Using Opto Isolators
I am building a large dc motor driver(still). I am using a PAK-V to
drive very large MOSFETs(100v 180amp rating, I'll be using 15vdc to
drive) and relays(12v 40amp). I would like to use a couple of Opto 22
modules that I have laying around. In the data sheet for the ODC5, it
shows using a N channel transistor. Has anyone used one of these
modules? Can I simplify and just send the positive signal? I would
assume that if i can, I can also use the same technique for the
Stamp's I/O's(switches,indicators,etc). Thanks.
Ian
Ian
I haven't used the Opto modules in a while, but a Web search looks like
they draw 18mA max from the control input and need at least 3.7V. The
Stamp and the PAK both can drive 18mA, but maybe not all at one time.
Both chips have a maximum current rating for the total. So for the PAK,
you can have about 130mA passing through the chip. The chip itself draws
80mA or so. So that gives you about 40 or 50mA to play with. If you are
drawing 18mA per pin, then two or three pins would put you right at the
limit and you probably want some safety margin. On the other hand, our
ratings are relatively conservative and your duty cycle will be less
than 100%, but you still don't want to push the envelope too hard.
The Stamp has a similar specs, so while you might be able to draw 30mA
through each pin, you have a limit of 60mA total or some such.
I wonder if the opto draws much current when off (I can't imagine it
does, but that would be easy to test with a ammeter). If so, maybe you
could use a pull up resistor to supply the on current and then just
switch the Stamp output to ground or an input. That wouldn't help with a
PAK-V though.
Hope that helps.
Al Williams
AWC
* NEW: New kits!
http://www.al-williams.com/kits.htm
Original Message
> From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=meNx-yw3G67mfmLNxlpwDncT2XXItt7YRAvlX_PlJOddcngwjH9s1cWWRD_foIY6aC7eGgM5GINEaz1pW-cI4gg]iphillips@s...[/url
> Sent: Saturday, March 08, 2003 2:35 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Using Opto Isolators
> Ian
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
negative side of the Opto would probably be the best idea then. I've
got a couple of IRL540n's left that I can use. Thanks again.
Ian.
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Hi Ian,
like
The
time.
PAK,
draws
are
the
our
30mA
you
with a
> PAK-V though.
> Hope that helps.
> Al Williams
> AWC
> * NEW: New kits!
