A/D converter for a joystick
can anyone suggest a good a/d converter IC that works well with the
stamp? I was thinking of using the ADC0831CCN:
http://www.jameco.com/cgi-bin/ncommerce3/ProductDisplay?
prmenbr=91&prrfnbr=3029&cgrfnbr=501&ctgys=
it has two inputs which is what I need: I'm building a joystick which
uses potentiometers to encode joystick position, so I only need an x
and a y potentiometer. I saw some a/d converters with auto-calibrate
fetaures....would this be helpful in this type of application? Maybe
when the potentiometers wear down and give different resistances, the
auto-calibrate will help...? Thanks.
RCTIME function. Here's a link to an article that will show you how (Column #70
from Nuts & Volts "Stamp Applications):
<A
HREF="http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV70-Using_MAX72\
19_LED_Display_Driver_with_LEDs.pdf">
http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV70-Using_MAX7219_LED\
_Display_Driver_with_LEDs.pdf</A>
-- Jon Williams
-- Parallax
In a message dated 6/3/2003 11:11:19 AM Central Standard Time,
hard-on@t... writes:
temperature variations, since the basic stamp is going to be on an
underwater vehicle, the temperature will probably change a lot.. Will
an a/d converter IC have the same temperature problems?
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Technically, you can connect a joystick to the BASIC Stamp by using
the
how (Column #70
> <A
Using_MAX7219_LED_Display_Driver_with_LEDs.pdf">
Using_MAX7219_LED_Display_Driver_with_LEDs.pdf</A>
> -- Jon Williams
> -- Parallax
the
which
an x
calibrate
Maybe
the
