string to decimal
I am communicating with a digital scale via RS232 and using the
Serin command on my BS2. I am getting the info correctly but need
to convert it into decimal value. The script I use is
serData var byte(10)
again:
serin 15,16780,[noparse][[/noparse]STR serdata\9]
pause 50
debug cls, str serdata
goto again
on the debug screen I get +0056.25 which is the correct value (of
course this changes with the load on the scale), the question is how
can I turn this string into a decimal value so that I can use it
inside my script. I don't particularly care about the value after
the decimal value, but would be nice have it.
any help!
Al
again:
pause 50
goto again
any help!
Al
pretty easy:
whole = 0
whole = whole + ((serData(1) - "0") * 1000)
whole = whole + ((serData(2) - "0") * 100)
whole = whole + ((serData(3) - "0") * 10)
whole = whole + (serData(4) - "0")
frac = 0
frac = frac + ((serData(6) - "0") * 10)
frac = frac + (serData(7) - "0")
I'm sure somebody like Tracy or Al has a more elegant solution, but this will
work and is should be very easy for you to understand.
-- Jon Williams
-- Parallax
In a message dated 5/12/2003 5:35:16 PM Central Standard Time,
brownstamp@y... writes:
> again:
> pause 50
> goto again
> any help!
> Al
whole var word
i var nib
again:
whole = 0
pause 50
debug cls, dec whole
goto again
THe result is number 65078 irrelevent of the load! I know that the
scales is working!
Al
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> If your string is a fixed length and is structured as in your
example, it's
> pretty easy:
> whole = 0
> frac = 0
but this will
> -- Jon Williams
> -- Parallax
need
> > again:
> > pause 50
> > goto again
(of
how
after
> > any help!
> > Al
sleep for about 45 hours this weekend -- and I'm still not quite on my feet.
What you should be able to gleen is an approach to Ascii-to-decimal
conversion.
Check to see the positions of the data within the string, then make
adjustments where needed.
-- Jon Williams
-- Parallax
In a message dated 5/12/2003 8:29:00 PM Central Standard Time,
> Thanks Jon but your script didn't work. Here is how I used it:
> whole var word
> i var nib
> again:
> whole = 0
> pause 50
> goto again
> scales is working!
> Al
guess I shouldn't always take what you say as gospel! (but almost)
Al
> Okay, Al, I participated in a filmmaking "race" that had me going
without
on my feet.
decimal
> conversion.
make
> -- Jon Williams
> -- Parallax
> > whole var word
> > i var nib
> > again:
> > whole = 0
> > pause 50
> > goto again
the
> > scales is working!
> > Al
I VAR BYTE
MyVal VAR WORD
MyStr VAR BYTE(9)
MaxLen CON 5
MyVal = 0
FOR I = 0 TO MaxLen
MyVal = MyVal * 10
MyVal = MyVal + MyStr(I) - "0"
NEXT
This will work for any number of leading '0'.
You might want to use a 'while' loop, and stop
when you find the '.' character.
--- In basicstamps@yahoogroups.com, "brownstamp" <brownstamp@y...>
> again:
> pause 50
> goto again
how
> any help!
> Al
