BS2 simple question — Parallax Forums
BS2 simple question
edited 2003-04-24 01:19 in General Discussion
can i use pin 3 (ATN) of the BS2 for serial communication with another
processor? It will only be receiving one bit. I've used all of the other I/O
pins as well as the TX/RX. if not, what can i do about this? thanks so much
for all responses
    edited 2003-04-23 23:42
    In a message dated 04/23/2003 18:10:31 Eastern Daylight Time,
    ckkim_1999@y... writes:
    > I/O pins as well as the TX/RX. if not, what can i do about this? thanks
    > so much for all responses
    If you are communicating with another processor using serin and/or serout,
    try using address on the processor. Using this procedure can let you
    communicate with a large number of peripheral processsors using only one
    Stamp I/O port.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    No. The ATN line is used to reset the BASIC Stamp (via programming
    interface) to start the download process -- it is not available for
    general-purpose or serial IO.
    -- Jon Williams
    -- Parallax
    In a message dated 4/23/2003 5:09:59 PM Central Standard Time,
