SCR for motor control — Parallax Forums
edited 2003-04-11 02:54 in General Discussion
Does anyone know if an SCR can be used to control a motor through a
basic stamp? If not what about transistors?
Rob
    edited 2003-04-08 12:50
    check out http://www.geocities.com/jimforkin2003/
    jim
    From: mstroboto2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fqmhLL16BzJ9jmXBCDA-wzrYPxXh4FJMkUBrj7gyUM8Y88HXMhXIMGk15U512vEmAsWaQd5CKRk]monkeymack@a...[/url
    Sent: Monday, April 07, 2003 8:42 PM
    Subject: [noparse][[/noparse]basicstamps] SCR for motor control
    Rob
    edited 2003-04-08 13:53
    yes . . . what size motor? you might need to drive
    the scr with a transistor . . . else try an Opto22
    module (www.opto22.com). The mp120d4 module pulls
    less than 10mw when driving 120 @3amps.
    > motor through a
    > Thanks,
    > Rob
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - File online, calculators, forms, and more
    http://tax.yahoo.com
    edited 2003-04-09 10:14
    Rob,
    I'm assuming you're trying to control a DC motor with an SCR?
    Although I haven't done it with the stamp, it does sound feasible.
    However you will run into problems along the way with things such as
    detecting the zero voltage crossing of the AC line, commutation
    notches in the AC line as the motor runs, etc. etc. If your motor is
    relatively small, you're probably better off going with an H-Bridge
    type setup with four transistors, and then pulsing two at a time
    (PWM) at set intervals to create an average DC voltage and run the
    motor. If you need precise control over the motor you may need to
    hook an encoder up to it to count revolutions. The stamp will
    quickly become a limitation if your project requires this type of
    feature.
    Ron
    --- In basicstamps@yahoogroups.com, "mstroboto2003" <monkeymack@a...>
    > Thanks,
    > Rob
    edited 2003-04-11 01:44
    Not quite OT, especially if counting turns is required for a motor, but has
    anyone considered using a small bar magnet fixed to the shaft of the motor
    so that one end passed near a Hall sensor (Hall's read a linear signal out
    in direct proportion to the magnetic field, right?), and counting the sine
    waves produced by the magnet/Hall effect combination as the magnet ends come
    near the sensor?
    It seems like that would be a VERY BEAMish idea, since you could a) gate a
    window to count cycles in, and derive RPMs, b) calculate the sine angle and
    thus degrees of rotation for a very slow, or even stepped motor, and c) just
    plain count cycles, with a proper correction factor for the circumference of
    the circle described by the magnet's poles, to obtain distance traveled.
    For that matter, if you made sure that the motor shaft stuck straight up or
    straight down (wouldn't matter which, really, you just have t make sure the
    magnet is always at least near parallel to the earth's surface, so that it
    comes into North/South alignment, and out, at a regular rate of speed) you
    could calculate the change in angular velocity as the carrier vehicle turned
    a corner (for very short periods), and possibly (like doppler shifting) read
    the turn rate of the vehicle as a function of the sum or difference of the
    resulting count rates.
    Does that make sense? If not, and someone else would like to take a crack at
    rephrasing it, great. Otherwise, if it doesn't seem clear, let me know and
    I'll try to re-state the idea.
    I wish I had some kind of graphic software to use to draw what I'm talking
    about. Any advice on what to use, and where to get it?
    Mic
    Sent: Wednesday, April 09, 2003 5:14 AM
    Subject: [noparse][[/noparse]basicstamps] Re: SCR for motor control
    > Rob,
    > feature.
    > Ron
    > > Thanks,
    > > Rob
    edited 2003-04-11 02:32
    > Thanks,
    > Rob
    Hi Rob,
    assuming you are trying to do variable speed control, pwm is a simple
    way to pulse full voltage to a motor of yeild higher power at lower
    speeds.
    if you are interested in controlling speed, some form of encoder is
    needed and you would also want to use a PID loop to cotrol the
    signals.
    I think the existing forms of motor speed contorllers for hobby size
    motors are pretty good. when you get into the horsepower motors, you
    run into monitoring amps, hertz and volts. then you are getting into
    some heavy processing.
    the IGBT transistors fire at 32,000 hz to eleminate the resonance
    caused by the motor laminations vibrating. And then of course, there
    are some step thru frequencies so that if a particular motor does
    resonate at some frequency, you cna bypass that range.
    maybe if you let us know the motor size your are looking into we
    could offe a little more directon ?
    Dave
    edited 2003-04-11 02:36
    www.alltronics.com sells an optical encoder which will do exactly what you
    want and it will interface with the Stamp. Look under the Whats New link on
    their website.
    Bill Cramer
    Atlanta, Ga. USA
    Sent: Thursday, April 10, 2003 8:44 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: SCR for motor control
    has
    come
    > near the sensor?
    and
    just
    of
    the
    turned
    read
    at
    > Mic
    > From: Ron Jeremy <ronjeremy912@y...>
    > > Rob,
    > > feature.
    > > Ron
    > > > Thanks,
    > > > Rob
    and
    Bill:
    I understand, and I know that Gray Scale optical codecs have been around for
    decades (but not always in IC form. We had to build them from discretes when
    I was in the US Navy), but what I thought would be interesting was using
    only two magnet/hall sensor assemblies (one on a rolling wheel and one on
    the "compass card") to derive SO much info. And lurking in the back of my
    mind was how much fun it would be to get all that info with a Stamp.
    Mic
    Sent: Thursday, April 10, 2003 9:36 PM
    on
    > their website.
    > Regards,
    > Bill Cramer
    > Atlanta, Ga. USA
    > From: "Michael Duerksen" <michael_duerksen@c...>
    > has
    motor
    out
    sine
    > come
    > > near the sensor?
    a
    > and
    > just
    circumference
    > of
    > or
    > the
    it
    you
    > turned
    > read
    the
    crack
    > at
    and
    talking
    > > Mic
    > > > Rob,
    > > > feature.
    > > > Ron
    > > > > Thanks,
    > > > > Rob
    > and
    and
