Rf transmission — Parallax Forums
Rf transmission
edited 2003-05-01 20:40 in General Discussion
If i may insert a word of caution.
Using a antenna on a hobby tranmitter such as being discussed can lead
you down the rosie path to big trouble.
The 434 mhz frequency is in the amateur radio (ham) band and (1) must
accept "all" interference from licensed users and (2) can not give
"any" interference to licensed users. Hams usually run 50 watts or
more on those frequencys including wideband tv.
Also there are certain quite zones concerning the 400-450 mhz band in
the u.s.a in which if violated will bring down fcc and other agencys
on your head immeadiatly. New mexico area and west virginia must be
extremely carefull.
If a complaint is registered with the fcc and they can can and will
find you then they can confiscate all of your associated equipment.
I would suggest that you might consider using multiple transeivers in
the areas needing coverage if that is possible.
73
spence
k4kep ex w9qni
    edited 2003-04-30 19:05
    Hi, I have an rws/tws-434 pair. I have the transmitter on the bas2sx
    and the receiver on a bs1. I used to be able to transmit data, then I
    left the system alone for a week and now it doesn't transfer
    information via rf anymore. The only time I receive information at
    the receiver end is right when I power up the bs2sx (transmitter
    attached) or when I tap either the transmitter or receiver antenna
    with my fingers. But all that gets transfered when I do any of the
    above things is 255 255 255 or 0 0 0 (depending on if I have it set
    to true or inverted transmission).
    So it sounds like the transmitter isn't working, right? Is there a
    way I could hook up leds or somehow see if the transmitter is
    transmitting data? Does anyone have any other suggestions? Thanks.
    edited 2003-05-01 15:39
    Sam,
    sounds like you have a near dead battery! You need to check that rf is
    being transmitted first of all. You need a device to detect rf. You could
    use a scanner or even a simple diode attached to an antenna wire feeding a
    sensitive meter or even an oscilloscope. To build a simple rf probe, attach
    one end of a wire aprox 5.5 inches long to the anode of a 1N4148 diode.
    Attach the other lead of the diode (cathode) to the + terminal of a uA
    meter. Across the meter, attach a 470 pF capacitor. Connect the - lead of
    the meter to another 5.5 inch wire. Arrange the wires like a dipole and
    while holding the meter case, trigger the rf from the transmitter and you
    should see an indication on the meter that should increase as you get nearer
    the transmitter and decrease as you move away. It's crude and only gives
    relative indications, but it works when nothing else is available. If you
    see rf being produced, then you can concentrate on finding data troubles.
    Jim
    http://www.geocities.com/jimforkin2003/
    From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=59CJjBhh1bHMMyV0MJ1npFtGxdPSU6FtNDSImu4KJx3Kxi99JQRbOeeHD-RIVwNOI1ABto0UXaDt]hard-on@t...[/url
    Sent: Wednesday, April 30, 2003 2:05 PM
    Subject: [noparse][[/noparse]basicstamps] rf transmission
    edited 2003-05-01 15:57
    In a message dated 5/1/2003 7:53:52 AM Pacific Daylight Time, jjf@p...
    writes:
    > Sam,
    > could
    > attach
    > nearer
    I know almost nothing about RF....but, could you also use a cheap hand held
    AM transistor radio to detect the RF?
    edited 2003-05-01 16:09
    No, the units he has operate at 433mHz, way above AM radio frequency.
    Jonathan
    Sent: Thursday, May 01, 2003 7:57 AM
    Subject: Re: [noparse][[/noparse]basicstamps] rf transmission
    jjf@p...
    > writes:
    > > Sam,
    > > could
    a
    > > attach
    of
    you
    > > nearer
    gives
    you
    troubles.
    held
    edited 2003-05-01 16:39
    Progress(but still not working):
    I'm using an ac-dc adaptor for both basic stamps (transmitter
    connected to a bs2sx, receiver connected to a bs1), so power is not
    an issue.
    I increased the antenna size and now I'm getting a stream of 0s
    received at the receiver whenever the transmitter/bs2sx is on. I get
    nothing at the receiver when the transmitter/bs2sx is turned off. So
    it seems that 0s are indeed being sent from the transmitter to the
    receiver, but I can't send any other numbers.
    I've tried using the linear and serial outputs of the receiver, and
    I've checked the antenna connections. I've tried different resistor
    values between the receiver output and the basic stamp (including no
    resistor), and none of it makes a difference.
    --- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
    > Sam,
    rf is
    You could
    feeding a
    probe, attach
    diode.
    uA
    lead of
    dipole and
    and you
    get nearer
    gives
    If you
    troubles.
    > Jim
    > From: Sam [noparse][[/noparse]mailto:hard-on@t...]
    I
    Subject and
    edited 2003-05-01 17:03
    One step at a time, if you remove the TX and RX units hook a 10k resistor
    between your sx and bs1 does the info transfer ??
