Rf transmission
If i may insert a word of caution.
Using a antenna on a hobby tranmitter such as being discussed can lead
you down the rosie path to big trouble.
The 434 mhz frequency is in the amateur radio (ham) band and (1) must
accept "all" interference from licensed users and (2) can not give
"any" interference to licensed users. Hams usually run 50 watts or
more on those frequencys including wideband tv.
Also there are certain quite zones concerning the 400-450 mhz band in
the u.s.a in which if violated will bring down fcc and other agencys
on your head immeadiatly. New mexico area and west virginia must be
extremely carefull.
If a complaint is registered with the fcc and they can can and will
find you then they can confiscate all of your associated equipment.
I would suggest that you might consider using multiple transeivers in
the areas needing coverage if that is possible.
73
spence
k4kep ex w9qni
extremely carefull.
73
spence
k4kep ex w9qni
and the receiver on a bs1. I used to be able to transmit data, then I
left the system alone for a week and now it doesn't transfer
information via rf anymore. The only time I receive information at
the receiver end is right when I power up the bs2sx (transmitter
attached) or when I tap either the transmitter or receiver antenna
with my fingers. But all that gets transfered when I do any of the
above things is 255 255 255 or 0 0 0 (depending on if I have it set
to true or inverted transmission).
So it sounds like the transmitter isn't working, right? Is there a
way I could hook up leds or somehow see if the transmitter is
transmitting data? Does anyone have any other suggestions? Thanks.
sounds like you have a near dead battery! You need to check that rf is
being transmitted first of all. You need a device to detect rf. You could
use a scanner or even a simple diode attached to an antenna wire feeding a
sensitive meter or even an oscilloscope. To build a simple rf probe, attach
one end of a wire aprox 5.5 inches long to the anode of a 1N4148 diode.
Attach the other lead of the diode (cathode) to the + terminal of a uA
meter. Across the meter, attach a 470 pF capacitor. Connect the - lead of
the meter to another 5.5 inch wire. Arrange the wires like a dipole and
while holding the meter case, trigger the rf from the transmitter and you
should see an indication on the meter that should increase as you get nearer
the transmitter and decrease as you move away. It's crude and only gives
relative indications, but it works when nothing else is available. If you
see rf being produced, then you can concentrate on finding data troubles.
Jim
http://www.geocities.com/jimforkin2003/
Original Message
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=59CJjBhh1bHMMyV0MJ1npFtGxdPSU6FtNDSImu4KJx3Kxi99JQRbOeeHD-RIVwNOI1ABto0UXaDt]hard-on@t...[/url
Sent: Wednesday, April 30, 2003 2:05 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] rf transmission
Hi, I have an rws/tws-434 pair. I have the transmitter on the bas2sx
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
writes:
> Sam,
> could
> attach
> nearer
I know almost nothing about RF....but, could you also use a cheap hand held
AM transistor radio to detect the RF?
Jonathan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, May 01, 2003 7:57 AM
Subject: Re: [noparse][[/noparse]basicstamps] rf transmission
> In a message dated 5/1/2003 7:53:52 AM Pacific Daylight Time,
jjf@p...
> writes:
> > Sam,
> > could
a
> > attach
of
you
> > nearer
gives
you
troubles.
held
I'm using an ac-dc adaptor for both basic stamps (transmitter
connected to a bs2sx, receiver connected to a bs1), so power is not
an issue.
I increased the antenna size and now I'm getting a stream of 0s
received at the receiver whenever the transmitter/bs2sx is on. I get
nothing at the receiver when the transmitter/bs2sx is turned off. So
it seems that 0s are indeed being sent from the transmitter to the
receiver, but I can't send any other numbers.
I've tried using the linear and serial outputs of the receiver, and
I've checked the antenna connections. I've tried different resistor
values between the receiver output and the basic stamp (including no
resistor), and none of it makes a difference.
--- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
> Sam,
rf is
You could
feeding a
probe, attach
diode.
uA
lead of
dipole and
and you
get nearer
gives
If you
troubles.
> Jim
Original Message
> From: Sam [noparse][[/noparse]mailto:hard-on@t...]
I
Subject and
between your sx and bs1 does the info transfer ??
1. are you sending at 2400 ( real good place to start )
2. are your modes matched and are they both inverted
3. sx has different mode values I think
Larry Gaminde
Original Message
Sent: May 01, 2003 8:39 AM
Subject: [noparse][[/noparse]basicstamps] Re: rf transmission
> Progress(but still not working):
> an issue.
