TTL/CMOS Command — Parallax Forums
TTL/CMOS Command
edited 2003-03-24 15:11 in General Discussion
Is there a command that converts from TTL/CMOS or vice versa? Does the stamp
startup as TTL?
    edited 2003-03-21 14:36
    --- In basicstamps@yahoogroups.com, "Jerry Walker"
    the stamp
    > startup as TTL?
    TTL and CMOS are fundamental chip technologies. TTL stands for
    Transistor-Transistor Logic and usually refers to older bipolar
    transistor input and output stages which consume quite a bit of
    current. CMOS (Complimentary Metallic Oxide Silicon) is a different
    technology that is tolerant of higher voltages and uses much less
    current. I have never seen (or heard of) a software command to
    switch between the two. If you require such capability you will have
    to provide for it with hardware.
    However, I have not done a recent, exhaustive study into emerging
    technologies and it is very possible that someone, somewhere, has
    made an MCU with that capability.
    edited 2003-03-21 15:18
    In a message dated 3/20/2003 5:08:01 PM Pacific Standard Time,
    the_prettiest@h... writes:
    > startup as TTL?
    From what I see in the stamp manual, the Stamp is configured for TTL level
    signals. I do not see a command to change the input logic from TTL to CMOS.
    Although the logic thresholds are different for TTL and CMOS, when running a
    CMOS IC Vcc at 5v, I have never had a problem using a CMOS input to the
    stamp.
    edited 2003-03-21 16:12
    CMOS- Complementary Metal Oxide Semiconductor
    Tim
    Sent: Friday, March 21, 2003 9:36 AM
    Subject: [noparse][[/noparse]basicstamps] Re: TTL/CMOS Command
    > the stamp
    > > startup as TTL?
    This reminds me of when I worked at the CB amp factory. One of the
    assemblers told me the IC chips were made from "Sea weed". I asked if
    he meant 'CMOS' and he replied "Yeah thats it! Sea Moss!"
    Paul
    Does the stamp
    > > startup as TTL?
    TTL level
    to CMOS.
    running a
    the
    > stamp.
