82C54 on BS2e
Does anybody know how to control 82C54 Programable Timer from Bs2e?
Is possible to use BS2e I/O pins as 82C54 data bus and address bus?
if Anybody have a sample code or documentation about this question,
please send me.
thank's
Vanderson
please send me.
thank's
Vanderson
using it as a high-speed interface to a PC, instead of the clunky serial
port method. I have some pretty basic Mode-0 I/O working already talking to
a PORT-A bus. I haven't attempting using interrupt signaling yet....I
should give it a whirl in the next day or two. I'll post my results when I
have some.
- Ted
Original Message
From: kloggerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SbQ_KH0YV7osjCJ-yIA8EM1MkF4afJZb35Ahlp5757WBk3aMI854tJ2OC4mEQKYaB7WixriQw4lzdwQHhw]loggerr@b...[/url
Sent: Thursday, April 10, 2003 7:21 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] 82C54 on BS2e
please send me.
thank's
Vanderson
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
structure. The *INTerrupt pin from the 8255 can only
go into a discrete I/O pin which is then _polled_ for
the active level.
kevin
--- Ted Larson <ted@l...> wrote:
> I have just started fooling with talking to an 8255
> from an BS2SX. I am
> signaling yet....I
> have some.
> - Ted
Original Message
> From: kloggerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xpLjwbhsyvBYv4bKu9udFmFfQhSLuYprpGVmMO7-QlFJhD9jar-4z5Wap1Zg06EaiqKV-I-idxlYUA]loggerr@b...[/url
> Timer from Bs2e?
> and address bus?
> this question,
> please send me.
> thank's
> Vanderson
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online, calculators, forms, and more
http://tax.yahoo.com
I just started working on the 82C54 PIT and a BS2p24, but through a pair of
PCF8574 I2C I/O extenders (one for the data bus, and the other for the
remaining address and control lines, for I/O limitations), but actually I'm
just writing the program codes and didn't try any test.
If you have I/O enough for directly controlling the PIT, you can do it.
Anyway I suggest you to put a 74HC... buffer through the lines used for the
data bus, mainly for the safety of the Stamp (the PIT data bus is
bi-directional). Second, remember that when powered on the PIT has its
internal registers in an unknown condition (it isn't provided by a reset
pin), therefore you have to set them anyway.
I'm following only the data sheet of the PIT, that seems something plain to
me. If you tell me what application you are working around (that is, what
operating modes of the internal counters do interest you), maybe I can be of
any help for you.
I.e., I'm using the PIT in two PWM controller boards, one for AC and one for
DC motor, and that requires two counters - with different modes - in each
board.
Alberto, IZ2EWV.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, April 11, 2003 4:20 AM
> please send me.
> thank's
> Vanderson
mode 2 and counter 1/2 on mode 1 to control a 50 Hz PWM motor.
Now, I am using almost all I/O pins from my BS2e for 82C54 control.
It's very bad, I'll need more I/O or another Bs2e !!
I would like to use a any IC for expand Bs2e I/O pins.Do you know
anything to make that?
Vanderson
--- In basicstamps@yahoogroups.com, "Alberto Calderara"
<albertocalderara@t...> wrote:
> Ciao,
pair of
the
actually I'm
it.
for the
its
reset
plain to
what
can be of
> any help for you.
one for
each
> board.
> Alberto, IZ2EWV.
Original Message
> From: "kloggerr" <loggerr@b...>
Bs2e?
bus?
question,
> > please send me.
> > thank's
> > Vanderson
to Parallel set of signals?
(Use SHIFTOUT to control)
(AND you can put multiples in series!)
74HC165 for Parallel in to Serial set of signals?
(Again, use SHIFTIN )
--- In basicstamps@yahoogroups.com, "kloggerr" <loggerr@b...> wrote:
> My project require only one 82C54 PIT on basic PWM arrange,counter0
on
> Vanderson
> > Ciao,
a
> pair of
for
> the
> actually I'm
do
> it.
used
> for the
has
> its
a
> reset
something
> plain to
is,
> what
I
> can be of
> > any help for you.
and
> one for
in
> each
> > board.
> > Alberto, IZ2EWV.
Original Message
> Bs2e?
> bus?
> question,
> > > please send me.
> > > thank's
> > > Vanderson