> > Sam,
> rf is
> You could
> feeding a
> probe, attach
> diode.
> uA
> lead of
> dipole and
> and you
> get nearer
> gives
> If you
> troubles.
> > Jim
Original Message
> I
> Subject and
on a computer you may have to use a rs232 to ttl
converter fire up a terminal program at least you
will see exactly what is going in and whats comming
out then hook the stamps up one at a time.
> (transmitter
> so power is not
> an issue.
> stream of 0s
> is turned off. So
> transmitter to the
> the receiver, and
> different resistor
> stamp (including no
> <jjf@p...> wrote:
> > Sam,
> need to check that
> rf is
> You could
> an antenna wire
> feeding a
> a simple rf
> probe, attach
> anode of a 1N4148
> diode.
> the + terminal of a
> uA
> lead of
> wires like a
> dipole and
> the transmitter
> and you
> increase as you
> get nearer
> It's crude and only
> gives
> else is available.
> If you
> finding data
> troubles.
> > Jim
Original Message
> transmit data, then
> I
> doesn't transfer
> bs2sx (transmitter
> receiver antenna
> I do any of the
> if I have it set
> right? Is there a
> transmitter is
> Text in the
> Subject and
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
Sounds like it might be baud rates or something. Make sure that you look up
the correct number, the 2sx is different for the BS2, which is what the
sample code for the unit uses, I think.
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, May 01, 2003 8:39 AM
> an issue.
> > Sam,
> rf is
> You could
> feeding a
> probe, attach
> diode.
> uA
> lead of
> dipole and
> and you
> get nearer
> gives
> If you
> troubles.
> > Jim
Original Message
> I
> Subject and
resistor because I read it was only needed if you send data
inverted). I then monitored the bs1's input, it got nothing until the
bs2sx was turned on. when the bs2sx was turned on, the bs1 kept
getting 255's (true) or 0's (inverted) even though the bs2sx was
sending the numbers 50 and 180. I used both 2400 and 600 baud rates,
same thing for both. This is bizarre... I'm making sure that the baud
rates are the same on both stamps (different codes for each) and that
they are both true or inverted...
--- In basicstamps@yahoogroups.com, "Larry Gaminde" <lgaminde@t...>
wrote:
> One step at a time, if you remove the TX and RX units hook a 10k
resistor
> Larry Gaminde
Original Message
> From: "Sam" <hard-on@t...>
not
> > an issue.
get
So
and
resistor
no
> > > Sam,
that
> > rf is
rf.
> > You could
> > feeding a
> > probe, attach
> > diode.
of a
> > uA
the -
> > lead of
> > dipole and
transmitter
> > and you
you
> > get nearer
only
> > gives
available.
> > If you
> > troubles.
> > > Jim
Original Message
bas2sx
then
> > I
at
antenna
the
set
there a
Thanks.
> > Subject and
Subject and
1. USE THE 10k . ( what if you hooked things up wrong even just for a
second)
2. Stick with the inverted only .
3. program simple serial out and in instructions, using something like below
and the bs1 connected to the computer using serial in and DEBUG (never
used a bs1 is this possable) .
for i = 0 to 255
serout 1,2,3, [noparse][[/noparse]i]
pause 700
next i
Larry Gaminde
Original Message
Sent: May 01, 2003 11:18 AM
> I connected a bs2sx output pin directly to a bs1 input pin (no 10k
> resistor
> > Larry Gaminde
Original Message
> not
> > > an issue.
> get
> So
> and
> resistor
> no
> > > > Sam,
> that
> > > rf is
> rf.
> > > You could
> > > feeding a
> > > probe, attach
> > > diode.
> of a
> > > uA
> the -
> > > lead of
> > > dipole and
> transmitter
> > > and you
> you
> > > get nearer
> only
> > > gives
> available.
> > > If you
> > > troubles.
> > > > Jim
Original Message
> bas2sx
> then
> > > I
> at
> antenna
> the
> set
> there a
> Thanks.
> > > Subject and
> Subject and
Use the 10k (take it from someone who has smoked more chips than
cigarettes)
Larry Gaminde
Original Message
Sent: May 01, 2003 11:51 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: rf transmission
> Ok you now getting to a point of finding out what is wrong
> second)
below
> for i = 0 to 255
> pause 700
> next i
> Larry Gaminde
Original Message
> > resistor
> > > Larry Gaminde
Original Message
> > not
> > > > an issue.
