Color Sorting
I need to be able to detect the shade of some objects and I need to
find out what is the best way to do it. Here is the setup, I need to
sort some nuts (Walnuts) based on there darkness/lightness as they
pass by on a chute. They will be passing by on this chute at a high
rate of speed. Any suggestions would be alot of help.
Chris
Chris
http://www.keyence.com for the factory web site.
Jim
http://www.geocities.com/jimforkin2003/
Original Message
From: christopherjdunn [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CBi2i_SfHNf7Nrrg-xvLhJbhMgYOqWKX9RJcItG9GpSgRt265lzQCAkzveJtMH7Q3X-UYI0h4DoA]chrisd@d...[/url
Sent: Wednesday, May 21, 2003 3:09 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Color Sorting
Chris
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Chris
Hi Chris -
You might want to take a look at the Taos light to frequency chips found here:
http://www.taosinc.com/light_to_frequency.htm
Contacting Taos with your problem might be the best idea. They are familiar
with the capabilities of the Parallax Basic Stamp, and may be able to advise
you.
Hope that helps.
Bruce Bates
Original Message
From: christopherjdunn [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fkOjy9dTSlt4TQ0Z2Kk_eyNL6TxD8h9h7Yh6g6QyUHxXUlo3oKkwNunZkd9CRDtjnqCXWmiEb3qZesM]chrisd@d...[/url
Sent: Wednesday, May 21, 2003 2:09 PM
Chris
and Body of the message will be ignored.
Chris:
A lot depends on what is "high rate of speed."
Also, if you are attempting to determine e.g. ripeness, an optical
filter to restrict your measurement to some specific area of the
spectrum could improve the discrimination a lot.
As Bruce mentioned, the TAOS chip could work here, depending on what
your actual speed requirements are. Parallax even sells an accessory
board that is ideal for experiments. Using this device, you might be
able to do the "optical filtration" in software, as a ratio between
two colors or some more complicated manipulation of the raw RGB
values.
Reg Neale
