Update to displaying images with CMUcam
I guess I forgot to mention but when I unstrapped the 9600 baud, I
left it at 115200 baud on the board. The max232 chip was placed on
the PCB and thus the communication go into the TTLin (pin 11) of the
Max232, and out to the computer on the RSout (pin12). Communication
the other way goes into RSin (pin13) of the Max232 and out the TTLout
(pin 14) of the Max232 chip.
Michael
--- In basicstamps@yahoogroups.com, Powderworks Robotics
<robotics@p...> wrote:
> I believe a "stock" CMUcam communicates at 115200
> without jumpers. You might start there.
> Andy
> --- omnigroup_2002 <ord_data@h...> wrote:
> > I have the Parallax, Inc. modified version of the
> > CMUcam, which in
> > and of itself cannot dump images to a computer. I
> > have a new
> > requirement that necessitates an image to be seen.
> > After contacting
> > SeattleRobotics, I have added the Max232 chip, 4 1uf
> > 50V capacitors,
> > 5x2 .100 header pin to allow the serial connection,
> > removed the
> > jumpers strapping the board to 9600 baud, and have
> > the serial cable
> > ready to go. However, whenever I open hyperterminal
> > I don't get any
> > response from the camera like the version number
> > upon startup. Also,
> > the Carnegie Melon CMUcam gui is installed and it
> > always gives a
> > reset failure error and says the serial read timed
> > out. Anyone have
> > any ideas why I still can't get the computer and
> > camera to
> > communicate?
> > Michael
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.
> > Text in the Subject and Body of the message will be
> > ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
Michael
> Andy
> > CMUcam, which in
> > have a new
> > After contacting
> > 50V capacitors,
> > removed the
> > the serial cable
> > I don't get any
> > upon startup. Also,
> > always gives a
> > out. Anyone have
> > camera to
> > communicate?
> > Michael
> > ignored.
5 pins) not the ttl serial connection to talk with your computer.
--- In basicstamps@yahoogroups.com, "omnigroup_2002" <ord_data@h...>
the
Communication
TTLout
> Michael
> > Andy
> > > CMUcam, which in
> > > have a new
> > > After contacting
> > > 50V capacitors,
> > > removed the
> > > the serial cable
> > > I don't get any
> > > upon startup. Also,
> > > always gives a
> > > out. Anyone have
> > > camera to
> > > communicate?
> > > Michael
> > > ignored.
