Two quick questions - ADC inputs and overheating — Parallax Forums
edited 2003-05-01 20:32 in General Discussion
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> Where should the resistor go?
Often one puts a resistor between the circuit being senced and the
ADC input. that way, the current is limited to some small value.
you would need to check to make sure the current was high enough that
it could drive the ADC input.
And you would need to make sure it was included in any calcs for
voltage drop thru the ADC. In some cases, the ADC acts like a
voltage divider so adding another resistor might change the expected
output requiring a little software offset.
Dave
> From: Dave Mucha [noparse][[/noparse]mailto:davemucha@j...]
> Sent: Tuesday, April 29, 2003 9:15 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Two quick questions
> did you put in a 10K resistor to limit the current ?
> are you measuring direct or thru a voltage divider ?
> Dave
> wrote:
> > The adc was hot, I have a board of education so the board and
stamp
> were
> > being run by a 9v battery, and the adc was connected to the
battery
> that
> > my robot is going to use.
> > From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
> > Sent: Tuesday, April 29, 2003 8:35 PM
> > Subject: Re: [noparse][[/noparse]basicstamps] Two quick questions
> > In a message dated 4/29/2003 5:07:54 PM Pacific Daylight Time,
> > laxboy687@e... writes:
> > > Hi all,
> > > I just started to incorporate a voltage monitoring system into
my
> > > project using the adc8031, BS2, and a 4.8 v battery.
> > > I was running it and the voltage was coming up fine, but I
noticed
> > that
> > > it was extremely hot, I touched it and was almost blister hot.
> > > Is this standard?
> > > My other question was, I'm running out of I/O pins and I have
an
> lcd
> > > screen and I read some where that you can tri-state one of the
> data
> > bus
> > > lines.
> > > What does this mean and can I do it? I just want to add a sharp
> > Gpd02-4
> > > to my project, and just need one more pin.
> > > -Mike
> > "blister hot" is not normal! Some part of your circuit is pulling
> too
> > much
> > current.
> > Also, what was extreemly hot, the stamp, the adc???
> > What input voltage are you running to power the stamp?
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> Subject
> > and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
Subject
    edited 2003-04-30 20:38
    Here's one more bit of information that I forgot. Even when the adc is
    only hooked up to my battery that it tests, it gets hot.
    From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pVnA2YViCl_Mf78RnpUCxdxzzTFQUjq8iEqxZ-TcdmJyIKftocbdlAs58YKIC7ZcLbVAe4SPag9-jnmTUg]davemucha@j...[/url
    Sent: Wednesday, April 30, 2003 9:51 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Two quick questions - ADC inputs and
    overheating
    Dave
    > Dave
    stamp
    > were
    battery
    > that
    > > > Hi all,
    my
    noticed
    > > that
    > > > Is this standard?
    an
    > lcd
    > data
    > > bus
    > > > lines.
    > > Gpd02-4
    > > > -Mike
    > too
    > > much
    > > current.
    > Subject
    Subject
    edited 2003-04-30 20:39
    There is nothing about an ADC that should perceivably get hot.
    Check your wiring to the ADC if it is not too late.
    >From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FVDzqJywENE-o7v9-OTLLb0tGIzBBbv8OAnIYDJyFa3_OpFH3j5Zw4TaELeqbTc7LaC7inKzvGCQUg]davemucha@j...[/url
    >overheating
    >Dave
    > > Dave
    >stamp
    > > were
    >battery
    > > that
    > > > > Hi all,
    >my
    >noticed
    > > > that
    > > > > Is this standard?
    >an
    > > lcd
    > > data
    > > > bus
    > > > > lines.
    > > > Gpd02-4
    > > > > -Mike
    > > too
    > > > much
    > > > current.
    > > Subject
    >Subject
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-04-30 21:42
    --- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
    Too late is a good term. the ADC is a sensor only and should carry
    NO power.
    better verify each connection. if it is a double input and you are
    using one with reference, the other is either open or tied to a
    ground. make sure it is wired exactly per the data sheet for that
    particular model.
    also, check your serial connection wring both signal and grounds to
    make sure it is not off chip.
    if you isolate it to the chip itself, look for a replacement.
    If you are really unsure, think about posting your circuit so one of
    us can double check it for you.
    Dave
    adc is
    > >overheating
    that
    expected
    > >Dave
    > > > Dave
    <laxboy687@e...>
    > >stamp
    > > > were
    > >battery
    > > > that
    > > > > > Hi all,
    into
    > >my
    > >noticed
    > > > > that
    hot.
    > > > > > Is this standard?
    have
    > >an
    > > > lcd
    the
    > > > data
    > > > > bus
    > > > > > lines.
    sharp
    > > > > Gpd02-4
    > > > > > -Mike
    pulling
    > > > too
    > > > > much
    > > > > current.