> > get
> > So
> > and
> > resistor
> > no
> > > > > Sam,
> > that
> > > > rf is
> > rf.
> > > > You could
> > > > feeding a
> > > > probe, attach
> > > > diode.
> > of a
> > > > uA
> > the -
> > > > lead of
> > > > dipole and
> > transmitter
> > > > and you
> > you
> > > > get nearer
> > only
> > > > gives
> > available.
> > > > If you
> > > > troubles.
> > > > > Jim
Original Message
> > bas2sx
> > then
> > > > I
> > at
> > antenna
> > the
> > set
> > there a
> > Thanks.
> > > > Subject and
> > Subject and
and
Big concern if you have two way serial going on... One stamp driving a 0,
one stamp driving a 1, *poof*, tons of smoke - two dead stamps - Yuk.
- Robert
Original Message
Sent: Thursday, May 01, 2003 12:58 PM
| Oh by the way
| cigarettes)
| Larry Gaminde
Original Message
| > second)
| below
| > for i = 0 to 255
| > pause 700
| > next i
| > Larry Gaminde
Original Message
| > > resistor
| > > > Larry Gaminde
Original Message
| > > not
| > > > > an issue.
| > > get
| > > So
| > > and
| > > resistor
| > > no
| > > > > > Sam,
| > > that
| > > > > rf is
| > > rf.
| > > > > You could
| > > > > feeding a
| > > > > probe, attach
| > > > > diode.
| > > of a
| > > > > uA
| > > the -
| > > > > lead of
| > > > > dipole and
| > > transmitter
| > > > > and you
| > > you
| > > > > get nearer
| > > only
| > > > > gives
| > > available.
| > > > > If you
| > > > > troubles.
| > > > > > Jim
Original Message
| > > bas2sx
| > > then
| > > > > I
| > > at
| > > antenna
| > > the
| > > set
| > > there a
| > > Thanks.
| > > > > Subject and
| > > Subject and
| and
and
trying to keep the current below 20 mA, which
is within the Stamp's pin limit.
When doing bi-directional comm on one pin,
there will almost ALWAYS be times when one just
stopped talking, and the other one now wants
to start talking, and drives the pin before
the other lets go.
--- In basicstamps@yahoogroups.com, "Robert Ussery" <uavscience@f...>
wrote:
> Is the 10k mostly to prevent excess current from a bus fight?
driving a 0,
Yuk.
> - Robert
Original Message
> From: "Larry Gaminde" <lgaminde@t...>
> | Oh by the way
> | cigarettes)
> | Larry Gaminde
Original Message
just for a
> | > second)
something like
> | below
DEBUG (never
> | > for i = 0 to 255
> | > pause 700
> | > next i
> | > Larry Gaminde
Original Message
(no 10k
until the
kept
was
rates,
the baud
and that
<lgaminde@t...>
a 10k
> | > > resistor
> | > > > Larry Gaminde
Original Message
(transmitter
power is
> | > > not
> | > > > > an issue.
of 0s
is on. I
> | > > get
turned off.
> | > > So
transmitter to the
receiver,
> | > > and
> | > > resistor
(including
> | > > no
<jjf@p...> wrote:
> | > > > > > Sam,
check
> | > > that
> | > > > > rf is
detect
> | > > rf.
> | > > > > You could
antenna wire
> | > > > > feeding a
simple rf
> | > > > > probe, attach
a 1N4148
> | > > > > diode.
terminal
> | > > of a
> | > > > > uA
Connect
> | > > the -
> | > > > > lead of
like a
> | > > > > dipole and
> | > > transmitter
> | > > > > and you
increase as
> | > > you
> | > > > > get nearer
crude and
> | > > only
> | > > > > gives
> | > > available.
> | > > > > If you
finding data
> | > > > > troubles.
> | > > > > > Jim
Original Message
on the
> | > > bas2sx
transmit data,
> | > > then
> | > > > > I
transfer
information
> | > > at
(transmitter
receiver
> | > > antenna
any of
> | > > the
have it
> | > > set
Is
> | > > there a
transmitter is
suggestions?
> | > > Thanks.
in the
> | > > > > Subject and
the
> | > > Subject and
Subject
> | and
Subject
> and
Subject and
