Axle coupler
Hi. This is only remotely stamp related...but I'm not sure where
else to ask.
Right now I'm working on a home built linear actuator. I've
purchased some stepper motors and a stepper controller that I'll be
controlling with my computer through a bs2. I've run into a problem,
however: The stats on the motors listed their shaft diameters
as .250", however they're actually .275". I'm trying to join these
to a .250" diameter threaded rod. The axle couplers I purchased
don't fit the motor shafts. I tried drilling one of the bores out,
but I botched the attempt and didn't get the enlarged hole dead
center, which causes an eccentric action...
This is a learning project for me, so any suggestions would be
welcome. I've searched mcmaster-carr and sdp-si, but for the life of
me, I can't seem to find anything with a .275" bore size.
Just as a side note, this is all for a neat little project of mine.
I purchased a safe, and forgot the combination. It's a pushbutton
combo entry, so instead of calling the safe company for a solution,
for fun (and education) I'm building a system using the stamp, my
computer, steppers, etc. to try all the possible combinations.
else to ask.
often have to machine adapters for our stuff because things aren't always
the correct size.
I'm guessing the shaft is probably 7mm -- which is about 0.275.
Original Message
> else to ask.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
might be able to get away with a piece of poly-vinyl tubing.
>else to ask.
coupling for that size.
If you have a drll press, drill the hole for that tap, then the 7mm
hole half way, then tap the hole. that should give you clearance.
if you have a lathe, you can make it dead center.
A less clean way would be to buy a threaded rod coupling nut. that
would be threaded all the way thry and it would be long. then you
can drill the center out. again, a drill press would be best. and
in this case, I'd clamp the drill in a vice and put the nut in the
drill press chuck. seems it would drill straighter that way.
just a thought.
Dave
--- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
wrote:
> Since it sounds as though you don't need a lot of coupling torque,
you
> >else to ask.
problem,
of
Subject and
think of buying one...where to put it?!), but I do have a drill
press, is there a good technique of centering the drill bit? I also
worry about ensuring a cylinder is accurately vertically aligned in
the vice. I won't be able to put the coupler in the chuck. It's
just too big.
I guess I could try to drill/tap set screws into a coupling nut?
Harrumph. I may just go buy a lathe!
I'll post a link to images of the contraption in operation once I get
it done. At this rate that'll be a while :P
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
wrote:
> sounds like the shaft is 7 mm. you should be able to get a shaft
> just a thought.
> Dave
torque,
> you
> > >else to ask.
be
> problem,
these
out,
life
> of
mine.
pushbutton
solution,
> Subject and
.012 shim stock to bush your smaller shaft (.250). Or you can mail the part
to me and I will open it up on a lathe [noparse]:)[/noparse]
Contact me off list if you want me to turn it for you. I live in North
Florida.
Jeff
Original Message
From: verygrimm2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Czy29UnmaQkfTf0xWO18_PtY38uyXNqAF7veFZ9Yl5qXvGJ_5IV0opZ5vsKvHtQDk6Iw9tFKWEnusP4L35AxvVJH]robots@t...[/url
Sent: Thursday, April 24, 2003 3:05 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Axle coupler
Thanks guys. Since I don't have a lathe (this is really making me
just too big.
> just a thought.
> Dave
torque,
> you
> > >else to ask.
be
> problem,
these
out,
life
> of
mine.
pushbutton
solution,
> Subject and
the press and slide the coupling on it. Lower the spindle till the coupling
is in the vise. Now it's lined up. Clamp part, and vise retract spindle
and replace bit with the size you want. Drill away.
Original Message
From: verygrimm2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XzgTHF5g76V8Vh8jxynON-Bhn_e2sSSGFjfZNSXSlP2Fq5gaBQmAovwACF3gby-ZG3F6zu3ABlRnp3DHUr3rXw]robots@t...[/url
just too big.
> just a thought.
> Dave
torque,
> you
> > >else to ask.
be
> problem,
these
out,
life
> of
mine.
pushbutton
solution,
> Subject and
I have a lathe and would be happy to do it for you.
Dave
also
> worry about ensurin
> just too big.
get
7mm
clearance.
that
you
and
the
> > just a thought.
> > Dave
<bschwabe@a...>
> torque,
> > you
where
> > > >else to ask.
I'll
> be
> > problem,
> these
purchased
> out,
> life
> > of
> mine.
> pushbutton
> solution,
my
> > Subject and
if you are on the other side of the Missisppi, it may be faster in
Fla as I'm at the shop only a few days a week.
Dave
--- In basicstamps@yahoogroups.com, "Jeff Mitchell" <JMitchell@G...>
wrote:
> Get a two piece clamp on coupler to fit your larger shaft (.275?)
and use
the part
North
> Florida.
> Jeff
Original Message
> From: verygrimm2 [noparse][[/noparse]mailto:robots@t...]
> just too big.
get
7mm
that
and
> > just a thought.
> > Dave
> torque,
> > you
where
> > > >else to ask.
I'll
> be
> > problem,
> these
purchased
> out,
> life
> > of
> mine.
> pushbutton
> solution,
my
> > Subject and
Subject and
