SCR for motor control
Does anyone know if an SCR can be used to control a motor through a
basic stamp? If not what about transistors?
Rob
Rob
jim
Original Message
From: mstroboto2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fqmhLL16BzJ9jmXBCDA-wzrYPxXh4FJMkUBrj7gyUM8Y88HXMhXIMGk15U512vEmAsWaQd5CKRk]monkeymack@a...[/url
Sent: Monday, April 07, 2003 8:42 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] SCR for motor control
Rob
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the scr with a transistor . . . else try an Opto22
module (www.opto22.com). The mp120d4 module pulls
less than 10mw when driving 120 @3amps.
> motor through a
> Thanks,
> Rob
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online, calculators, forms, and more
http://tax.yahoo.com
I'm assuming you're trying to control a DC motor with an SCR?
Although I haven't done it with the stamp, it does sound feasible.
However you will run into problems along the way with things such as
detecting the zero voltage crossing of the AC line, commutation
notches in the AC line as the motor runs, etc. etc. If your motor is
relatively small, you're probably better off going with an H-Bridge
type setup with four transistors, and then pulsing two at a time
(PWM) at set intervals to create an average DC voltage and run the
motor. If you need precise control over the motor you may need to
hook an encoder up to it to count revolutions. The stamp will
quickly become a limitation if your project requires this type of
feature.
Ron
--- In basicstamps@yahoogroups.com, "mstroboto2003" <monkeymack@a...>
> Thanks,
> Rob
anyone considered using a small bar magnet fixed to the shaft of the motor
so that one end passed near a Hall sensor (Hall's read a linear signal out
in direct proportion to the magnetic field, right?), and counting the sine
waves produced by the magnet/Hall effect combination as the magnet ends come
near the sensor?
It seems like that would be a VERY BEAMish idea, since you could a) gate a
window to count cycles in, and derive RPMs, b) calculate the sine angle and
thus degrees of rotation for a very slow, or even stepped motor, and c) just
plain count cycles, with a proper correction factor for the circumference of
the circle described by the magnet's poles, to obtain distance traveled.
For that matter, if you made sure that the motor shaft stuck straight up or
straight down (wouldn't matter which, really, you just have t make sure the
magnet is always at least near parallel to the earth's surface, so that it
comes into North/South alignment, and out, at a regular rate of speed) you
could calculate the change in angular velocity as the carrier vehicle turned
a corner (for very short periods), and possibly (like doppler shifting) read
the turn rate of the vehicle as a function of the sum or difference of the
resulting count rates.
Does that make sense? If not, and someone else would like to take a crack at
rephrasing it, great. Otherwise, if it doesn't seem clear, let me know and
I'll try to re-state the idea.
I wish I had some kind of graphic software to use to draw what I'm talking
about. Any advice on what to use, and where to get it?
Mic
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, April 09, 2003 5:14 AM
Subject: [noparse][[/noparse]basicstamps] Re: SCR for motor control
> Rob,
> feature.
> Ron
> > Thanks,
> > Rob
> Thanks,
> Rob
Hi Rob,
assuming you are trying to do variable speed control, pwm is a simple
way to pulse full voltage to a motor of yeild higher power at lower
speeds.
if you are interested in controlling speed, some form of encoder is
needed and you would also want to use a PID loop to cotrol the
signals.
I think the existing forms of motor speed contorllers for hobby size
motors are pretty good. when you get into the horsepower motors, you
run into monitoring amps, hertz and volts. then you are getting into
some heavy processing.
the IGBT transistors fire at 32,000 hz to eleminate the resonance
caused by the motor laminations vibrating. And then of course, there
are some step thru frequencies so that if a particular motor does
resonate at some frequency, you cna bypass that range.
maybe if you let us know the motor size your are looking into we
could offe a little more directon ?
Dave
want and it will interface with the Stamp. Look under the Whats New link on
their website.
Bill Cramer
Atlanta, Ga. USA
Original Message
Sent: Thursday, April 10, 2003 8:44 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: SCR for motor control
> Not quite OT, especially if counting turns is required for a motor, but
has
come
> near the sensor?
and
just
of
the
turned
read
at
> Mic
Original Message
> From: Ron Jeremy <ronjeremy912@y...>
> > Rob,
> > feature.
> > Ron
> > > Thanks,
> > > Rob
and
I understand, and I know that Gray Scale optical codecs have been around for
decades (but not always in IC form. We had to build them from discretes when
I was in the US Navy), but what I thought would be interesting was using
only two magnet/hall sensor assemblies (one on a rolling wheel and one on
the "compass card") to derive SO much info. And lurking in the back of my
mind was how much fun it would be to get all that info with a Stamp.
Mic
Original Message
Sent: Thursday, April 10, 2003 9:36 PM
> www.alltronics.com sells an optical encoder which will do exactly what you
on
> their website.
> Regards,
> Bill Cramer
> Atlanta, Ga. USA
Original Message
> From: "Michael Duerksen" <michael_duerksen@c...>
> has
motor
out
sine
> come
> > near the sensor?
a
> and
> just
circumference
> of
> or
> the
it
you
> turned
> read
the
crack
> at
and
talking
> > Mic
Original Message
> > > Rob,
> > > feature.
> > > Ron
> > > > Thanks,
> > > > Rob
> and
and