    1. are you sending at 2400 ( real good place to start )
    2. are your modes matched and are they both inverted
    3. sx has different mode values I think
    Larry Gaminde
    Sent: May 01, 2003 8:39 AM
    Subject: [noparse][[/noparse]basicstamps] Re: rf transmission
    > an issue.
    > > Sam,
    > rf is
    > You could
    > feeding a
    > probe, attach
    > diode.
    > uA
    > lead of
    > dipole and
    > and you
    > get nearer
    > gives
    > If you
    > troubles.
    > > Jim
    > I
    > Subject and
    edited 2003-05-01 17:42
    just a idea why not hook both up to a serial port
    on a computer you may have to use a rs232 to ttl
    converter fire up a terminal program at least you
    will see exactly what is going in and whats comming
    out then hook the stamps up one at a time.
    > (transmitter
    > so power is not
    > an issue.
    > stream of 0s
    > is turned off. So
    > transmitter to the
    > the receiver, and
    > different resistor
    > stamp (including no
    > <jjf@p...> wrote:
    > > Sam,
    > need to check that
    > rf is
    > You could
    > an antenna wire
    > feeding a
    > a simple rf
    > probe, attach
    > anode of a 1N4148
    > diode.
    > the + terminal of a
    > uA
    > lead of
    > wires like a
    > dipole and
    > the transmitter
    > and you
    > increase as you
    > get nearer
    > It's crude and only
    > gives
    > else is available.
    > If you
    > finding data
    > troubles.
    > > Jim
    > transmit data, then
    > I
    > doesn't transfer
    > bs2sx (transmitter
    > receiver antenna
    > I do any of the
    > if I have it set
    > right? Is there a
    > transmitter is
    > Text in the
    > Subject and
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________
    Do you Yahoo!?
    The New Yahoo! Search - Faster. Easier. Bingo.
    http://search.yahoo.com
    edited 2003-05-01 18:03
    Sam,
    Sounds like it might be baud rates or something. Make sure that you look up
    the correct number, the 2sx is different for the BS2, which is what the
    sample code for the unit uses, I think.
    Jonathan
    www.madlabs.info
    Sent: Thursday, May 01, 2003 8:39 AM
    > an issue.
    > > Sam,
    > rf is
    > You could
    > feeding a
    > probe, attach
    > diode.
    > uA
    > lead of
    > dipole and
    > and you
    > get nearer
    > gives
    > If you
    > troubles.
    > > Jim
    > I
    > Subject and
    edited 2003-05-01 19:18
    I connected a bs2sx output pin directly to a bs1 input pin (no 10k
    resistor because I read it was only needed if you send data
    inverted). I then monitored the bs1's input, it got nothing until the
    bs2sx was turned on. when the bs2sx was turned on, the bs1 kept
    getting 255's (true) or 0's (inverted) even though the bs2sx was
    sending the numbers 50 and 180. I used both 2400 and 600 baud rates,
    same thing for both. This is bizarre... I'm making sure that the baud
    rates are the same on both stamps (different codes for each) and that
    they are both true or inverted...
    --- In basicstamps@yahoogroups.com, "Larry Gaminde" <lgaminde@t...>
    resistor
    > Larry Gaminde
    > From: "Sam" <hard-on@t...>
    not
    > > an issue.
    get
    So
    and
    resistor
    no
    > > > Sam,
    that
    > > rf is
    rf.
    > > You could
    > > feeding a
    > > probe, attach
    > > diode.
    of a
    > > uA
    the -
    > > lead of
    > > dipole and
    transmitter
    > > and you
    you
    > > get nearer
    only
    > > gives
    available.
    > > If you
    > > troubles.
    > > > Jim
    bas2sx
    then
    > > I
    at
    antenna
    the
    set
    there a
    Thanks.
    > > Subject and
    Subject and
    edited 2003-05-01 19:51
    Ok you now getting to a point of finding out what is wrong
    1. USE THE 10k . ( what if you hooked things up wrong even just for a
    second)
    2. Stick with the inverted only .
    3. program simple serial out and in instructions, using something like below
    and the bs1 connected to the computer using serial in and DEBUG (never
    used a bs1 is this possable) .
    for i = 0 to 255
    serout 1,2,3, [noparse][[/noparse]i]
    pause 700
    next i
    Larry Gaminde
    Sent: May 01, 2003 11:18 AM
    > resistor
    > > Larry Gaminde
    > not
    > > > an issue.
    > get
    > So
    > and
    > resistor
    > no
    > > > > Sam,
    > that
    > > > rf is
    > rf.
    > > > You could
    > > > feeding a
    > > > probe, attach
    > > > diode.
    > of a
    > > > uA
    > the -
    > > > lead of
    > > > dipole and
    > transmitter
    > > > and you
    > you
    > > > get nearer
    > only
    > > > gives
    > available.
    > > > If you
    > > > troubles.
    > > > > Jim
    > bas2sx
    > then
    > > > I
    > at
    > antenna
    > the
    > set
    > there a
    > Thanks.
