A/D converter for a joystick — Parallax Forums
edited 2003-06-03 19:35 in General Discussion
can anyone suggest a good a/d converter IC that works well with the
stamp? I was thinking of using the ADC0831CCN:
http://www.jameco.com/cgi-bin/ncommerce3/ProductDisplay?
prmenbr=91&prrfnbr=3029&cgrfnbr=501&ctgys=
it has two inputs which is what I need: I'm building a joystick which
uses potentiometers to encode joystick position, so I only need an x
and a y potentiometer. I saw some a/d converters with auto-calibrate
fetaures....would this be helpful in this type of application? Maybe
when the potentiometers wear down and give different resistances, the
auto-calibrate will help...? Thanks.
    edited 2003-06-03 17:41
    Technically, you can connect a joystick to the BASIC Stamp by using the
    RCTIME function. Here's a link to an article that will show you how (Column #70
    from Nuts & Volts "Stamp Applications):
    <A
    HREF="http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV70-Using_MAX72\
    19_LED_Display_Driver_with_LEDs.pdf
    http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV70-Using_MAX7219_LED\
    </A>
    -- Jon Williams
    -- Parallax
    In a message dated 6/3/2003 11:11:19 AM Central Standard Time,
    hard-on@t... writes:
    yeah, but I read that that way of doing it has problems with
    temperature variations, since the basic stamp is going to be on an
    underwater vehicle, the temperature will probably change a lot.. Will
    an a/d converter IC have the same temperature problems?
    the
    how (Column #70
    > <A
    Using_MAX7219_LED_Display_Driver_with_LEDs.pdf">
    Using_MAX7219_LED_Display_Driver_with_LEDs.pdf</A>
    > -- Jon Williams
    > -- Parallax
    the
    which
    an x
    calibrate
    Maybe
    the
