--- In basicstamps@yahoogroups.com, "Jerry Walker"
<the_prettiest@h...> wrote:
> Is there a command that converts from TTL/CMOS or vice versa? Does
the stamp
> startup as TTL?
TTL and CMOS are fundamental chip technologies. TTL stands for
Transistor-Transistor Logic and usually refers to older bipolar
transistor input and output stages which consume quite a bit of
current. CMOS (Complimentary Metallic Oxide Silicon) is a different
technology that is tolerant of higher voltages and uses much less
current. I have never seen (or heard of) a software command to
switch between the two. If you require such capability you will have
to provide for it with hardware.
However, I have not done a recent, exhaustive study into emerging
technologies and it is very possible that someone, somewhere, has
made an MCU with that capability.
In a message dated 3/20/2003 5:08:01 PM Pacific Standard Time, the_prettiest@h... writes:
> Is there a command that converts from TTL/CMOS or vice versa? Does the stamp
> startup as TTL?
From what I see in the stamp manual, the Stamp is configured for TTL level
signals. I do not see a command to change the input logic from TTL to CMOS.
Although the logic thresholds are different for TTL and CMOS, when running a
CMOS IC Vcc at 5v, I have never had a problem using a CMOS input to the
stamp.
Tim
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, March 21, 2003 9:36 AM
Subject: [noparse][[/noparse]basicstamps] Re: TTL/CMOS Command
> the stamp
> > startup as TTL?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
This reminds me of when I worked at the CB amp factory. One of the
assemblers told me the IC chips were made from "Sea weed". I asked if
he meant 'CMOS' and he replied "Yeah thats it! Sea Moss!"
Paul
Does the stamp
> > startup as TTL?
TTL level
to CMOS.
running a
the
> stamp.
the stamp
> startup as TTL?
> startup as TTL?
stamp.
Tim
Original Message
> the stamp
> > startup as TTL?
Paul
Does the stamp
> > startup as TTL?
TTL level
to CMOS.
running a
the
> stamp.
