Control/monitor stamp thru web
Hello everyone,
I have some stamp based monitoring equipment at a remote location and am
thinking I would like to try to monitor and even control my equipment thru
the web. I was wondering what sites/books/etc you all thought would be
helpful. I am currently plugging away on google as well.
thanx
thanx
will find much info to help you outside of this forum and the
nutsandvolts columns on parallax.com.
I have an electric motor running some equipment in a remote
location. It has an off-the-shelf monitoring board already installed
that monitors for over current and high and low voltage on the line
(a problem in rural areas). If one of these events happen a relay on
the monitor trips. I am catching that event with the button
command. I have a BS2 with a cermatek modem and ds1302 realtime
clock. Every night at 2:00am, the BS2 dials out and calls me at
home. It leaves a message on the answering machine with one tone
pattern for OK and another tone pattern for a fault.
I am working on a second prototype now that will call and log on to
my linux server via modem and pass the status of all input pins to a
shell script that will post them to a database that can be accessed
via the web. I'm considering having the DS1302 update its time to
the time on the server while it's logged in too.
For a final version, I think I would connect to a standard external
modem, rather than a cermatek. I should be able to find old surplus
9600b modems that are inexpensive. Speed is no issue at all for an
application like this.
Dan
--- In basicstamps@yahoogroups.com, electronguy@a... wrote:
> Hello everyone,
and am
equipment thru
be
> thanx
from Quadravox), your system could actually leave you a voice message with
details. That would be very intersting indeed ... I may have to get my
Cermetek modem out of the box....
-- Jon Williams
-- Parallax
In a message dated 5/11/2003 2:26:39 PM Central Standard Time,
dcm1104@y... writes:
This is very interesting. I have some questions about the modem
because I wanted to get it myself. You need a phone line and it's
not wireless, correct? Also, when you get the modem, does it have
practice experiments to help you get started and develop what you
have done? Any additional info you can provide (websites/articles)
is greatly appreciated.
Chris
--- In basicstamps@yahoogroups.com, "dcm1104" <dcm1104@y...> wrote:
> I too have been working along similar lines... I don't think you
installed
line
on
to
a
accessed
to
external
surplus
an
> Dan
> > Hello everyone,
location
> and am
> equipment thru
would
> be
> > thanx
different about it is that it's tiny -- not much bigger than the
BS2. And you can interface with it without using any extra RS232
driver ICs (which is nice as it leaves the BS2s serial pins available
for using debug and program download).
This link has most of the info you will need:
http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV60-
Calling_All_Stamps.pdf
and
www.cermetek.com has some more details.
It is on sale now at parallax.com for $39! Cheap!
--- In basicstamps@yahoogroups.com, "christopher41877" <CHRIS@R...>
wrote:
> Dan,
> Chris
> installed
> line
relay
> on
> to
to
> a
> accessed
> to
> external
> surplus
> an
> > Dan
> > > Hello everyone,
> location
> > and am
> > equipment thru
> would
> > be
> > > thanx
That was my thinking originally. I have the quadravox module
gathering dust on my shelf. I had to finish the project in a hurry
and didn't have time to get that part integrated in. I was able to
convey what I needed by just using some dtmf tones after the
answering machine picks up. I may end up building quite a few of them
for other people who have expressed interest in the concept, and the
quadravox may be an option.
Thanks to you for your columns. I was able to get this project
running in no time at all with help from nuts and volts #60.
Dan
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> That's an interesting concept. It seems that with a bit more
hardware (like
message with
get my
> -- Jon Williams
> -- Parallax
installed
line
relay on
telezapper and insult callers from known telemarketing prefixes would be a
good Stamp project.
Does the Cermetek modem do caller ID?
> hardware (like
> message with
> get my
> Hey, a smart answering machine / caller ID box that would act as a
would be a
> good Stamp project.
I don't believe the 1786 does, but I'm not 100% sure.
However, the new Stamp 2 interfacing book
has an interface for a caller ID chip.
The book is available from Parallax.
The Cermetek does do everything else a
1200 baud modem 1 inch square should do.
Namely, dial out, allow dialing in,
answer the phone, talk to other modems,
send DTMF tones, and send pager messages
to a pager service.
would be a
> good Stamp project.
hurry
to
them
the
> > hardware (like
> > message with
> > get my
