82C54 on BS2e — Parallax Forums
82C54 on BS2e
edited 2003-04-12 22:09 in General Discussion
Does anybody know how to control 82C54 Programable Timer from Bs2e?
Is possible to use BS2e I/O pins as 82C54 data bus and address bus?
if Anybody have a sample code or documentation about this question,
please send me.
thank's
Vanderson
    edited 2003-04-11 07:29
    I have just started fooling with talking to an 8255 from an BS2SX. I am
    using it as a high-speed interface to a PC, instead of the clunky serial
    port method. I have some pretty basic Mode-0 I/O working already talking to
    a PORT-A bus. I haven't attempting using interrupt signaling yet....I
    should give it a whirl in the next day or two. I'll post my results when I
    have some.
    - Ted
    From: kloggerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SbQ_KH0YV7osjCJ-yIA8EM1MkF4afJZb35Ahlp5757WBk3aMI854tJ2OC4mEQKYaB7WixriQw4lzdwQHhw]loggerr@b...[/url
    Sent: Thursday, April 10, 2003 7:21 PM
    Subject: [noparse][[/noparse]basicstamps] 82C54 on BS2e
    please send me.
    thank's
    Vanderson
    edited 2003-04-11 18:04
    I don't believe that the Stamp has an interrupt
    structure. The *INTerrupt pin from the 8255 can only
    go into a discrete I/O pin which is then _polled_ for
    the active level.
    kevin
    > from an BS2SX. I am
    > signaling yet....I
    > have some.
    > - Ted
    > From: kloggerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xpLjwbhsyvBYv4bKu9udFmFfQhSLuYprpGVmMO7-QlFJhD9jar-4z5Wap1Zg06EaiqKV-I-idxlYUA]loggerr@b...[/url
    > Timer from Bs2e?
    > and address bus?
    > this question,
    > please send me.
    > thank's
    > Vanderson
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - File online, calculators, forms, and more
    http://tax.yahoo.com
    edited 2003-04-12 18:43
    Ciao,
    I just started working on the 82C54 PIT and a BS2p24, but through a pair of
    PCF8574 I2C I/O extenders (one for the data bus, and the other for the
    remaining address and control lines, for I/O limitations), but actually I'm
    just writing the program codes and didn't try any test.
    If you have I/O enough for directly controlling the PIT, you can do it.
    Anyway I suggest you to put a 74HC... buffer through the lines used for the
    data bus, mainly for the safety of the Stamp (the PIT data bus is
    bi-directional). Second, remember that when powered on the PIT has its
    internal registers in an unknown condition (it isn't provided by a reset
    pin), therefore you have to set them anyway.
    I'm following only the data sheet of the PIT, that seems something plain to
    me. If you tell me what application you are working around (that is, what
    operating modes of the internal counters do interest you), maybe I can be of
    any help for you.
    I.e., I'm using the PIT in two PWM controller boards, one for AC and one for
    DC motor, and that requires two counters - with different modes - in each
    board.
    Alberto, IZ2EWV.
    Sent: Friday, April 11, 2003 4:20 AM
    > please send me.
    > thank's
    > Vanderson
    edited 2003-04-12 20:50
    My project require only one 82C54 PIT on basic PWM arrange,counter0 on
    mode 2 and counter 1/2 on mode 1 to control a 50 Hz PWM motor.
    Now, I am using almost all I/O pins from my BS2e for 82C54 control.
    It's very bad, I'll need more I/O or another Bs2e !!
    I would like to use a any IC for expand Bs2e I/O pins.Do you know
    anything to make that?
    Vanderson
    --- In basicstamps@yahoogroups.com, "Alberto Calderara"
    <albertocalderara@t...> wrote:
    > Ciao,
    pair of
    the
    actually I'm
    it.
    for the
    its
    reset
    plain to
    what
    can be of
    > any help for you.
    one for
    each
    > board.
    > Alberto, IZ2EWV.
    > From: "kloggerr" <loggerr@b...>
    Bs2e?
    bus?
    question,
    > > please send me.
    > > thank's
    > > Vanderson
    74HC595 for Serial out (Data, Clk, Grn)
    to Parallel set of signals?
    (Use SHIFTOUT to control)
    (AND you can put multiples in series!)
    74HC165 for Parallel in to Serial set of signals?
    (Again, use SHIFTIN )
    on
    > Vanderson
    > > Ciao,
    a
    > pair of
    for
    > the
    > actually I'm
    do
    > it.
    used
    > for the
    has
    > its
    a
    > reset
    something
    > plain to
    is,
    > what
    I
    > can be of
    > > any help for you.
    and
    > one for
    in
    > each
    > > board.
    > > Alberto, IZ2EWV.
    > Bs2e?
    > bus?
    > question,
    > > > please send me.
    > > > thank's
    > > > Vanderson
