> b con a*a/2
> Run this:
> a CON 65535
> b var word
not
of
> -- Tracy
(Truncation)"
> >them.
> >a CON 65535
> >b CON a*a/2
> >DEBUG DEC b
1.
> >Thank you,
> >Jared Hoylman
