[RE: [[basicstamps] Room Mapping]]
Sorry, I haven't built them yet. It's just a concept at present. Each beacon
can be very inexpensive, or could get more complicated. An IR emitter could
be mounted on a servo, or a mirror on the servo, and different codes
transmitted based on the angle. Small bots could even have beacon
transmitters.
A beacon could use a TV remote IC, 3V, low current. Various intensities might
be useful for detecting range (and perhaps to avoid reflections, or take
advantage of them too).
The tabrobotkit yahoo group has some files on the chip that their IR remotes
use. There are lots of chips for that, and also on the receiving end. I have
a couple I got from Radio Shack, and 3 different ones from Jameco.
As for visualization, consider placing a flashlight on the floor so it
projects a beam of light. A robot could follow the beam and determine the
intensity. Now consider two more flashlights projecting beams that intersect
with the other ones, to form a triangle. With signals encoded in the beams,
the robot can tell which beam of light it is following, and what direction it
is going, toward or away from each emitter.
That's the rough idea; I don't know how well it might work out.
Phil.Kruger@A... wrote:
> Can you be more specific about your beacons. Are they for ID of room or
will
> your bot use for navigation. How did you construct? Battery? Powered
outlet?
> Inexpensive to build if I wanted bunches?
> Thanks
Original Message
> From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AOePAouwfMKIiXA4Zgnf_01tR81bRVn7IKQfN0GOhPnDYoBDoDTRH8xFA2_ranArRyH8KThEBA]fkerr@u...[/url
> Sent: Monday, March 17, 2003 4:42 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse][noparse][[/noparse]basicstamps] Room Mapping]
> I think a "beacon" setup may be needed, or may simplify things a lot. I'm
> planning to try this myself. Basically have a few IR LEDs in various
> locations and orientations, transmitting codes that can be distinguished
> apart.
> "laxboy687" <laxboy687@e...> wrote:
> > Hey all,
> > I'm working on a project to create a bot that roams my house taking
> > readings (temp, Fire sensors, etc...) and then reports them back to
> > my computer. I realize that in order to do this, my bot would have to
> > have a "map" of the house and where it could link up to my comp. Does
> > anyone have any expeirince with this type of navigation? I'm using a
> > BS2 so is this even possible?
> > thanx everyone
> > -Mike
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
> > and
> Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
transmitters.
will
outlet?
> Thanks
Original Message
> apart.
> > Hey all,
> > thanx everyone
> > -Mike
> > and
beacon A, once at Beacon A the bot goes to Beacon B and so on. Finally
when a voltage monitor sets off, the bot looks for the recharge beacon.
Is that possible? I wanted something like my bot going through different
rooms and then back to the recharge.
Thanx again
-Mike
Original Message
From: Fred Kerr (usa.net) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XI0AI0vBiSJJ-Jgn6M5aaaZyc1SUwSBO4jmmu2ifn382U_r6TdpTgTUlsWC2ahDXL0s_]fkerr@u...[/url
Sent: Monday, March 17, 2003 7:32 PM
Subject: Re: [noparse]/noparse]RE: [noparse][[/noparse][noparse][[/noparse]basicstamps] Room Mapping
beacon
could
transmitters.
might
remotes
I have
the
intersect
beams,
direction it
will
outlet?
> Thanks
Original Message
> From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XI0AI0vBiSJJ-Jgn6M5aaaZyc1SUwSBO4jmmu2ifn382U_r6TdpTgTUlsWC2ahDXL0s_]fkerr@u...[/url
I'm
distinguished
> apart.
> > Hey all,
to
Does
> > thanx everyone
> > -Mike
Subject
> > and
and
and
and Body of the message will be ignored.
I think the beacons are a great idea. But you might need more than the
beacons, especially if the bot is to go room to room in a large house. Also
it seems as if some object detection will be required, in case stuff gets in
the way.
If the bot will do a specific route, perhaps you could do something similar
to the "follow the tape" thing. Instead of tape, put tiny NIB magnets along
the path, and use linear hall sensors to follow them. Maybe use the magnets
down hallways and the beacons in rooms, with a little object detection in
case the dog gets in the way. I have never done such a thing, just a
thought.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, March 17, 2003 7:07 PM
Subject: RE: [noparse]/noparse]RE: [noparse][[/noparse][noparse][[/noparse]basicstamps] Room Mapping
> Thanx Fred for the concept. Do you think I could program the bot to find
> Thanx again
> -Mike
Original Message
> From: Fred Kerr (usa.net) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FJxcXwVjDX6iI8tmAuYmLxruMWTrbZIcMz0jswwvuxeWrAMCjJe3ouqjPw_IyohUbbeIXPSLcDE]fkerr@u...[/url
> beacon
> could
> transmitters.
> might
> remotes
> I have
> the
> intersect
> beams,
> direction it
> or
> will
> outlet?
> > Thanks
Original Message
> > From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FJxcXwVjDX6iI8tmAuYmLxruMWTrbZIcMz0jswwvuxeWrAMCjJe3ouqjPw_IyohUbbeIXPSLcDE]fkerr@u...[/url
> I'm
> distinguished
> > apart.
> > > Hey all,
> to
> Does
> > > thanx everyone
> > > -Mike
> Subject
> > > and
> and
> and
What are NIB Magnets and linear hall sensors? I have already got a
object detection system working and calibrated so I just have to get the
"route"
thing going.
Thanx
-Mike
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s5dXdfMX_Xjoz2zOOHyo8o6EU3FJwBs5FFGnBZyoyWu3v8nmSvCVWb_OCNjFMk19wiVkK7ojnEUMzfonEgPFUQ]jpeakall@m...[/url
Sent: Monday, March 17, 2003 11:19 PM
Mike, Fred,
Also
gets in
the way.
similar
along
magnets
in
thought.
