Integer Math — Parallax Forums
Integer Math
edited 2003-06-04 02:16 in General Discussion
There have been some posts on "Multiplication Overflow(Truncation)"
and I understand the concept within.
However, I have run into something with Integer math that I don't
understand. I too am working in VB to simulate integer math. I
have been very successful up to this point dealing with numbers >
65535 and < 0 and getting them to display as a BS2 would display
them.
The thing that questions me is when using this code...
a CON 65535
b CON a*a/2
DEBUG DEC b
I would think that the stamp would display zero, but it displays 1.
So here is what I come up with...
$FFFF * $FFFF = $FFFE0001
Truncated this equals 1.
Then dividing by 2 (1/2) this should equal 0.
But the Stamp insists that the result is one... [noparse];)[/noparse]
Can someone explain what is happening here?
Thank you,
Jared Hoylman
    edited 2003-06-04 00:56
    OK, I think I am partially right in my first post.
    The result should be zero. But since the constants are calculated
    at compile time this is most likely a compiler bug, correct?
    DEBUG DEC 65535*65535/2
    ...does diaply zero.
    But when calculated at compile time it results in a one...
    Is this a compiler(tokenizer) bug?
    [noparse][[/noparse]I am using v2.0 Beta 2]
    Jared
    --- In basicstamps@yahoogroups.com, "microextra" <microextra@y...>
    (Truncation)"
    > them.
    > a CON 65535
    > b CON a*a/2
    > DEBUG DEC b
    > Thank you,
    > Jared Hoylman
    edited 2003-06-04 01:12
    That is interesting, but when you write,
    b con a*a/2
    it is the compiler does that computation, before it downloads the
    program to the Stamp.
    Run this:
    a CON 65535
    b var word
    b = a*a/2 ' now, the Stamp computes this!
    DEBUG DEC b ' the result is zero.
    I would consider the thing you noticed a bug in the compiler (but not
    in the Stamp!). The compiler should follow the truncation rules of
    integer math when it precomputes those constants.
    -- Tracy
    >them.
    >a CON 65535
    >b CON a*a/2
    >DEBUG DEC b
    >Thank you,
    >Jared Hoylman
    Tracy,
    Thanks for the quick answer. I agree with you that it is the
    compiler that is wrong. I will forward this on to Parallax.
    Thanks again,
    Jared
    > b con a*a/2
    > Run this:
    > a CON 65535
    > b var word
    not
    of
    > -- Tracy
    (Truncation)"
    > >them.
    > >a CON 65535
    > >b CON a*a/2
    > >DEBUG DEC b
    1.
    > >Thank you,
    > >Jared Hoylman
