Many questions for MAX 7219
1. Can I make a 64 LED matrix myself or do I have to use one
already assembled? I need a size of about 3' x 3'
2. Are there any schematics out there for wiring 8 columns and 8
rows of LEDs (Multiplexing)? I think I know how to do it, just want
some assurance.
3. Has anyone out there communicated serially through a Mac
program called Max/MSP through the serial object? If so, is there
a special protocol to use? I know the serial object only takes
numbers and when trying to send them to the BS, nothing
happens.
4. How can I test the the MAX7219 from the Pbasic editor to
check my wiring?
Your response are greatly appreciated, for this is part of my
thesis art project.
regards,
Silas
some assurance.
happens.
check my wiring?
thesis art project.
regards,
Silas
sistarr@h... writes:
> some assurance.
I think you will do better with a 6 x 8 display. The way the inside four
across the top would equal seg f, the inside four at the bottom would equal
seg c. This makes all segs four LEDs.
Sid
the matrix, two matrix of 64 led, the only one problem isthis chip
communicate by i2C......
Atentamente.
Ing. Damian Trujillo G.
RIESE & CIA, S.A.
Caracas - Venezuela
Phone: 58-212-7934266/4377
Fax: 58-212-7940791/0908
Email: dtrujillo_riese@c...
Original Message
Date: Martes 11 de Marzo de 2003 08:03:19 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Many questions for MAX 7219
some assurance.
happens.
check my wiring?
thesis art project.
regards,
Silas
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You say the size is 3 feet x 3 feet, is this correct?
If so you will need a huge number of LEDs and power supply and driver circuits
to support them.
Brooke Clarke, N6GCE
http://www.precisionclock.com
> From: basicstamps@yahoogroups.com
> some assurance.
> happens.
> check my wiring?
> thesis art project.
> regards,
> Silas
columnsstretched out 3' x 3', or a total of up to 64 discrete LEDs.
Silas
--- In basicstamps@yahoogroups.com, Brooke Clarke
<brooke@p...> wrote:
> Hello Silas:
and driver circuits to support them.
and 8
want
> > some assurance.
Mac
there
> > happens.
> > check my wiring?
> > thesis art project.
> > regards,
> > Silas
The MAX7219 is easy to interface with. Just follow the examples on
Parallax's website and in the NutsandVolts magazine articles (also on the
web). The only thing I had trouble with is being very careful to not
exceed the voltage and current maximum's on the 7219 (see data sheets). I
made my own 8" seven segment display using over 200 leds but the way I have
the leds connected series/parallel, I am getting too close to the maximum
current. One of these days I will either build a driver board for the 7219
or use one of the more powerful driver chips out there. Several people
have talked about this before, do a search for MAX7219 inside of this yahoo
group. Good luck, keep us informed, Dan
No, not a solid matrix stretching 3' x 3' but 8 rows and 8
Silas
Thanks for the feedback. Can I ask just one question? Since I
am new to programming in PBasic, how can you send out serial
data to test the matrix. I have a test board for 5 columns by 8
rows wired up, but I want to test it out before trying to get it to
communicate with a Mac program called Max/MSP. The debug
window makes no sense to me on how to send out data. Any
help would be greatly appreciated
Silas
daniel.d.dangremond@j... wrote:
> Silas,
examples on
(also on the
not
data sheets). I
but the way I have
maximum
the 7219
people
of this yahoo
LEDs.
> Silas
DEBUGIN function to get data from the DEBUG window (previously, you had to
use SERIN setup at 9600 baud).
DEBUGIN DEC cmd
will accept a decimal number. Now you can send it to the 7219:
SHIFTOUT Dpin, Cpin, MSBFirst, [noparse][[/noparse]cmd]
Since you're new to PBASIC you may want to download and skim through
StampWorks or any of our other educational books. StampWorks includes an
experiment with the MAX7219.
-- Jon Williams
-- Parallax
In a message dated 3/13/2003 8:29:14 AM Central Standard Time,
> Dan,
Silas
' Set means Invert sense (ie 232 drivers in use)
SerBaud CON 84 + SerInvert ' "84" 9600 baud from SEROUT Baud Rates
ReadByte VAR Byte
SEROUT 16, SerBaud, [noparse][[/noparse]"Enter a Value>"]
SERIN 16, SerBaud, [noparse][[/noparse]ReadByte]
' "16" means use Stamp debug port for I/O
-- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> If you've downloaded the Beta version of the new compiler you can
use the
had to
> DEBUGIN DEC cmd
through
includes an
> -- Jon Williams
> -- Parallax
> > Dan,
to
Silas
