Micro Fuel Cell
Does anyone know of a manufacturer of mini fuel cells?
I would like to look into using fuel cells to power my
robot projects.
Andrew Hoover
robot projects.
Andrew Hoover
robotics@p... writes:
> robot projects.
> Thanks,
> Andrew Hoover
go to
<A HREF="www.howstuffworks.com">www.howstuffworks.com</A>
<A HREF="http://www.utoypia.com/fuelcellcar.shtml">Fuel Cell Car Kit at
uTOYpia</A>
It depends what you want. I have been pursuing a fuel cell bot myself. The
main trouble I have been having so far is raising the voltage of the cell
enough to run the logic circuits. I have tried several cells using the MAX
756, no luck. I am still looking. E-mail me off list if you want my details
on my failures ;-)
Jonathan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, April 11, 2003 2:26 PM
Subject: Re: [noparse][[/noparse]basicstamps] Micro Fuel Cell
> In a message dated 4/11/2003 1:25:15 PM Pacific Daylight Time,
> > robot projects.
> > Thanks,
> > Andrew Hoover
> go to
uTOYpia</A>
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
These fuel cells run on hydrogen right? Or are there different versions
that run on different substances? If they do run on hydrogen how do you
plan on getting that fuel?
-Mike
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=njjU5q2JloBJH1FuL-EdStoxtluDRE4AXKRRCR9RYLbuu4Hp8_yE7tLa4bW0Wt59jkXBtMd31AQ4KG4n]jpeakall@m...[/url
Sent: Saturday, April 12, 2003 10:31 AM
To: basicstamps@yahoogroups.com
Andrew,
The
cell
MAX
details
on my failures ;-)
Jonathan
Original Message
> > robot projects.
> > Thanks,
> > Andrew Hoover
> go to
at
uTOYpia</A>
and
and Body of the message will be ignored.
to give credit where credit is due.
HI,
You mean like this?
http://www.electronickits.com/kit/complete/solar/fuelcell.htm
or a more robust version..
http://www.homepower.com/files/fuelcell.pdf
Wayne
Wayne & Rebecca Lowry
Springfield, Oregon
And I'm partial to people from Oregon anyway. I was born there.
Mic
Original Message
Sent: Saturday, April 12, 2003 10:30 AM
> Andrew,
details
> on my failures ;-)
> Jonathan
Original Message
> From: <smartdim@a...>
> > > robot projects.
> > > Thanks,
> > > Andrew Hoover
> > go to
> uTOYpia</A>
and
the interaction between hydrogen and oxygen. Getting
oxygen isn't difficult, but it is time consuming. You
would use either a solar array (for the "free"
generation of Hydrogen) or AC house voltage to split
water into hydrogen and oxygen. After that you use the
hydrogen and air for the fuel cell. The whole trick to
the system is to figure out an effecient way to
generate hydrogen.
Andy
--- Mike Dillon <laxboy687@e...> wrote:
> Hey all,
> different versions
> hydrogen how do you
> -Mike
Original Message
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oPUt6iU0Gql6I71F9Yt6_APzTBynOrf9z8QkEvzQbJYA4RfrBIsLY6giMkmXAklBgCJqJ2M6Q2AvRmU]jpeakall@m...[/url
> Andrew,
> The
> the voltage of the
> cell
> MAX
> if you want my
> details
> on my failures ;-)
> Jonathan
Original Message
> Daylight Time,
> cells?
> power my
> > > robot projects.
> > > Thanks,
> > > Andrew Hoover
> > go to
> > <A
> > <A
> Cell Car Kit
> at
> uTOYpia</A>
> removed]
> Text in the Subject
> and
> Text in the Subject
> Text in the Subject and Body of the message will be
> ignored.
Andy
--- Michael Duerksen <michael_duerksen@c...>
wrote:
> I found this over on the Toddler bots group at
> yahoo. I used the entire text
> HI,
> You mean like this?
> Wayne
> Springfield, Oregon
> born there.
> Mic
Original Message
> From: Jonathan Peakall <jpeakall@m...>
> > Andrew,
> list if you want my
> details
> > on my failures ;-)
> > Jonathan
Original Message
> Daylight Time,
> fuel cells?
> power my
> > > > robot projects.
> > > > Thanks,
> > > > Andrew Hoover
> > > go to
> > > <A
> > > <A
> Cell Car Kit at
> > uTOYpia</A>
> removed]
> Text in the Subject
> and
> ignored.
This is getting kinda OT but...
The Thames and Kosmos fuel cell in the link is neat, I have one.
Unfortunately, since it is a single membrane cell, it's voltage under any
load drops to about .7V. The motor that comes with it is a special motor
made to run on this low voltage, and it doesn't produce enough power to run
much of a bot. Further, it is (so far for me) impossible to make the cell
cough up enough voltage to run a HF DC/DC converter on. At least not a
through hole type like the MAX756. They have a SMT model that might work,
but I can't do SMT.
One extremely neat feature about the T&K cell is that it is reversible,
meaning it will perform electrolysis if voltage is applied to it, and it is
a very efficient fuel producer. The current plan with my bot is to use one
of these to produce fuel for another cell.
Any more details should be off list, so e-mail if you want.
Jonathan
www.madlabs.info
Original Message
Sent: Saturday, April 12, 2003 8:36 PM
> These are great links, thanks a whole heap!
> Andy
> > HI,
> > You mean like this?
> > Wayne
> > Springfield, Oregon
> > born there.
> > Mic
Original Message
> > > Andrew,
> > list if you want my
> > details
> > > on my failures ;-)
> > > Jonathan
Original Message
> > Daylight Time,
> > fuel cells?
> > power my
> > > > > robot projects.
> > > > > Thanks,
> > > > > Andrew Hoover
> > > > go to
> > > > <A
> > > > <A
> > Cell Car Kit at
> > > uTOYpia</A>
> > removed]
> > Text in the Subject
> > and
> > ignored.
