Two quick questions - ADC inputs and overheating
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> Where should the resistor go?
Often one puts a resistor between the circuit being senced and the
ADC input. that way, the current is limited to some small value.
you would need to check to make sure the current was high enough that
it could drive the ADC input.
And you would need to make sure it was included in any calcs for
voltage drop thru the ADC. In some cases, the ADC acts like a
voltage divider so adding another resistor might change the expected
output requiring a little software offset.
Dave
Original Message
> From: Dave Mucha [noparse][[/noparse]mailto:davemucha@j...]
> Sent: Tuesday, April 29, 2003 9:15 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: Two quick questions
> did you put in a 10K resistor to limit the current ?
> are you measuring direct or thru a voltage divider ?
> Dave
> wrote:
> > The adc was hot, I have a board of education so the board and
stamp
> were
> > being run by a 9v battery, and the adc was connected to the
battery
> that
> > my robot is going to use.
Original Message
> > From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
> > Sent: Tuesday, April 29, 2003 8:35 PM
> > Subject: Re: [noparse][[/noparse]basicstamps] Two quick questions
> > In a message dated 4/29/2003 5:07:54 PM Pacific Daylight Time,
> > laxboy687@e... writes:
> > > Hi all,
> > > I just started to incorporate a voltage monitoring system into
my
> > > project using the adc8031, BS2, and a 4.8 v battery.
> > > I was running it and the voltage was coming up fine, but I
noticed
> > that
> > > it was extremely hot, I touched it and was almost blister hot.
> > > Is this standard?
> > > My other question was, I'm running out of I/O pins and I have
an
> lcd
> > > screen and I read some where that you can tri-state one of the
> data
> > bus
> > > lines.
> > > What does this mean and can I do it? I just want to add a sharp
> > Gpd02-4
> > > to my project, and just need one more pin.
> > > -Mike
> > "blister hot" is not normal! Some part of your circuit is pulling
> too
> > much
> > current.
> > Also, what was extreemly hot, the stamp, the adc???
> > What input voltage are you running to power the stamp?
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> Subject
> > and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
Subject
Dave
Original Message
> Dave
stamp
> were
battery
> that
Original Message
> > > Hi all,
my
noticed
> > that
> > > Is this standard?
an
> lcd
> data
> > bus
> > > lines.
> > Gpd02-4
> > > -Mike
> too
> > much
> > current.
> Subject
Subject
only hooked up to my battery that it tests, it gets hot.
Original Message
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pVnA2YViCl_Mf78RnpUCxdxzzTFQUjq8iEqxZ-TcdmJyIKftocbdlAs58YKIC7ZcLbVAe4SPag9-jnmTUg]davemucha@j...[/url
Sent: Wednesday, April 30, 2003 9:51 AM
Subject: [noparse][[/noparse]basicstamps] Re: Two quick questions - ADC inputs and
overheating
Dave
Original Message
> Dave
stamp
> were
battery
> that
Original Message
> > > Hi all,
my
noticed
> > that
> > > Is this standard?
an
> lcd
> data
> > bus
> > > lines.
> > Gpd02-4
> > > -Mike
> too
> > much
> > current.
> Subject
Subject
from the same email address that you subscribed. Text in the Subject
Check your wiring to the ADC if it is not too late.
>Here's one more bit of information that I forgot. Even when the adc is
Original Message
>From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FVDzqJywENE-o7v9-OTLLb0tGIzBBbv8OAnIYDJyFa3_OpFH3j5Zw4TaELeqbTc7LaC7inKzvGCQUg]davemucha@j...[/url
>overheating
>Dave
Original Message
> > Dave
>stamp
> > were
>battery
> > that
Original Message
> > > > Hi all,
>my
>noticed
> > > that
> > > > Is this standard?
>an
> > lcd
> > data
> > > bus
> > > > lines.
> > > Gpd02-4
> > > > -Mike
> > too
> > > much
> > > current.
> > Subject
>Subject
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
wrote:
> There is nothing about an ADC that should perceivably get hot.
Too late is a good term. the ADC is a sensor only and should carry
NO power.
better verify each connection. if it is a double input and you are
using one with reference, the other is either open or tied to a
ground. make sure it is wired exactly per the data sheet for that
particular model.
also, check your serial connection wring both signal and grounds to
make sure it is not off chip.
if you isolate it to the chip itself, look for a replacement.
If you are really unsure, think about posting your circuit so one of
us can double check it for you.