    > > > Subject
    > >Subject
    Subject
    Subject and
    edited 2003-04-30 21:55
    Hey, it just occurred to me:
    The ADC0831 is supposed to be POWERED by 4.5 to
    6.3 volts, (with an internal zener to protect it,
    see the data sheet National Semiconductor). If
    you go above 6.3 volts, a series resistor is
    recommended to limit the VCC current. May be
    your problem.
    It can then measure an analog signal between
    0 and VCC volts (rail to rail).
    ( And, from the Docs: )
    "Note 4: When the input voltage (VIN) at any pin
    exceeds the power supply rails (VIN < V- or VIN >
    V+) the absolute value of current at that pin
    should be limited to 5 mA or less. The 20 mA
    package input current limits the number of pins
    that can exceed the power supply boundaries with a
    5 mA current limit to four."
    So if you want to measure more voltage than is
    powering the chip, you MUST use a voltage divider
    resistor network to drop the voltage at the pin,
    the re-scale the results in software.
    In general, when something gets hot that isn't
    supposed to, there's current running somewhere
    it shouldn't.
    is
    > overheating
    that
    expected
    > Dave
    > > Dave
    <laxboy687@e...>
    > stamp
    > > were
    > battery
    > > that
    > > > > Hi all,
    into
    > my
    > noticed
    > > > that
    > > > > Is this standard?
    > an
    > > lcd
    the
    > > data
    > > > bus
    > > > > lines.
    sharp
    > > > Gpd02-4
    > > > > -Mike
    pulling
    > > too
    > > > much
    > > > current.
    > > Subject
    > Subject
    Subject
    edited 2003-05-01 00:09
    Ok so the chip is being powered by the VCC on my BOE, which is 5v
    correct?
    The chip is measuring a 4.8v battery. I think that is within the specs
    that
    Allan stated.
    Heres my schematic with it getting hot.
    _______
    P1 on BS2 ---|1 8|----VCC on BS2
    (4.8V+ bat )---|2 7|---- P3 on BS2
    (4.8V- bat )---|3 6|---- P2 on BS2
    VSS ---|4 5|----VCC on BS2
    From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fT08uDb2zCyNpZXtCvldESnvPrthESOzMsesOOtaqDuBokeY0bqsp33AGn-TEhYZe-PtUKQPU86UCDNvgthzGHcQRg]allan.lane@h...[/url
    Sent: Wednesday, April 30, 2003 4:55 PM
    overheating
    your problem.
    it shouldn't.
    is
    > overheating
    that
    expected
    > Dave
    > > Dave
    <laxboy687@e...>
    > stamp
    > > were
    > battery
    > > that
    > > > > Hi all,
    into
    > my
    > noticed
    > > > that
    > > > > Is this standard?
    > an
    > > lcd
    the
    > > data
    > > > bus
    > > > > lines.
    sharp
    > > > Gpd02-4
    > > > > -Mike
    pulling
    > > too
    > > > much
    > > > current.
    > > Subject
    > Subject
    Subject
    edited 2003-05-01 15:22
    In the 'standard' approach, Pins 3 and 4 are tied
    together (-Vin is tied to GND). Pins 5 and 8 are
    also tied together (VCC is also your Vref --
    which you have already done)
    Your input (4.8V to zero) is tied to pin2, and
    gives results compared to VRef.
    It looks like you have a 'floating ground' problem,
    currently -- which tieing -Vin to GND should fix.
    Make sure you're using 'VDD' for +5 volts, NOT
    'Vin' which is sitting around 9 to 12 volts on
    the BOE. Your other BS2 data connections are
    correct.
    > correct?
    specs
    > that
    > Allan stated.
    > _______
    > From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
    > overheating
    > your problem.
    > it shouldn't.
    edited 2003-05-01 16:47
    Also, the ADC0831 chip could have been
    plugged in upside down.
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > correct.
    > > correct?
    > specs
    > > that
    > > Allan stated.
    > > _______
    > > overheating
    > > your problem.
    > > it shouldn't.
    Thanks so much, I guess it was the floating ground, because it works
    fine now!
    -Mike
    From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WkXWe3HgZ-HWJ-9YaMPsZ47PsoeMeyuGy2PjO47Vni0XvWLEbNACUgMWoZGh0uNGmlOlkw7UOFT5K7X3slkZLP7W]allan.lane@h...[/url
    Sent: Thursday, May 01, 2003 11:48 AM
    overheating
    > correct.
    > > correct?
    > specs
    > > that
    > > Allan stated.
    > > _______
    > > overheating
    > > your problem.
    > > it shouldn't.