    > > > Subject and
    > Subject and
    edited 2003-05-01 19:58
    Oh by the way
    Use the 10k (take it from someone who has smoked more chips than
    cigarettes)
    Larry Gaminde
    Sent: May 01, 2003 11:51 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: rf transmission
    > second)
    below
    > for i = 0 to 255
    > pause 700
    > next i
    > Larry Gaminde
    > > resistor
    > > > Larry Gaminde
    > > not
    > > > > an issue.
    > > get
    > > So
    > > and
    > > resistor
    > > no
    > > > > > Sam,
    > > that
    > > > > rf is
    > > rf.
    > > > > You could
    > > > > feeding a
    > > > > probe, attach
    > > > > diode.
    > > of a
    > > > > uA
    > > the -
    > > > > lead of
    > > > > dipole and
    > > transmitter
    > > > > and you
    > > you
    > > > > get nearer
    > > only
    > > > > gives
    > > available.
    > > > > If you
    > > > > troubles.
    > > > > > Jim
    > > bas2sx
    > > then
    > > > > I
    > > at
    > > antenna
    > > the
    > > set
    > > there a
    > > Thanks.
    > > > > Subject and
    > > Subject and
    and
    edited 2003-05-01 20:26
    Is the 10k mostly to prevent excess current from a bus fight?
    Big concern if you have two way serial going on... One stamp driving a 0,
    one stamp driving a 1, *poof*, tons of smoke - two dead stamps - Yuk.
    - Robert
    Sent: Thursday, May 01, 2003 12:58 PM
    | Oh by the way
    | cigarettes)
    | Larry Gaminde
    | > second)
    | below
    | > for i = 0 to 255
    | > pause 700
    | > next i
    | > Larry Gaminde
    | > > resistor
    | > > > Larry Gaminde
    | > > not
    | > > > > an issue.
    | > > get
    | > > So
    | > > and
    | > > resistor
    | > > no
    | > > > > > Sam,
    | > > that
    | > > > > rf is
    | > > rf.
    | > > > > You could
    | > > > > feeding a
    | > > > > probe, attach
    | > > > > diode.
    | > > of a
    | > > > > uA
    | > > the -
    | > > > > lead of
    | > > > > dipole and
    | > > transmitter
    | > > > > and you
    | > > you
    | > > > > get nearer
    | > > only
    | > > > > gives
    | > > available.
    | > > > > If you
    | > > > > troubles.
    | > > > > > Jim
    | > > bas2sx
    | > > then
    | > > > > I
    | > > at
    | > > antenna
    | > > the
    | > > set
    | > > there a
    | > > Thanks.
    | > > > > Subject and
    | > > Subject and
    | and
    and
    Yes. Although 220 ohm is sufficient -- you're
    trying to keep the current below 20 mA, which
    is within the Stamp's pin limit.
    When doing bi-directional comm on one pin,
    there will almost ALWAYS be times when one just
    stopped talking, and the other one now wants
    to start talking, and drives the pin before
    the other lets go.
    --- In basicstamps@yahoogroups.com, "Robert Ussery" <uavscience@f...>
    driving a 0,
    Yuk.
    > - Robert
    > From: "Larry Gaminde" <lgaminde@t...>
    > | Oh by the way
    > | cigarettes)
    > | Larry Gaminde
    just for a
    > | > second)
    something like
    > | below
    DEBUG (never
    > | > for i = 0 to 255
    > | > pause 700
    > | > next i
    > | > Larry Gaminde
    (no 10k
    until the
    kept
    was
    rates,
    the baud
    and that
    <lgaminde@t...>
    a 10k
    > | > > resistor
    > | > > > Larry Gaminde
    (transmitter
    power is
    > | > > not
    > | > > > > an issue.
    of 0s
    is on. I
    > | > > get
    turned off.
    > | > > So
    transmitter to the
    receiver,
    > | > > and
    > | > > resistor
    (including
    > | > > no
    <jjf@p...> wrote:
    > | > > > > > Sam,
    check
    > | > > that
    > | > > > > rf is
    detect
    > | > > rf.
    > | > > > > You could
    antenna wire
    > | > > > > feeding a
    simple rf
    > | > > > > probe, attach
    a 1N4148
    > | > > > > diode.
    terminal
    > | > > of a
    > | > > > > uA
    Connect
    > | > > the -
    > | > > > > lead of
    like a
    > | > > > > dipole and
    > | > > transmitter
    > | > > > > and you
    increase as
    > | > > you
    > | > > > > get nearer
    crude and
    > | > > only
    > | > > > > gives
    > | > > available.
    > | > > > > If you
    finding data
    > | > > > > troubles.
    > | > > > > > Jim
    on the
    > | > > bas2sx
    transmit data,
    > | > > then
    > | > > > > I
    transfer
    information
    > | > > at
    (transmitter
    receiver
    > | > > antenna
    any of
    > | > > the
    have it
    > | > > set
    Is
    > | > > there a
    transmitter is
    suggestions?
    > | > > Thanks.
    in the
    > | > > > > Subject and
    the
    > | > > Subject and
    Subject
    > | and
    Subject
    > and
    Subject and