Dave
adc is
Original Message
> >overheating
that
expected
> >Dave
Original Message
> > > Dave
<laxboy687@e...>
> >stamp
> > > were
> >battery
> > > that
Original Message
> > > > > Hi all,
into
> >my
> >noticed
> > > > that
hot.
> > > > > Is this standard?
have
> >an
> > > lcd
the
> > > data
> > > > bus
> > > > > lines.
sharp
> > > > Gpd02-4
> > > > > -Mike
pulling
> > > too
> > > > much
> > > > current.
> > > Subject
> >Subject
Subject
Subject and
The ADC0831 is supposed to be POWERED by 4.5 to
6.3 volts, (with an internal zener to protect it,
see the data sheet National Semiconductor). If
you go above 6.3 volts, a series resistor is
recommended to limit the VCC current. May be
your problem.
It can then measure an analog signal between
0 and VCC volts (rail to rail).
( And, from the Docs: )
"Note 4: When the input voltage (VIN) at any pin
exceeds the power supply rails (VIN < V- or VIN >
V+) the absolute value of current at that pin
should be limited to 5 mA or less. The 20 mA
package input current limits the number of pins
that can exceed the power supply boundaries with a
5 mA current limit to four."
So if you want to measure more voltage than is
powering the chip, you MUST use a voltage divider
resistor network to drop the voltage at the pin,
the re-scale the results in software.
In general, when something gets hot that isn't
supposed to, there's current running somewhere
it shouldn't.
is
Original Message
> overheating
that
expected
> Dave
Original Message
> > Dave
<laxboy687@e...>
> stamp
> > were
> battery
> > that
Original Message
> > > > Hi all,
into
> my
> noticed
> > > that
> > > > Is this standard?
> an
> > lcd
the
> > data
> > > bus
> > > > lines.
sharp
> > > Gpd02-4
> > > > -Mike
pulling
> > too
> > > much
> > > current.
> > Subject
> Subject
Subject
correct?
The chip is measuring a 4.8v battery. I think that is within the specs
that
Allan stated.
Heres my schematic with it getting hot.
_______
P1 on BS2 ---|1 8|----VCC on BS2
(4.8V+ bat )---|2 7|---- P3 on BS2
(4.8V- bat )---|3 6|---- P2 on BS2
VSS ---|4 5|----VCC on BS2
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fT08uDb2zCyNpZXtCvldESnvPrthESOzMsesOOtaqDuBokeY0bqsp33AGn-TEhYZe-PtUKQPU86UCDNvgthzGHcQRg]allan.lane@h...[/url
Sent: Wednesday, April 30, 2003 4:55 PM
overheating
Hey, it just occurred to me:
your problem.
it shouldn't.
is
Original Message
> overheating
that
expected
> Dave
Original Message
> > Dave
<laxboy687@e...>
> stamp
> > were
> battery
> > that
Original Message
> > > > Hi all,
into
> my
> noticed
> > > that
> > > > Is this standard?
> an
> > lcd
the
> > data
> > > bus
> > > > lines.
sharp
> > > Gpd02-4
> > > > -Mike
pulling
> > too
> > > much
> > > current.
> > Subject
> Subject
Subject
together (-Vin is tied to GND). Pins 5 and 8 are
also tied together (VCC is also your Vref --
which you have already done)
Your input (4.8V to zero) is tied to pin2, and
gives results compared to VRef.
It looks like you have a 'floating ground' problem,
currently -- which tieing -Vin to GND should fix.
Make sure you're using 'VDD' for +5 volts, NOT
'Vin' which is sitting around 9 to 12 volts on
the BOE. Your other BS2 data connections are
correct.
wrote:
> Ok so the chip is being powered by the VCC on my BOE, which is 5v
> correct?
specs
> that
> Allan stated.
> _______
Original Message
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> overheating
> your problem.
> it shouldn't.
plugged in upside down.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> In the 'standard' approach, Pins 3 and 4 are tied
> correct.
> > correct?
> specs
> > that
> > Allan stated.
> > _______
Original Message
> > overheating
> > your problem.
> > it shouldn't.
fine now!
-Mike
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WkXWe3HgZ-HWJ-9YaMPsZ47PsoeMeyuGy2PjO47Vni0XvWLEbNACUgMWoZGh0uNGmlOlkw7UOFT5K7X3slkZLP7W]allan.lane@h...[/url
Sent: Thursday, May 01, 2003 11:48 AM
overheating
Also, the ADC0831 chip could have been
> correct.
> > correct?
> specs
> > that
> > Allan stated.
> > _______
Original Message
> > overheating
> > your problem.
> > it shouldn't.
