Many questions for MAX 7219 — Parallax Forums
edited 2003-03-13 19:25 in General Discussion
1. Can I make a 64 LED matrix myself or do I have to use one
already assembled? I need a size of about 3' x 3'
2. Are there any schematics out there for wiring 8 columns and 8
rows of LEDs (Multiplexing)? I think I know how to do it, just want
some assurance.
3. Has anyone out there communicated serially through a Mac
program called Max/MSP through the serial object? If so, is there
a special protocol to use? I know the serial object only takes
numbers and when trying to send them to the BS, nothing
happens.
4. How can I test the the MAX7219 from the Pbasic editor to
check my wiring?
Your response are greatly appreciated, for this is part of my
thesis art project.
regards,
Silas
    edited 2003-03-12 00:13
    In a message dated 03/11/2003 19:06:19 Eastern Standard Time,
    sistarr@h... writes:
    > some assurance.
    I think you will do better with a 6 x 8 display. The way the inside four
    across the top would equal seg f, the inside four at the bottom would equal
    seg c. This makes all segs four LEDs.
    Sid
    edited 2003-03-12 13:11
    I recommend you to use the MAX6955, because this chip can be use 128 led in
    the matrix, two matrix of 64 led, the only one problem isthis chip
    communicate by i2C......
    Atentamente.
    Ing. Damian Trujillo G.
    RIESE & CIA, S.A.
    Caracas - Venezuela
    Phone: 58-212-7934266/4377
    Fax: 58-212-7940791/0908
    Email: dtrujillo_riese@c...
    Date: Martes 11 de Marzo de 2003 08:03:19 PM
    Subject: [noparse][[/noparse]basicstamps] Many questions for MAX 7219
    some assurance.
    happens.
    check my wiring?
    thesis art project.
    regards,
    Silas
    edited 2003-03-12 17:05
    Hello Silas:
    You say the size is 3 feet x 3 feet, is this correct?
    If so you will need a huge number of LEDs and power supply and driver circuits
    to support them.
    Brooke Clarke, N6GCE
    http://www.precisionclock.com
    > From: basicstamps@yahoogroups.com
    > some assurance.
    > happens.
    > check my wiring?
    > thesis art project.
    > regards,
    > Silas
    edited 2003-03-12 17:48
    No, not a solid matrix stretching 3' x 3' but 8 rows and 8
    columnsstretched out 3' x 3', or a total of up to 64 discrete LEDs.
    Silas
    --- In basicstamps@yahoogroups.com, Brooke Clarke
    <brooke@p...> wrote:
    > Hello Silas:
    and driver circuits to support them.
    and 8
    want
    > > some assurance.
    Mac
    there
    > > happens.
    > > check my wiring?
    > > thesis art project.
    > > regards,
    > > Silas
    edited 2003-03-12 18:10
    Silas,
    The MAX7219 is easy to interface with. Just follow the examples on
    Parallax's website and in the NutsandVolts magazine articles (also on the
    web). The only thing I had trouble with is being very careful to not
    exceed the voltage and current maximum's on the 7219 (see data sheets). I
    made my own 8" seven segment display using over 200 leds but the way I have
    the leds connected series/parallel, I am getting too close to the maximum
    current. One of these days I will either build a driver board for the 7219
    or use one of the more powerful driver chips out there. Several people
    have talked about this before, do a search for MAX7219 inside of this yahoo
    group. Good luck, keep us informed, Dan
    Silas
    edited 2003-03-13 14:26
    Dan,
    Thanks for the feedback. Can I ask just one question? Since I
    am new to programming in PBasic, how can you send out serial
    data to test the matrix. I have a test board for 5 columns by 8
    rows wired up, but I want to test it out before trying to get it to
    communicate with a Mac program called Max/MSP. The debug
    window makes no sense to me on how to send out data. Any
    help would be greatly appreciated
    Silas
    daniel.d.dangremond@j... wrote:
    > Silas,
    examples on
    (also on the
    not
    data sheets). I
    but the way I have
    maximum
    the 7219
    people
    of this yahoo
    LEDs.
    > Silas
    edited 2003-03-13 14:46
    If you've downloaded the Beta version of the new compiler you can use the
    DEBUGIN function to get data from the DEBUG window (previously, you had to
    use SERIN setup at 9600 baud).
    DEBUGIN DEC cmd
    will accept a decimal number. Now you can send it to the 7219:
    SHIFTOUT Dpin, Cpin, MSBFirst, [noparse][[/noparse]cmd]
    Since you're new to PBASIC you may want to download and skim through
    StampWorks or any of our other educational books. StampWorks includes an
    experiment with the MAX7219.
    -- Jon Williams
    -- Parallax
    In a message dated 3/13/2003 8:29:14 AM Central Standard Time,
    > Dan,
    Silas
    SerInvert CON $4000
    ' Set means Invert sense (ie 232 drivers in use)
    SerBaud CON 84 + SerInvert ' "84" 9600 baud from SEROUT Baud Rates
    ReadByte VAR Byte
    SEROUT 16, SerBaud, [noparse][[/noparse]"Enter a Value>"]
    SERIN 16, SerBaud, [noparse][[/noparse]ReadByte]
    ' "16" means use Stamp debug port for I/O
    use the
    had to
    > DEBUGIN DEC cmd
    through
    includes an
    > -- Jon Williams
    > -- Parallax
    > > Dan,
    to
    Silas
