Control/monitor stamp thru web — Parallax Forums
edited 2003-05-12 15:34 in General Discussion
Hello everyone,
I have some stamp based monitoring equipment at a remote location and am
thinking I would like to try to monitor and even control my equipment thru
the web. I was wondering what sites/books/etc you all thought would be
helpful. I am currently plugging away on google as well.
thanx
    edited 2003-05-11 20:25
    I too have been working along similar lines... I don't think you
    will find much info to help you outside of this forum and the
    nutsandvolts columns on parallax.com.
    I have an electric motor running some equipment in a remote
    location. It has an off-the-shelf monitoring board already installed
    that monitors for over current and high and low voltage on the line
    (a problem in rural areas). If one of these events happen a relay on
    the monitor trips. I am catching that event with the button
    command. I have a BS2 with a cermatek modem and ds1302 realtime
    clock. Every night at 2:00am, the BS2 dials out and calls me at
    home. It leaves a message on the answering machine with one tone
    pattern for OK and another tone pattern for a fault.
    I am working on a second prototype now that will call and log on to
    my linux server via modem and pass the status of all input pins to a
    shell script that will post them to a database that can be accessed
    via the web. I'm considering having the DS1302 update its time to
    the time on the server while it's logged in too.
    For a final version, I think I would connect to a standard external
    modem, rather than a cermatek. I should be able to find old surplus
    9600b modems that are inexpensive. Speed is no issue at all for an
    application like this.
    Dan
    --- In basicstamps@yahoogroups.com, electronguy@a... wrote:
    > Hello everyone,
    and am
    equipment thru
    be
    > thanx
    edited 2003-05-11 20:31
    That's an interesting concept. It seems that with a bit more hardware (like
    from Quadravox), your system could actually leave you a voice message with
    details. That would be very intersting indeed ... I may have to get my
    Cermetek modem out of the box....
    -- Jon Williams
    -- Parallax
    In a message dated 5/11/2003 2:26:39 PM Central Standard Time,
    dcm1104@y... writes:
    edited 2003-05-11 22:05
    Dan,
    This is very interesting. I have some questions about the modem
    because I wanted to get it myself. You need a phone line and it's
    not wireless, correct? Also, when you get the modem, does it have
    practice experiments to help you get started and develop what you
    have done? Any additional info you can provide (websites/articles)
    is greatly appreciated.
    Chris
    installed
    line
    on
    to
    a
    accessed
    to
    external
    surplus
    an
    > Dan
    > > Hello everyone,
    location
    > and am
    > equipment thru
    would
    > be
    > > thanx
    edited 2003-05-12 04:24
    Yes. It's a standard phone line modem, albeit a slow one. What's
    different about it is that it's tiny -- not much bigger than the
    BS2. And you can interface with it without using any extra RS232
    driver ICs (which is nice as it leaves the BS2s serial pins available
    for using debug and program download).
    This link has most of the info you will need:
    http://www.parallax.com/Downloads/Documentation/nv/v2/col/NV60-
    Calling_All_Stamps.pdf
    and
    www.cermetek.com has some more details.
    It is on sale now at parallax.com for $39! Cheap!
    --- In basicstamps@yahoogroups.com, "christopher41877" <CHRIS@R...>
    wrote:
    > Dan,
    > Chris
    > installed
    > line
    relay
    > on
    > to
    to
    > a
    > accessed
    > to
    > external
    > surplus
    > an
    > > Dan
    > > > Hello everyone,
    > location
    > > and am
    > > equipment thru
    > would
    > > be
    > > > thanx
    edited 2003-05-12 04:36
    Jon:
    That was my thinking originally. I have the quadravox module
    gathering dust on my shelf. I had to finish the project in a hurry
    and didn't have time to get that part integrated in. I was able to
    convey what I needed by just using some dtmf tones after the
    answering machine picks up. I may end up building quite a few of them
    for other people who have expressed interest in the concept, and the
    quadravox may be an option.
    Thanks to you for your columns. I was able to get this project
    running in no time at all with help from nuts and volts #60.
    Dan
    hardware (like
    message with
    get my
    > -- Jon Williams
    > -- Parallax
    installed
    line
    relay on
    edited 2003-05-12 04:38
    Hey, a smart answering machine / caller ID box that would act as a
    telezapper and insult callers from known telemarketing prefixes would be a
    good Stamp project.
    Does the Cermetek modem do caller ID?
    > hardware (like
    > message with
    > get my
    edited 2003-05-12 04:53
    would be a
    > good Stamp project.
    I don't believe the 1786 does, but I'm not 100% sure.
    No, the Cermetek does not do caller ID.
    However, the new Stamp 2 interfacing book
    has an interface for a caller ID chip.
    The book is available from Parallax.
    The Cermetek does do everything else a
    1200 baud modem 1 inch square should do.
    Namely, dial out, allow dialing in,
    answer the phone, talk to other modems,
    send DTMF tones, and send pager messages
    to a pager service.
    would be a
    > good Stamp project.
    hurry
    to
    them
    the
    > > hardware (like
    > > message with
    > > get my
