BS2 simple question
can i use pin 3 (ATN) of the BS2 for serial communication with another
processor? It will only be receiving one bit. I've used all of the other I/O
pins as well as the TX/RX. if not, what can i do about this? thanks so much
for all responses
for all responses
ckkim_1999@y... writes:
> I/O pins as well as the TX/RX. if not, what can i do about this? thanks
> so much for all responses
If you are communicating with another processor using serin and/or serout,
try using address on the processor. Using this procedure can let you
communicate with a large number of peripheral processsors using only one
Stamp I/O port.
Sid Weaver
W4EKQ
Port Richey, FL
interface) to start the download process -- it is not available for
general-purpose or serial IO.
-- Jon Williams
-- Parallax
In a message dated 4/23/2003 5:09:59 PM Central Standard Time,
