string to decimal — Parallax Forums
string to decimal
edited 2003-05-13 14:50 in General Discussion
I am communicating with a digital scale via RS232 and using the
Serin command on my BS2. I am getting the info correctly but need
to convert it into decimal value. The script I use is
serData var byte(10)
again:
serin 15,16780,[noparse][[/noparse]STR serdata\9]
pause 50
debug cls, str serdata
goto again
on the debug screen I get +0056.25 which is the correct value (of
course this changes with the load on the scale), the question is how
can I turn this string into a decimal value so that I can use it
inside my script. I don't particularly care about the value after
the decimal value, but would be nice have it.
any help!
Al
    edited 2003-05-13 01:47
    If your string is a fixed length and is structured as in your example, it's
    pretty easy:
    whole = 0
    whole = whole + ((serData(1) - "0") * 1000)
    whole = whole + ((serData(2) - "0") * 100)
    whole = whole + ((serData(3) - "0") * 10)
    whole = whole + (serData(4) - "0")
    frac = 0
    frac = frac + ((serData(6) - "0") * 10)
    frac = frac + (serData(7) - "0")
    I'm sure somebody like Tracy or Al has a more elegant solution, but this will
    work and is should be very easy for you to understand.
    -- Jon Williams
    -- Parallax
    In a message dated 5/12/2003 5:35:16 PM Central Standard Time,
    brownstamp@y... writes:
    > again:
    > pause 50
    > goto again
    > any help!
    > Al
    edited 2003-05-13 02:26
    Thanks Jon but your script didn't work. Here is how I used it:
    whole var word
    i var nib
    again:
    whole = 0
    pause 50
    debug cls, dec whole
    goto again
    THe result is number 65078 irrelevent of the load! I know that the
    scales is working!
    Al
    example, it's
    > pretty easy:
    > whole = 0
    > frac = 0
    but this will
    > -- Jon Williams
    > -- Parallax
    need
    > > again:
    > > pause 50
    > > goto again
    (of
    how
    after
    > > any help!
    > > Al
    edited 2003-05-13 03:04
    Okay, Al, I participated in a filmmaking "race" that had me going without
    sleep for about 45 hours this weekend -- and I'm still not quite on my feet.
    What you should be able to gleen is an approach to Ascii-to-decimal
    conversion.
    Check to see the positions of the data within the string, then make
    adjustments where needed.
    -- Jon Williams
    -- Parallax
    In a message dated 5/12/2003 8:29:00 PM Central Standard Time,
    > whole var word
    > i var nib
    > again:
    > whole = 0
    > pause 50
    > goto again
    > scales is working!
    > Al
    edited 2003-05-13 03:24
    Sorry Jon, I should have been paying more attention. It works! I
    guess I shouldn't always take what you say as gospel! (but almost)
    Al
    without
    on my feet.
    decimal
    > conversion.
    make
    > -- Jon Williams
    > -- Parallax
    > > whole var word
    > > i var nib
    > > again:
    > > whole = 0
    > > pause 50
    > > goto again
    the
    > > scales is working!
    > > Al
    Perhaps more compact:
    I VAR BYTE
    MyVal VAR WORD
    MyStr VAR BYTE(9)
    MaxLen CON 5
    MyVal = 0
    FOR I = 0 TO MaxLen
    MyVal = MyVal * 10
    MyVal = MyVal + MyStr(I) - "0"
    NEXT
    This will work for any number of leading '0'.
    You might want to use a 'while' loop, and stop
    when you find the '.' character.
    --- In basicstamps@yahoogroups.com, "brownstamp" <brownstamp@y...>
    > again:
    > pause 50
    > goto again
    how
    > any help!
    > Al