Jonathan
www.madlabs.info
Original Message
find
beacon.
different
> Thanx again
> -Mike
Original Message
> From: Fred Kerr (usa.net) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AQJZqM-MljXTV5ZHiyGB6FESM59drWIwHYRsFYSLBnXbRgiNiZOiLEaXkMc7q8CZIG0mc792K7I]fkerr@u...[/url
Each
> beacon
> could
> transmitters.
intensities
> might
take
> remotes
> I have
> the
> intersect
> beams,
> direction it
> or
> will
> outlet?
> > Thanks
Original Message
> > From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AQJZqM-MljXTV5ZHiyGB6FESM59drWIwHYRsFYSLBnXbRgiNiZOiLEaXkMc7q8CZIG0mc792K7I]fkerr@u...[/url
lot.
> I'm
various
> distinguished
> > apart.
> > > Hey all,
taking
to
> to
> Does
a
> > > thanx everyone
> > > -Mike
> Subject
> > > and
Subject
> and
Subject
> and
and
NIB stands for Neodymium Iron Boron, which is the combination of elements
used to make really strong magnets, the strongest there are, I think. Check
out: http://www.wondermagnet.com/dev/main.shtml . They sell lots of them.
They can also be scrounged free from old hard drives. Small NIBs can be
gotten surplus and on ebay.
Hall sensors detect magnetic fields. They come in at least two flavors,
linear and I guess non-linear. Linear ones vary a resistance based on the
strength of the magnetic field. The others are an on/off type, as soon as
the magnetic field is strong enough it switches.
As I said, I have never done this. I would get a Hall sensor and experiment
with a magnet and see what range you can get. Then figure out how many
magnets it would take and see if it is practical. The reason I thought it
would be cool is that the magnets would be much more easily hidden than the
tape method.
Jonathan
www.madlabs.info
Original Message
Sent: Tuesday, March 18, 2003 3:35 PM
> Jonathan,
> "route"
> thing going.
> Thanx
> -Mike
Original Message
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6ALI5EMWEUr98qrEEVvO0wM-MZJKSO5SUhlDEy44881q9sF3WlOLLbDWsRC_5khnhl-BrzsUCy815xNbqpo]jpeakall@m...[/url
> Mike, Fred,
> Also
> gets in
> the way.
> similar
> along
> magnets
> in
> thought.
> Jonathan
> www.madlabs.info
Original Message
> From: "Mike Dillon" <laxboy687@e...>
> find
> beacon.
> different
> > Thanx again
> > -Mike
Original Message
> > From: Fred Kerr (usa.net) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7gWmVDCy1sjMrFv8wLxqv4_c7Od6RixijW93SvaeWU6DpSZjL2q6uMSyKR5Em7i_nneu2w]fkerr@u...[/url
> Each
> > beacon
> > could
> > transmitters.
> intensities
> > might
> take
> > remotes
> > I have
> > the
> > intersect
> > beams,
> > direction it
> > or
> > will
> > outlet?
> > > Thanks
Original Message
> > > From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7gWmVDCy1sjMrFv8wLxqv4_c7Od6RixijW93SvaeWU6DpSZjL2q6uMSyKR5Em7i_nneu2w]fkerr@u...[/url
> lot.
> > I'm
> various
> > distinguished
> > > apart.
> > > > Hey all,
> taking
> to
> > to
> > Does
> a
> > > > thanx everyone
> > > > -Mike
> > Subject
> > > > and
> Subject
> > and
> Subject
> > and
> and
they are in the lens asembley they are about 1 cm bye
1.5 cm and are realy strong [noparse]:)[/noparse]
--- Jonathan Peakall <jpeakall@m...> wrote:
> Mike,
> least two flavors,
> figure out how many
> tape method.
> Jonathan
> www.madlabs.info
Original Message
> > Jonathan,
> have already got a
> > "route"
> > thing going.
> > Thanx
> > -Mike
Original Message
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pRX_bQJT60sJqi3G-ZEG2CoRn8CVP4WkZc6qGKx1LW2V37SQKPXHDC81hNgMdTlvHRXfx1S_AQCcUMwGfNYp]jpeakall@m...[/url
> > Mike, Fred,
> > Also
> > gets in
> > the way.
> could do something
> > similar
> > along
> them. Maybe use the
> > magnets
> > in
> > thought.
> > Jonathan
> > www.madlabs.info
Original Message
> program the bot to
> > find
> for the recharge
> > beacon.
> going through
> > different
> > > Thanx again
> > > -Mike
Original Message
> > > From: Fred Kerr (usa.net) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KQqkoRGrUriWHRCYR6MjvLYO7sDKZG2F4iRl637Wvpz3w3cBSCesD7sQ30NLKVU2uO3s]fkerr@u...[/url
> concept at present.
> > Each
> > > beacon
> > > could
> and different codes
> > > transmitters.
> current. Various
> > intensities
> > > might
> > take
> > > remotes
> > > I have
> ones from Jameco.
> > > the
> > > intersect
> > > beams,
> following, and what
> > > direction it
> might work out.
> > > or
> > > will
> > > outlet?
> > > > Thanks
Original Message
> > > > From: Fred Kerr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KQqkoRGrUriWHRCYR6MjvLYO7sDKZG2F4iRl637Wvpz3w3cBSCesD7sQ30NLKVU2uO3s]fkerr@u...[/url
> simplify things a
> > lot.
> > > I'm
> few IR LEDs in
> > various
> that can be
> > > distinguished
> > > > apart.
=== message truncated ===
__________________________________________________
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
